very nice job!!! A lot of skill with styrene. I noticed you said you are building the HMS Clematis.... good choice... i can't wait to see your build up of her.
Here is a link to my Clematis I built a number of years ago... http://www.48thfleet.com/k36.html |
Germany
Joined Mar 2012
Hi Rich.
Germany
Joined Mar 2012
Thanks, Foo. Youīre to kind. Until now itīs only some pieces of plastic, we have to wait if i can get her to swim and do her job.......
Germany
Joined Mar 2012
Hi Reid, thanks for the nice words. Did someone deleted the pics on that side? 3 ships are clickable (Destroyer, Clematis, Minesweeper), but only the destroyer has pics - the other 2 only show the info text. I would love to see the pics.
Germany
Joined Mar 2012
be my guest. Iīm glad if i could provide a idea you like to ad to your build.And your pic shows another cool painted tug ..... to bad i need mine to be warship grey. But who knows ..... maybe i will build another tug some day, next time more colorfull. But first i have to get this one to work.
Germany
Joined Mar 2012
Soooo, here we go again - it took some time, but as we all know the smaller the stuff, the more time consuming it is.
I wasnīt completely satisfied with the smoothness of the running shafts, prop and rudder, so i made small teflon-shims from a big industrial one (2 for the Propshaft and 1 for the rudder) .... and it makes a hell of a difference. First punching the small centerhole matchint to the shaft, and then aiming as good as possible to get it centered in the hole for the outline - i use Micromarks punching tool for this kind of work. ![]() ![]() ![]() The big and heavy metal searchlight from Graupner was replaced with a scratched one, in real it doesnīt look that bad as on this makro-pics ![]() ![]() ![]() ![]() The mast got itīs lights, too ![]() Iīve made some accurate looking housings from ps and 3mm leds, one pin on the left and the other on the right, soldered to 2 strand of bare cables, which were ca glued as flat as possible to the mast. After that some layers of Mr. Surfacer to blend everything together.
Germany
Joined Mar 2012
The rear corners of the house got their hose holders (ladder and door were only placed losely to check the look)
![]() And made the stern-light, ca. the same way as the mast-lights ![]() Soldered and bend some railing which i mounted to the ship ![]() ![]() ![]() ![]() As you may notice i did some work to the deckhouse and also some detailing with found parts from model-kits ![]() ![]()
Germany
Joined Mar 2012
Originally i hade the portholes a little bit to low, under the seam of the extended hull - but i decided i donīt like that. They were closed and will be positioned more accurate, later.
![]() Added some details in the wheelhouse (from old kits out of my greeblie boxes) ![]() Made the vents from PS-tube and a blob Aves Apoxie sculpt, after itīs cured a serious but carefull amount of sanding is needed ![]() ![]() From 0,3mm wire, wrapped around a piece of 0,5mm wire, i made some eyebolts for the coming rigging - and streched the first ropes. ![]() ![]() ![]() Slowly but steady it comes together. Unfortunately the bigger rings for the portholes are still not available, iīm eager to see it in grey colors. ![]()
| Thread Tools | |
| Build Log Salvaging a Lindberg Diesel Tug | RGinCanada | Scale Boats | 208 | Oct 19, 2012 11:53 AM |
| Discussion lindberg diesel tug kit | igotit | Scale Boats | 19 | Jul 04, 2011 06:58 AM |
| Discussion Lindberg diesel tug/Microglass G-13 hull questions | redlined_b16a | Dock Talk | 3 | Jun 15, 2011 08:30 AM |
| Discussion Lindberg Diesel TUG questions, suggestions | dostacos | Scale Boats | 19 | Aug 10, 2008 10:00 AM |
| Help! Lindberg 1/82 scale model Diesel Tug | sivadmatt | Dock Talk | 31 | Jan 13, 2007 01:14 PM |
