View Poll Results: Add ailerons or not???
Put Ailerons on 11 47.83%
Keep it stock RES 12 52.17%
Voters: 23. You may not vote on this poll
Old Mar 24, 2012, 08:30 AM
chamm37 is offline
Find More Posts by chamm37
Slope,thermal and Scale flying
chamm37's Avatar
Australia, NSW, Queanbeyan
Joined Jun 2008
Idea
Aileron Allegro-Lite 2m???
G'day guys,
I was just seeing if the Allegro-Lite 2m could become an aileron functional glider if i took out most of the dihedral in the wings and made it similar to the supra dihedral wing
I have been really thinking about it so I thought i would share and see what you guys think. The only thing that i am worried about is that if the airfoil for the Allegro will fly any good with ailerons? Whats you thought guys
chamm37 is offline Find More Posts by chamm37
Old Mar 24, 2012, 11:33 AM
Steve Anderson is offline
Find More Posts by Steve Anderson
Joined Sep 2007
Steve Anderson is offline Find More Posts by Steve Anderson
Old Mar 24, 2012, 12:59 PM
planepainter is offline
Find More Posts by planepainter
planepainter
planepainter's Avatar
Mt. Juliet, TN
Joined Sep 2008
Chamm, Your thinking shows real imagination and creativity. Our sport needs forward thinkers like you. Keep doing it. With that said, I have an Allegro Lite kit that a dear friend gave me. When I finally get around to building it, there is now way on this green earth that I would take a top drawer, high performance, take no prisoners 2 meter sailplane like the Allegro Lite and put ailerons on it.
But, that is just me.
Ok, now all of the rest of you are free to kick my a$$....
PP
planepainter is offline Find More Posts by planepainter
Old Mar 24, 2012, 07:35 PM
chamm37 is offline
chamm37's Avatar
Joined Jun 2008
Yes well if i had experience in bagging i would just do the bagged version but i want something unique and built up as well. That is why i was thinking of the Allegro lite and do something with her. I like the thought of ailerons and saying that too i have never really flown a res plane before
In theory it should work in saying all the kinks dont mess it up like what you were saying Steve with the torsional strength of the wing. I might be able to combat this with using whats called laminating film http://nqrc.com/?vp=laminatingfilm30x300
It adds considerable amount of stiffness to a wing and i cover all my combat planes with this stuff and man are they stiff ass and the beauty of this stuff aswell is that it is light
But the main problem would be the wing profile if it will fly any good with ailerons and not as much dihedral in the wing
Old Mar 24, 2012, 08:11 PM
chamm37 is offline
chamm37's Avatar
Joined Jun 2008
So this is a quick, very quick and accurate drawing... NOT!!! of what i was thinking for the wing.
The first dihedral of the wing will be the centre and on the plans it will be raised 1 inch at each section. The outer pannels will be raised 3 inches i think but dont know if this will be too much. Might even have to go at 3.5 inches
Old Mar 25, 2012, 06:24 AM
chamm37 is offline
chamm37's Avatar
Joined Jun 2008
What do you guys think?
Old Mar 25, 2012, 08:55 AM
glidermang is offline
Find More Posts by glidermang
chamm37:
Cutting a portion of the wing and hinging it for an aileron, by itself, won't affect the wing performance all that much. The question you have to answer is this: for the weight of the servos and wires, and for the drag of links, what will you gain?
If it's just roll control, I think it will not make much difference in overall performance. You'll be able to roll independently of yaw, but I'm not sure that's critical to soaring performance.
You don't need permission to incorporate ailerons, just a reason. If you are curious, why not build two wings? One with, one without. Compare weights and relative performance.
Yours, Greg
glidermang is offline Find More Posts by glidermang
Old Mar 25, 2012, 09:42 AM
chamm37 is offline
chamm37's Avatar
Joined Jun 2008
Curious would be more along the lines of this build here Greg. I was thinking about it today about building the two wings so that i could compare the two when they are done so atleast if the aileron wing doesnt work out i will still have a wing that will
With the spar system i am going to make it a little bit different to the plans. Im not going to be winching it up at all if anything it will be a high start that will be launching it up. I will be mainly throwing it around and using her as a DLG more than anything. So in explaining myself i plan on using 10mm carbon tube for the centre section, 8 mm for the middle and 5mm for the tips. The tubes should be strong enough for the application i need them for, certainly not a 150 pound winch launch
I will be using a bit of carbon on the wing so hopefully it will look sexy and add torsional strength for the ailerons to perform there duties
A idea crossed my mind that would be very cool and expensive. With the balsa sheeting on the LE, just imagine replacing that with a carbon fibre sheet. So instead of cutting the ribs to offset the balsa thickness, cut it to offset the 2k carbon pre fab sheet so all you would have to do is slip it on and glue her onto the ribs I WANTIE!!!
or less expensive way would be light fibreglass or another light fibreglass with 1k carbon toe in the cross weave design I WANTIE TOO!!!
Old Mar 26, 2012, 04:08 AM
chamm37 is offline
chamm37's Avatar
Joined Jun 2008
Got all my balsa today now the long process of cutting everything out, ohwell needs to be done but all the effort will be worth it and then on thursday i will go and pick up my carbon for the spar system hmmmmm carbon (drool face)
Old Mar 27, 2012, 09:46 AM
leons is offline
Find More Posts by leons
украина , чернигов
Joined Feb 2011
Hello! I am for the ailerons, my blog http://www.rcgroups.com/forums/member.php?u=347279
leons is offline Find More Posts by leons
Old Mar 27, 2012, 10:22 AM
chamm37 is offline
chamm37's Avatar
Joined Jun 2008
Dam it i wanted to be the first one lol well this is good because now i can ask you questions How did she fly just thermal so when you turned the motor off??? i watched the video but couldnt see it very well.
What is your dihedral at?
I made a little 1/4 scale version of it today out of scrap balsa and did it all to spec on the wing. Didnt worry too much about the fuse and everything just wanted to see roughly how the wing went and man she was awesome. For a little glider, into wind and it wasnt light wind either. The best flight was 9.5m its just balsa sheet no airfoil but it was AWESOME
Im going to keep the flap like as if it was a RES glider but just put on ailerons.
Old Mar 27, 2012, 11:28 AM
leons is offline
украина , чернигов
Joined Feb 2011
chamm37
I am an English Nesil if you correctly understand the video Allegro flies hovering mode, rather than on the motor
My Allegro weighs 750 grams with 34 dm ploschyadi has nazguzku 22gr/dm and it is very small for the Council of 9.5 m / s, I flew from the comfort of up to 5m / s
Here is my album of Picasso https://picasaweb.google.com/1088602...77642611/YycRK
and here is the soaring flight in the morning
ALLEGRO-FOREVOR-1 (0 min 42 sec)
Allegro without a motor of my friends did, too, for sale with ailerons
allegro_vaenga.wmv (1 min 44 sec)
Old Mar 27, 2012, 11:57 AM
chamm37 is offline
chamm37's Avatar
Joined Jun 2008
She flies beautifully oh i cannot wait to finish mine to get her in the air
Old Mar 27, 2012, 07:49 PM
Jebera is online now
Find More Posts by Jebera
Jebera's Avatar
United States, NH, Nashua
Joined Oct 2006
UAU!
Congratulations, very well done!
I have an Allegro short kit as well as a Bubble dancer short kit too, actually I already built one of each, by the book.
Now you gave me a very good idea, I'll do the same with both!
One question, what motor battery and servos you have? Weight ?
Regards!
André
Jebera is online now Find More Posts by Jebera
Old Mar 28, 2012, 01:39 AM
chamm37 is offline
chamm37's Avatar
Joined Jun 2008
This is probably going to sound silly but what is the best way to cut out a round spar hole in the ribs accurately???
Allegro Lite SchiessCo Electric Sailplanes 22 Mar 30, 2014 08:22 AM
For Sale Allegro-Lite 2m Pod Mold Sled Driver Aircraft - Sailplanes (FS/W) 5 Nov 02, 2009 03:49 AM
Wanted Allegro-E-Lite / Allegro-Lite Pod mr_g Aircraft - Sailplanes (FS/W) 0 Nov 20, 2007 06:51 AM
Electrified allegro lite (2m res) Kallikrates Electric Sailplanes 13 Apr 17, 2003 03:06 PM
