Old Sep 29, 2012, 08:59 AM
pabloreg is offline
Find More Posts by pabloreg
Joined Jul 2011
Originally Posted by cdi3d View Post
Pabloreg - I sent you a pm a few days ago - Sorry the day job has kept me hopping - Do you have the 1/2" spacer in the location that you mention above? Which servos are you using? Is your camera balanced on the gimbal?
MIke
Thanks Mike, i almost don't receive pm, so i don't check it. Thanks!
I'm using Savox SH0262, the camera is balanced, maybe can be improved, i'm making some tests. Thanks for modification tip, i was thinking in something like that.
pabloreg is offline Find More Posts by pabloreg
Old Oct 03, 2012, 11:24 PM
Crash_Clark is offline
Find More Posts by Crash_Clark
Joined Sep 2006
This is my spin on the installation. I went direct instead of linkage. I will hav to see how it works this way.
Hey Tony, how is that working? I like the KISS method!
Crash_Clark is offline Find More Posts by Crash_Clark
Old Oct 07, 2012, 09:43 PM
Lt.Smash is offline
Find More Posts by Lt.Smash
GRAYSON HOBBY
Lt.Smash's Avatar
Grayson, GA
Joined Oct 2003
Sorry for the dbl post, but I posted this in the incorrect thread...dang search
Hey...
I picked up a flame gear a few weeks ago and Im finally getting around to installing it. I would like to know where / if I can purchase more of the hardware and frame parts. I have a few cameras I like to try and I can see it will be easier to change the mounts rather than the cameras on certain models.
Specifically, the nuts, bolts, the silver ball looking thing, and the 2 frame parts that attach to the camera tray
Lt.Smash is offline Find More Posts by Lt.Smash
Old Oct 08, 2012, 03:07 PM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
Lt Smash - just contact tony at Rc-Drones.com and he will hook you up for hardware parts - Thanks
cdi3d is offline Find More Posts by cdi3d
Old Dec 08, 2012, 04:26 AM
RCmit is offline
Find More Posts by RCmit
Joined Oct 2012
Thinking about getting this mount but I am a bit concerned about having servo jitter issues. Are the Hitec servos recommended for it pretty good, I plan to run off my Naza gimbal connection.
RCmit is offline Find More Posts by RCmit
Old Dec 08, 2012, 08:02 AM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
What camera are you planning on running?
Old Dec 08, 2012, 09:14 AM
RCmit is offline
Joined Oct 2012
Sony action camera HDR-AS15, I might give an NEX5n with 16mm lens a go also.
Old Jan 06, 2013, 07:02 PM
Glenstr is online now
Find More Posts by Glenstr
Glenstr's Avatar
Canada, AB, Lac La Biche
Joined Aug 2010
I was getting bad shudder with my Hitec 65mg servos, and the roll servo stopped working altogether, I'm assuming because the wires were jammed up against the back plate too tight. I switched the hitec out with the only spares I had that would fit, some cheapo digital HK 928mg servos, even though someone said that analog were better for this.
Right away I noticed that the roll was smoother than the pitch servo, which still shuddered badly, no matter what the settings on the Naza, so I changed it out with another HK digital. With the cheapo HK the bad shuddering was gone, so there is still hope for this gimbal.
Glenstr is online now Find More Posts by Glenstr
Old Jan 07, 2013, 07:26 PM
tonyestep is offline
Find More Posts by tonyestep
Yep, Naza-controlled Tricopter
tonyestep's Avatar
St. Louis
Joined Apr 2002
The best way to eliminate slop in the roll axis is to hook the pushrod up as shown in the picture. It goes straight up from the servo arm to the plate above. Drill a hole in the plate, and use a piece of threaded 2-56 rod. Put one nut above the plate and one below, adjust correctly, then add a drop of threadlock.
The simplest setup for the pitch axis is a direct drive. Tap a servo arm for two 1-72 screws, and attach it using something to maintain a little spacing from the G10 of the camera mount. I used 2-56 nuts that just slip over the screws. Then you can tighten the camera mount solidly against the servo arm. Both servos are HiTec 85MG.
The GoPro is held in place by a simple scheme. Just make a backplate with two slots in it as shown, and hold it in place with a wire latch. The kink in the middle goes over a button as shown; this prevents the latch from vibrating out in flight.
tonyestep is offline Find More Posts by tonyestep
Discussion My DJI F550 with the X468 FlameGear XT landing gear and camera gimbal jasper7821 Multirotor Talk 3 May 30, 2012 10:36 AM
Sold X468 Frame (Standard) & Camera Mount (Medium) 500Driver Aircraft - Electric - Multirotor (FS/W) 5 Mar 16, 2012 04:31 PM
Sold X468 Quad RXR with GOPRO mount, for sale! tc3wins Aircraft - Electric - Multirotor (FS/W) 0 Aug 07, 2011 04:55 AM
Discussion Testing X468 Frame with GoPro mount cdi3d Multirotor Talk 53 May 05, 2011 05:31 PM
