Old Mar 24, 2012, 09:53 AM
nadine is offline
Find More Posts by nadine
vtol fan
nadine's Avatar
Joined Jul 2009
Idea
Balsa airframe F3P
Hi guys!
I need some input.....I want to know if is a bad idea or good,if i try to make one f3p airframe,from light stick wood balsa and cover with light solar film to one side only!?It will be under 100 gr RTF ,what is your oppinion?
Some one did try in the past!?
Regards....
nadine is offline Find More Posts by nadine
Old Mar 24, 2012, 11:08 AM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
It may work, but foam is lighter.
If you did not want to make it out of foam you could make it out of carbon fiber.
http://www.rcgroups.com/forums/showthread.php?t=1158259
Free
Free is offline Find More Posts by Free
Old Mar 24, 2012, 11:26 AM
356Jim is offline
Find More Posts by 356Jim
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
Take a good, close look at the Vision 3D. I just finished mine, and AUW/RTF is 102 grams. That's a wing loading of 2.15 oz/sq. ft. for a 32" wingspan!!!!! It flies amazingly slow, as you'd expect and will survive a heck of a lot more punishment than balsa. (I love balsa, use it alot, but not for large aerobatic planes that I fly indoors).
Go to : FeatherlightRC.com
356Jim is offline Find More Posts by 356Jim
Old Mar 24, 2012, 11:41 AM
nadine is offline
vtol fan
nadine's Avatar
Joined Jul 2009
Ok...I got my answer....If is heavy i give up!
Maibe i will try with 1mm skeleton depron...thanks
Old Mar 25, 2012, 07:10 AM
crossup is offline
Find More Posts by crossup
Senior to who? Member
crossup's Avatar
Annapolis, Maryland USA
Joined Feb 2001
1mm depron =75% of 3mm weight. Use the 3mm and use less
crossup is offline Find More Posts by crossup
Old Mar 28, 2012, 07:11 AM
dylan roberts is offline
Find More Posts by dylan roberts
why wont it fly
south africa
Joined Jan 2006
http://www.rcgroups.com/forums/showthread.php?t=1378609
i did it with balsa and mylar.
best plane i had untill it had my entire stock of carbon fiber fall off the shelf onto it
dylan roberts is offline Find More Posts by dylan roberts
Old Mar 29, 2012, 10:13 AM
Trisquire is offline
Find More Posts by Trisquire
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
Balsa has been a valid building material for centuries. The full scale De Havilland Mosquito was partially made of balsa. There's no reason why a well constructed stick-n-tissue F3P plane can't be as light and perform as well as one made of high tech materials.
Trisquire is offline Find More Posts by Trisquire
Old Mar 29, 2012, 11:10 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Of course you can build an F3P model from balsa, but there is no advantage over Depron or Carbon and mylar covering.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Mar 30, 2012, 10:18 AM
Free is offline
Free's Avatar
Joined Jan 2012
Jürgen
Wow, that is neat! The balsa plane looks very hard to build.
Do you know the AUW of the Balsa plane?
Free
Old Mar 30, 2012, 01:16 PM
Joined Sep 2000
Free
Probably not as hard to build as some of the CFK models in this sub-forum.
AFAIK, the weight within the weight range of Depron models, but the IITOP organizers should be able to check the statistics sheets from 2010.
Here is a video:
IITOP 2010 F3P-AP Adam Vomberg (2 min 6 sec)
Jürgen
Old Mar 30, 2012, 04:52 PM
Free is offline
Free's Avatar
Joined Jan 2012
Hey Nadine,
If you start a F3P plane, please post pics.
Free
Old Mar 31, 2012, 07:14 AM
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
Adam's plane is nice, but I've got something more minimal in mind. Just a basic flat balsa framework, covered with undoped Esaki tissue on one side only, and then braced with plain old sewing thread. I can't help thinking that it would take less time than milling Depron. Martin's solution would be quicker as well.
Old Mar 31, 2012, 09:06 AM
crossup is offline
crossup's Avatar
Joined Feb 2001
Not trying to defend any method but milling can be pretty quick if you have a good eye and steady hand, and of course, not exactly fair, but if you make good templates then milling is very fast
. On the other hand, in any given size balsa can be much stiffer and at least for the best contest grade wood, probably lighter by a little bit. I built balsa planes for 40 years before I ordered wood from http://www.f1d.biz/ and was shocked at how strong and light wood can be. Its one of those, if you havent tried it, you have no idea deals. But the downside is it would be quite expensive, probably on a par with using CF tubing instead of rod. But thats probably one of those things where perception is a big factor: I've spent MORE than $100 for both my AITO v2 and HEPF Spark, both unmilled depron with pretty minimalist hardware. That equates to 45ft/15m of CF rod, enough for a composite airframe I'd guess.
Right now my first factory milled plane is in the mail, a Techone Yak at $40
Old Mar 31, 2012, 10:03 AM
Free is offline
Free's Avatar
Joined Jan 2012
For my planes I do what Martin does, it is LIGHT, STRONG, and EASY.
Free
Old Mar 31, 2012, 12:28 PM
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
I've never tried milling. I'm probably just resisting change.
On the subject of contest wood however, there must be a reason the indoor free flight guys haven't switched to carbon yet.
Sold SOLD - Fancy Foam Vrolet V1 F3P 3D kit with servos - $45.00 Shipped and Insured. GTMAXX Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Feb 29, 2012 09:28 AM
Sold Eflite 4-site F3P fruitguy Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Feb 27, 2012 06:55 PM
New Product F3P FANTASY-M (KKJ sky Balsa kit) wlrdy28 Indoor Pattern/F3P 20 Nov 21, 2010 10:57 PM
Discussion Any ideas on airfram for moki 2.1/evolution 35cc outofsight Giant Scale Airplanes 7 Nov 22, 2008 07:38 AM
Discussion Seeking Balsa Monoplane F3P Plans ? gbr677 Indoor Pattern/F3P 12 Oct 03, 2008 07:01 PM
