Joined Jan 2013
On another note. I looked through the forum and couldnt really find an answer. But I would love to convert this thing to 2.4ghz... I ordered a controller and receiver, but am not sure that there is a speed controller module out there that will balance the two motors properly for turning. Have you ran across any ideas? Before I start doing some crazy engineering that is...
Joined Jan 2013
Re
Hey All
I have just inherited a QS8006 from my uncle. There was a black wire inside that had come loose, he re soldered it wrong and the receiver inside the heli fried! I took it off his hands, ordered and received a new PCB receiver board to install into heli. PROBLEM IS.... I have no idea how to rewire it back in. Does anyone have one of these that they can take a photo of how it is wired/positions of the 2 black/red wires, and email or post it for me?? So a photo from underneath the PCB Board? My heli is just sitting there in pieces screaming to be flown!! I know its a bad first investment but it was free Any help appreciated Cheers |
Joined Feb 2011
The 8006 (and 8005) can generally fly with a little minor tooth damage on the main gear, but the damaged gear (or gears) will usually make a clicking noise as the helicopter flies. If the main gear is damaged a little too much, the motor’s gear can slip some resulting in the helicopter doing continuous little left or right turning pulsations (and sometimes a tendency to want to rotate). When that happens the helicopter will generally be harder to control and will not hold a good straight ahead hover. Also another indication that the main gear is damaged a bit too much is that the helicopter won’t climb right or as fast and a buzzing sound will be heard as the gears teeth slip under power. About the control system; there’s no doubt about it, it definitely would of been a big improvement if G.T Model was equipping these large Qs helicopters with a better working, longer range 2.4 Ghz control system. When it comes to trying to convert to a 2.4G system, I haven’t really come across away to do it. I think the main problem of trying to convert the Qs8006 radio system to a 2.4G system is the 14.8 voltage system, currently there just isn’t many options available out there for this size voltage system on helicopters. Ray |
Joined Feb 2011
Check out my PCB photos in my post 574 located on this page http://www.rcgroups.com/forums/showt...620210&page=39 The photos show how the main power wires and the battery wires are attached. Also sometimes the new PCB boards come without the motor connectors installed (so that the main motor wires can be plugged in on PCB). The photos in the post also show the location of where to solder the main motor wires on. About plugging the wires onto the board; (when looking head on at front top of PCB, antenna wire connection will be towards back and on right side), the rear main motor wire will plug in on left pin connector, and front main motor will plug in on right pin connector. Both of the motor wires will have the red wires on right when plugged in. The tail motor plugs into the pin connector just to the right of the main motor connectors and the red wire of the tail motor will be on the right when plugged in. The ON / OFF switch pin connector is located by itself a little a head of the 4 LED pin connectors. The ON / OFF switch wire can be plugged in any direction (red wire can be plugged in facing right or left). The LED wires can be plugged in on LED pin connectors in any order from front to back, but LED wires are polarity sensitive for them to work. I have found that sometimes new PCB board will have LED polarity reversed on the LED pin connectors from the factory compared to the original board, so sometimes trial and error is needed when plugging them in. So if the LED light doesn't light up when the LED wire is plugged in, then simply unplug the wire's connector and rotate the connector 180 degrees and plug it back in and then LED should work. Ray |
Joined Feb 2013
QS8006 - newbie
Hi everyone....just got a QS8006 and after some not quite successful attempts to fly I now have a power issue maybe someone can help me with.
With the remote control turned off, and the power switch on the side of the copter in the off position, if I plug in the battery to the copter the top blades will start spinning in full throttle. What up with that??? thanks |
Joined Feb 2011
Hi Luv2_Ride,
I was wondering, how was your 8006 acting before the issue started? Also, have you been able to get the helicopter flying at all since buying it? Here's an idea for something different to try, I would try turning on the transmitter first and then turn on the helicopter to see if it changes anything at all. Could be transmitter to PCB binding issue, but I doubt it. Also, you might want to take the main blades off until the problem is fixed. That way the helicopter will be easier to handle when testing it. Ray |
Joined Feb 2013
Qs8006
Thanks Ray,
It was working fine. Out of the box and this was the first attempts at flying. Everything seemed to work fine. A few small short flights with my controlling it not so great. First time R/C owner for this type of machine. After the few short flights and minor crashes when I picked up the helo it was doing this. Cutting off the remote control or the main power switch on the helo does not effect it. when the battery finally run down, I disconnected the battery and took the helo in the house. Snow on the ground but not alot. I let the helo sit inside for several hours thinking maybe some moisture may have affected the board or one of the motor connections. When I lightly touched the battery to the connecting plug, the blades began to spin. Again power switch in the off position and the remote control power was off. Thanks for any help or suggestions you can give. |
Joined Jan 2013
Same issue
Joined Feb 2013
Qs8006
Thanks JM....I thought that may be the area to look into but wanted to research some before spending money for hunt and peck fixes.....could cost more in the long run.....mechanics famous words...."I thought the ECM computer would fix the problem" .....lol
Joined Dec 2012
Pilot Ray/Fellow Bloggers
I did all the repairs and got the bird flying again. Ray your timely advice to keep an eye on the two tiny bearings saved me a lot of possible heart ache when replacing the the main spindle and the blade gripper. Purchased a second bird as well for $92 to get over the issue of flying time. They are getting cheaper by the day. With 4 stock batteries I now enjoy continuous flying for well over half an hour! By the way mine are the GT models which I presume are the latest in the series. Still having a few mishaps mainly due to windy conditions resulting in having to replace main spindles/buckles/blade grippers (the tiny plastic knobs holding the buckle which tend to break off easily with the slightest pilot error!) and not forgetting the the smashed up blades which ever tend to get entangled! With repeated replacements I have now become an expert at changing the main spindle, blade grippers and dislodging the pin on the balance bar! Still a learner pilot though. Enjoying the newly acquired hobby not only while flying but also when carrying out repairs! I have found two sites, the first www.banggood.com where the spares are CHEAP AS CHIPS including FREE DELIVERY. The choice of spares is limited though with the more frequently replaceable parts only being in stock. The other is www.aliexpress.com still cheap with a very comprehensive stock. FELLOW BLOGGERS to please take note. Much cheaper than www.feala.com and some other sites. Have just received the 9x7 Tiger Moth propellers and looking forward to a busy weekend with modifications to the stock tail rotor. Ray, mine being the GT model, would it be still ok in weighting the front with hobby clay as suggested by "Helicrapter" for easy forward movement of the big bird? The alternative is to cut the plastic lip of the battery holder as suggested by you (unless you were referring to a different model) and move the battery forward. Please advice. Thanks Raj |
Joined Feb 2011
Hi Luv2_Ride, It does sound like the PCB board has gone bad and will need to be replaced One thing I would check for is to make sure that none of the PCB board’s electronic (metal) parts are touching one another. I would also double check all of the circuitry on the board with a magnifying glass to make sure that no little piece of solder, etc. has gotten trapped between electrical parts on the board causing a short circuit. I doubt that any of those things is causing the problem, but it’s worth looking at though. Ray |
Joined Feb 2011
Hi Raj, I’m not exactly sure which version Qs8006 helicopter you have, but either method will work good for adjusting the balance of the helicopter. On my 8006 the battery holder is located at the front of the helicopter and moving the battery forward is pretty easy to do with little modification (remove lip and add Velcro). Adding weight to the nose of the helicopter can also be used for adjusting the balance of the helicopter and is an easy way of doing it, but this method does require adding a slight amount of weight to the helicopter though. When using the larger tail blade on my helicopter, I did fine tune the balance of my helicopter a little to compensate for the larger tail blade (the larger tail blade is about 2 grams heavier than the stock blade). Ray |
Joined Dec 2012
Pilot Ray
The birds are flying beautifully forward with the modified tail rotor blades (with Tiger Moth propellers). Weighted the front of one of them with hobby clay as suggested by "Helicrapter". Tried to be a bit over enthusiastic with the forward throttle resulting in burnout of the tail motor now requiring replacement. A valuable lesson to be gentle on the throttle especially with the larger tail rotor blade. www.banggood.com is there to rescue with cheap replacement part. Takes two weeks for delivery though. The battery chamber in the GT model is vertically below the main spindle. This is the same model as displayed by "Helicrapter". Raj |
| Thread Tools | |
| Sold New Dynam Vortex M100 Infrared RC Micro Helicopter 3.5 Channel RTF $23.00 | Madd_Trucker | Aircraft - Electric - Helis (FS/W) | 0 | Feb 26, 2012 01:30 AM |
| New Product New 2012 Giant X-Large 42"inch (106cm) Alloy Hawk H-785G 3.5 Channels Helicopter Gyro | 44everlasting | Large Electric Helis | 0 | Jan 21, 2012 08:17 PM |
| Discussion G.T. Model 2-Channel RC Eagle Toy | novaking | RC Toys | 1 | Nov 12, 2011 11:35 AM |
| Discussion Phantom S107 3.5 Channel Helicopter @ Kidswoot | Phenom | Micro Helis | 2 | Sep 16, 2011 11:42 AM |
| Discussion New Syma S027 Big Fire Wolf 3 Channel Airwolf Ready-to-Fly RC Helicopt | james1300 | Coaxial Helicopters | 3 | Apr 21, 2011 02:35 AM |
