Old Apr 10, 2012, 12:52 PM
Pilot Ray is offline
Find More Posts by Pilot Ray
Joined Feb 2011
Hi everyone,
I have posted another tip that may help other Qs8005 and Qs8006 owners.
If any of the rotor shaft bearing’s are loose in their plastic housing’s, they can easily be tightened up by wrapping them with aluminum foil;
Reason; If any of the rotor shaft bearing’s seem too loose fitting in their plastic housing, they may cause extra gear noise, extra vibrations, can cause the rotor shaft to be loose with side play, can cause gear slippage under heavy throttle, etc..
Note; if the bearing’s can be pushed in and out of the plastic housing somewhat easily and don’t really have any side to side movement when mounted into the housing, then the bearing to housing fit should be ok.
To Correct - Last year on my Qs8005, I had found that the lower rotor shaft’s main bearing was pretty loose fitting in the plastic housing of the plastic frame block for some reason. I easily fixed the bearing to housing looseness by first cutting out a piece of aluminum foil that was slightly wider and exactly as round as the bearing‘s circumference. I then just very carefully and evenly press wrapped the outer race of the bearing with the aluminum foil. On my Qs8005, the lower rotor bearing was so loose that I actually had to use 2 pieces of aluminum foil to properly tighten up the lower main bearing’s fit in the plastic housing. Once I had the bearing carefully and evenly wrapped with the aluminum foil, I lightly pressed the bearing back into the plastic housing. Once I was done, the bearing looseness was 100 percent fixed, and my helicopter ended up with a bit less vibration and has flown great. The amount of aluminum foil that will need to be used will depend on how loose fitting the bearing is in the plastic housing. The goal is to tighten up the main bearing just enough so that they will be a slight snug fit in the plastic housings. This fix can be used on any of the main bearings that need tightened up on the rotor system, but due to the little size of the bearings, it does require a little tedious finger work and might require a few attempts to get them in just right.
Ray
Pilot Ray is offline Find More Posts by Pilot Ray
Old Apr 10, 2012, 04:18 PM
letterman7 is offline
Find More Posts by letterman7
United States, PA, Downingtown
Joined Feb 2012
Interesting, Ray. I never looked at my bearing play.. guess I should do that while I'm waiting on the electronics. They may be a little loose which might be another cause to my weird vibration issue. I'm thinking, though, that maybe a careful application of adhesive might be an easier way to fix this? Although with the aluminum foil you could essentially wrap the entire bearing if necessary and simply poke the shaft up through the middle!
letterman7 is offline Find More Posts by letterman7
Old Apr 10, 2012, 04:41 PM
Daggy is offline
Find More Posts by Daggy
Darren
Joined Mar 2012
G'day Ray
It is actualy my tail motor that's packing it in but thanks for the advise anyway.
I unplugged the main motors at the board and then did the start up procedure with the rx and tx.
I noticed that the revs would suddenly drop off with the tail motor at full stick but was fine in reverse, which makes me think the brushes are buggered. I should add that this was before I cut any wire!
Does any one know if I could use a variable voltage regulator between the rx and a motor that was rated under 12 volts?
I just found this 100W DC Motor Speed Control PWM Controller LED Display on ebay.
Darren
Daggy is offline Find More Posts by Daggy
Old Apr 10, 2012, 05:59 PM
gordonzo is online now
Find More Posts by gordonzo
Different fly 4 different guy
gordonzo's Avatar
Joined Jan 2011
Hey you fans of huge helis - how about a FXD A68690 advertised as 47" long?
gordonzo is online now Find More Posts by gordonzo
Old Apr 10, 2012, 08:50 PM
Joined Feb 2012
It wouldn't surprise me that the FXD is a knock off of the GT. It even has similar LED "missiles" on the sides of the frame. On one advert though, they have a photo of the upper blades being bent almost in half. Makes me wonder exactly how stable that thing will be in a hard turn if we're having issues with blade movement on the GT!
Old Apr 10, 2012, 10:20 PM
Joined Feb 2011
Hi gordonzo,
I saw a couple of those helicopters on eBay recently. I don’t know who makes them, but like Rick was saying, they are similar to the G.T Model helicopters. When looking at the photos they look like they could be a good helicopter, but since their haven't been out on the market very long, I don’t know much about them or whether their good or bad.
Ray
Old Apr 10, 2012, 10:21 PM
Joined Feb 2011
Hey Rick,
I bet you can’t wait to get your new receiver board for the 8006. I know when ordering parts from China, I’ve had parts come as quick as 5 working days, but the average time has been 8 to 10 working days. Waiting for the parts to come can seem like it takes forever when you need a part to fly again.
Ray
Old Apr 10, 2012, 10:38 PM
Joined Feb 2011
Hi Darren,
I think you are probably right about your tail motor going bad. Those little tail motors are asked to do a lot for their size, especially when the tail blades are increased in size.
About using something less than 12 volts on a 14.8 volt system, although Im no electric specialist either, but Im sure if the voltage difference is too big, the part wont last long. If its just a couple volt difference it might be ok, but any more volt difference than that probably becomes a bit risky. Maybe somebody on another thread in the RC forum could give you a more accurate answer for what your trying to find out. I know with the RC electronics, sometimes they can be sensitive.
Ray
Old Apr 11, 2012, 12:22 AM
Daggy is offline
Darren
Joined Mar 2012
Ok I've just bought a 12 volt 50mm ducted fan from the states and a 12 to 24 volt speed controller from Hong Kong.
It's going to take until next month before the controller arrives so this will be torture for me!
I'll keep an eye on this thread though and throw my 2 cents in when I can.
Darren
Old Apr 11, 2012, 12:33 AM
gordonzo's Avatar
Joined Jan 2011
Originally Posted by Pilot Ray View Post
Hi gordonzo,
I saw a couple of those helicopters on eBay recently. I dont know who makes them, but like Rick was saying, they are similar to the G.T Model helicopters. When looking at the photos they look like they could be a good helicopter, but since their haven't been out on the market very long, I dont know much about them or whether their good or bad.
Ray
FXD has been a round for a while but I have never owned one. They make helis from very small to very huge. And there are also FXD clones out there. We are trying to repair a knockoff of the FXD-A68688, about the size of the 9053. It is mostly FXD under the hood but has a different canopy. Build quality is so-so. The FXD parts are a bit hard to find.The original owner paid $250 at a mall kiosk and the current owner paid $100 with a non-working tail motor/receiver issue.
Left to right: a68675 (similar to 6025), a68688 (similar to 9053), and a68690 (biggest I have seen). FXD makes many others as well. Whether they are copies of something else I don't know, but they have a lot of different models.
Old Apr 11, 2012, 10:08 PM
Joined Feb 2011
Darren
Hi Darren,
Waiting for the parts to come always seems like its takes forever. Hopefully in a couple of weeks your 8006 will be shredding more of those gum tree leaves.
Old Apr 11, 2012, 10:09 PM
Joined Feb 2011
Hi gordonzo
The FDX’s look good, but do cost much more than the big G.T Model helicopters. It’s good to see there are other companies making big helicopter‘s though. The G.T Model Qs8006 is currently the biggest electric helicopter made with a length of around 53“ long. The Qs8006 is also much lower priced than the FDX A68690 and the Qs8006 is sometimes selling for under $130.00 with free shipping on eBay. Also, the FDX A68690 is 11.1 volt where as the Qs8006 uses the more powerful 14.8 volt. The good thing about the FDX though, is that it might urge G.T Model toy company to make a giant 3.5ch or 4ch. 60” Qs8007 helicopter with a18.5 volt battery, and priced under $150.00 so as to try too stay ahead of the competition.
Ray
Old Apr 12, 2012, 02:55 AM
gordonzo's Avatar
Joined Jan 2011
Hi gordonzo
The FDXs look good, but do cost much more than the big G.T Model helicopters. Its good to see there are other companies making big helicopters though. The G.T Model Qs8006 is currently the biggest electric helicopter made with a length of around 53 long. The Qs8006 is also much lower priced than the FDX A68690 and the Qs8006 is sometimes selling for under $130.00 with free shipping on eBay. Also, the FDX A68690 is 11.1 volt where as the Qs8006 uses the more powerful 14.8 volt. The good thing about the FDX though, is that it might urge G.T Model toy company to make a giant 3.5ch or 4ch. 60 Qs8007 helicopter with a18.5 volt battery, and priced under $150.00 so as to try too stay ahead of the competition.
Ray
Regarding the size of the QS8006 at 53" long. I didn't realize it was that big!
Regarding the wishful future 60" QS8007. again!
Makes my T23 look tiny and inadequate.
Wouldn't it be neat to a have 'large heli only' meet where we can all show off our big birds?!
regards . . . g
Old Apr 12, 2012, 08:34 AM
Joined Feb 2012
We'd need to meet somewhere in the midwest where there's enough room to fly birds that big! The 8006 is only 48/49" long, though.. I don't know where they got the 53" number they are advertising (maybe they stretched the antenna all the way back...). I can't imagine trying to maneuver a 60" heli where I am.. winds are bad enough with a small one!
Old Apr 13, 2012, 09:07 PM
Joined Feb 2011
Ray
Hey Rick or Darren, or anyone that has a Qs8006 helicopter
I bought and received a new Qs8006 helicopter yesterday (Friday) and have a question about the 8006’s transmitter.
I was wondering if the throttle (joystick) is suppose to be spring loaded on the 8006 transmitter (so that the throttle will shut off automatically when you let go of the joystick)?
I noticed that the throttle (joystick) on my new 8006 transmitter doesn’t have a spring return (joystick doesn't go back to the off position automatically) and I wasn’t sure if the 8006 transmitter is suppose to work that way.
This is different than on my Qs8005 transmitter since the throttle’s joystick on it is spring loaded so it automatically goes back to the off position.
I did fly my new Qs8006 helicopter with the throttle’s joystick working this way, and in a way I kind of liked it working this way since the helicopter can hold a hover on its own without having to hold the joystick. I guess the slight downside to the throttle joystick working this way, is that I have to be extra careful to not accidentally bump the throttle whenever the transmitter is on.
I did fly my Qs8006 one flight so far, and my 8006 helicopter was amazingly very stable and smooth flying. On my first flight I only did some very slow flying since my 8006’s blade pivots are a bit looser than I like and really need shimmed before attempting the faster flying.
Here is one thing I have learned about the length of the helicopter (length includes the swing radius of the tail blade);
------- the factory list the Qs8006 length as being 134cm (52.75“)
------- the box of my new Qs8006 lists the helicopter as being 130cm (51.2”)
------- my new Qs8006 helicopter when measured has an actually measurement of 127.6cm (50.25“).
So the above dimensions show that my Qs8006 is one inch shorter than what it’s own box says, and my 8006 helicopter is also 2.5” shorter than what G.T. Model toy factory lists on their website. That is somewhat of a pretty big discrepancy in measurements, and I‘m not sure why that would be, but regardless of the measurement discrepancies the 8006 helicopter is still a big electric helicopter at 50” long.
I plan to fly my Qs8006 in stock form for a short while so as to see how the 8006 performs in stock form, and eventually I plan to put on my larger modified blade on it, and I figure then my 8006 be close to the 53“size.
Also, I have been comparing the differences between my Qs8006 and Qs8005 helicopter and I have learned some very interesting things about them. I will post what I have learned soon, but at least now I won’t be in the dark when the posts are about the 8006.
Ray
Sold New Dynam Vortex M100 Infrared RC Micro Helicopter 3.5 Channel RTF $23.00 Madd_Trucker Aircraft - Electric - Helis (FS/W) 0 Feb 26, 2012 02:30 AM
New Product New 2012 Giant X-Large 42"inch (106cm) Alloy Hawk H-785G 3.5 Channels Helicopter Gyro 44everlasting Large Electric Helis 0 Jan 21, 2012 09:17 PM
Discussion G.T. Model 2-Channel RC Eagle Toy novaking Chit Chat 1 Nov 12, 2011 12:35 PM
Discussion Phantom S107 3.5 Channel Helicopter @ Kidswoot Phenom Micro Helis 2 Sep 16, 2011 12:42 PM
Discussion New Syma S027 Big Fire Wolf 3 Channel Airwolf Ready-to-Fly RC Helicopt james1300 Coaxial Helicopters 3 Apr 21, 2011 03:35 AM
