Old Mar 24, 2012, 02:27 AM
Bart10 is offline
Find More Posts by Bart10
Bart10's Avatar
Poland, Podkarpackie, Mielec
Joined Apr 2010
Help!
Scanning mode and slow beeps
Hello,
Some time ago, I used scanning mode in Spectra 2.4 with the oldest version of firmware. And I had a problem:
Sometimes I heard too slow beeps from the module but servos moved normall and fast (beeps weren't fast an usually).
Is this behaviour normall? Is something wrong with my Spectra 2.4 or it's bug of old software?
Bart10 is offline Find More Posts by Bart10
Old Mar 24, 2012, 01:50 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by Bart10 View Post
Hello, Some time ago, I used scanning mode in Spectra 2.4 with the oldest version of firmware. And I had a problem:
Please refer to information detailing all the warning beeps and LED combinations provided previous answer.
Being "Some time ago", perhaps some confusion remains.
If it has not happened again and you are now using the correct voltage during both setup and use of your TX & Transceivers, followed by a range check testing all operations, then there is no problem.
Alan T.
A.T. is offline Find More Posts by A.T.
Old Mar 24, 2012, 02:47 PM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
Thx. Today I tested it. Sometimes I had more slow beeps and sometimes servo moved normally and sometimes slowly. Sometimes blue led on the module stoped blink (lighted still light) and on RX the same but I didn't hear beeps.During I was doing these experiment I was keeping Optima very near TX.
I saw that when I connected JR plug and unconnected on very very short moment, behaviour of module and receiver is diffrent than ussually.
When I connected battery to the SWITCH with proper distance (0,75m about), two times I heard LONG beeps but servo moved normal. Is this normal?
Old Mar 24, 2012, 03:19 PM
A.T. is offline
Joined Aug 2002
Thx. Today I tested it. Sometimes I had more slow beeps and sometimes servo moved normally and sometimes slowly. Sometimes blue led on the module stoped blink (lighted still light) and on RX the same but I didn't hear beeps. During I was doing these experiment I was keeping Optima very near TX. I saw that when I connected JR plug and unconnected on very very short moment, behaviour of module and receiver is diffrent than ussually. When I connected battery to the SWITCH with proper distance (0,75m about), two times I heard LONG beeps but servo moved normal. Is this normal?
There is absolutely no point in your continued experiments with incorrect procedures and then posting anywhere on the interent that you have a "problem" or asking "is it normal".
Of course abnormal situations arise when correct procedures have not been followed, this with every known RC system.
Again, please reread all the information provided in previous answers,
use only the correct procedure regarding both separation of the units and minimum voltage under load.
making sure ID Setup is complete before cycling the power -
Do Not "when I connected JR plug and unconnected on very very short moment" these types of experiment lead to damage
- use the switch harness provided to ensure not only correct polarity but make it easier to cycle the power on/off.
Cycling power to quickly is no different to turning your computer on/off very quickly - does not power up nor shut down properly.
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Old Mar 25, 2012, 02:30 AM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
I know that these tests can be dangerous but I sometimes have too long beeps or first beep when I connected battery with switcher, in proper distance and after proper binding. So far, I noticed that the servos are moving normally after this situation. Should I be worried about this?
Please help!
And second question. Sometimes when I turn on the Optima very near module, blue LED on Spectra and RX stop blinking but I dont't hear beeps. Sometimes servo moves slowly and after few second module has a very long beep. Is this normal?
Old Mar 28, 2012, 04:23 AM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
I have done some tests recently. In scan mode I have slow beeps when I keep RX in specific place (about 1m to TX and at a specific angle relative to the antenna). I don't understand anything. Sometimes servo move slowly after these slow beeps. This situation is in every modules or in only my? I link 5 times with 6,8 V in proper distance from module to receiver. Please help!
Old Mar 28, 2012, 06:55 PM
A.T. is offline
Joined Aug 2002
Please refer back to the first sentence in post #4 above, why do you continue
to try and find fault with your system?
Nobody can ever give a full service check or diagnosis over the internet.
If in any doubt at all, pack your transmitter and transceivers/receivers and send package into
your service centre for a full check and suggest an update to the latest firmware in each unit.
Situation pictured can be achieved with all known systems by anybody swamping
the transceiver at such close range, especially if indoors.
You would not fly at that range. As mentioned previously,
"Optima Transceiver (RX) - Servo Move Slower Than Usual - then Rebind.
...(Switched between Normal <> Scan mode with power off before process completed). "
on FAQ page may also be a reason in this instance.
1. Use Scan mode for re-allocation of frequencies to suit your field.
2. Change back to and use Normal Mode for everyday flying.
3. Range check, are all functions operating at 90<100ft
These questions have all been answered previously, please re-read the information available under:
. AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ
. "Glitches & Jitter in Receiver, Servo & ESC - causes and cures "
. "Receiver Operating Range, Range Test & Range Problem Solving"
and more below
"Radio Systems, Accessories, Alterations and FAQ." at:
Alan T.
Old Mar 30, 2012, 03:46 AM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
Thank you . You wrote: "Optima Transceiver (RX) - Servo Move Slower Than Usual - then Rebind." I have to ask you- rebind when servo very often move slowly when I turn on RX before flight or when I've got "swamping" and servo move slower because I turn on receiver in too short distance? I saw that when I've got these slow beeps with Optima 7, servos sometimes move slowly but after some time they start move normally. But when I've got slow beeps with Optima 6 Lite, servo moves slowly but it started move normally only two times. It usually moves slow all the time. I bound in different ways, etc. from 1m Tx to Rx, from 2m Tx to Rx. Is this normal effect of swamping or maybe is my Optima 6 Lite broke? Please help!
Edit: One time when I turned on my Optima 6 Lite beeps were longer than usual, servos moved normally. I kept Tx about 3m to Rx and it was indoor. You wrote "swamping the transceiver at such close range, especially if indoors." So is this situation normal indoor but with proper distance?
Old Apr 21, 2012, 11:56 PM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
Hi Alan!
Sometimes I've got "swamping" in scan mode (beeps in the module are longer than usual). After these slow beeps servo sometimes jitter but after few second it begin to move normally. But in the old Optima 6 Lite servo sometimes (60%) begin move normally and in my new Optima 6 Lite (some oryginal firmware, maybe other than 2.02) and Optima 7 with f.v.2.02 it always begin to move normally. When I had original firmware in the old one servo NEVER began to start quickly. So maybe my second Optima 6 Lite is broken?
This video (problem is in 0:21)sometimes servo begin move normally but in the Optima 7 and the new Optima 6 Lite servo always begin move normally. These alow beeps are very rarely.
Optima 6 scan mode problem (0 min 40 sec)
I know that I should send it to service but I want to get a help from you.
Old Apr 22, 2012, 03:22 AM
A.T. is offline
Joined Aug 2002
Hi Alan!
This after previous answers to posts and emails as well as most recent answer to similar question on other thread "2. Get rid of firmware version 1.01 on your module and use version 3.01. It makes no sense, to use the latest version on receiver and the oldest version on the module. "
Can not assist any further. If after updating all your units to latest possible firmware and a "problem" still exists, then please re-read and take action as in first paragraph post #7 above "
Alan T.
Old Apr 22, 2012, 03:27 AM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
Problem is only in scan mode, so I haven't got its in the latest firmware version.
Old May 20, 2012, 02:56 PM
Bart10 is offline
Bart10's Avatar
Joined Apr 2010
Hello!
I have sent this Optima 6 Lite to service and I have got a new one. But I have the other problem with this receiver. When I'm in Scan Mode, I sometimes have to wait longer than usual for hear beeps form module. This is happen in my every RXs but in this one, I sometimes have to wait longer than in my other receivers for hear beeps. Is this normal? I hope that I get an advice from You, Alan. Sometimes after this longer waiting time I have "swamping" but this situation happens only in my new O6 Lite. I don't want to send it to service again and I'm very worried!
Plaease help!!!
Note: I very rarely have this situation (longer waiting time) when I turn off and turn on new Optima after "swamping".
Old May 21, 2012, 02:12 PM
MikeMayberry is offline
Find More Posts by MikeMayberry
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
Scan mode has to set the new channels so can take a few seconds to link. As suggested, you should update to the latest module firmware or at least switch back to Normal mode and most likely all your problems will go away!!!
Mike.
MikeMayberry is offline Find More Posts by MikeMayberry
Discussion Phoenix 80 Beeps on slow throttle up.. Tracon Castle Creations 3 Nov 13, 2011 01:05 AM
Discussion basic 2.4 question - scan mode vs normal mode? MCarlton Radios 3 Aug 07, 2011 10:48 PM
Discussion Suddenly beep, beep, beep is now beep beep, beep beep, beep beep - ESC arm sound chg? turnbui Micro Helis 5 Apr 14, 2008 03:12 PM
Discussion BEEP BEEP BEEP BEEP BEEP (you get the idea...) usrem Dock Talk 5 Oct 23, 2007 06:11 AM
Discussion Beep - beep - beep - beep - beep? boyntonstu Dock Talk 6 Oct 03, 2007 08:28 PM
