New Turnigy Sk3 Series Outrunners, Turnigy's "High end" Outrunner
$16.98 a piece it will be interesting to see how these stack up in the logger and in Real life video. http://www.hobbyking.com/hobbyking/s...der=2004189800 Anyways on with the pictures. For Hobbyking, this is the highest quality I have seen out of them yet. Just based on packing, accessories and whatnot. You can tell Turnigy wanted these to be their best motors. Screws and spare c-clips, shafts and whatnot, one benefit over the NTM series... Its pretty neat. One prop adapter is designed for the prop shaft, the other is designed for the motor to be mouned upside down with the shaft pointed down. First time I have seen this in the industry. These are the tiny outrunners I plan to use for my Mini Hexa FPV setup. Turnigy Aerodrive SK3 - 2118-2750 http://www.hobbyking.com/hobbyking/s...dProduct=18133 Unfortunately these are designed to be used with prop savers only. I did some research and Turnigy DOES sell a SK3 shaft that is 2mm and would fit, but I"m not sure its long enough for a prop adapter to grab ahold of. I'd prefer prop adapters so I'll try the setup with one motor to see if it works. Compared to Popular other Mini/Micro Outrunners. The A1510 2000kv, and the 18-11 2000kv 10g motors. (I've had a big failure rate from the factory on both these motors which is why I am glad to be seeking out a new alternative. I was going to go with the 1811 or the C10s otherwise. Will see how the high 2750kv affects flight characteristics. They came highly recommended by other members. Turnigy recently released a 2100kv so that is an option as well. http://www.hobbyking.com/hobbyking/s...dProduct=18113
United Kingdom, England, Redcar
Joined Jan 2006
Not special it just means ive wasted enough money on their low quality products and ive decided i would rather spend a bit more initially rather than have to buy the same motor over and over because of their low QC.
The comment wasnt directed at you but rather at the product, but if you want to take offence because of something you bought from a company with a long history of producing relative low quality items and doing their best to ignore warranty including deleteing comments from their website and foums , well , thats up to you. |
Czech Republic, Prague
Joined Nov 2011
I recently bought SK3 2826-1130kV
http://www.hobbyking.com/hobbyking/s...dProduct=18152 The positive: It ran great out of the box - smooth, quiet It flies great - it has loads of power (and I mean LOADS - compared to my other set of 150W emax motors, or AXN-1050) - and they don't heat up much Accessories are nice The NEGATIVE One prop mount had slightly smaller holes and I had to file them to get screws through (and those were quiet hard to tighten - I suspect something's not as precise here) After a major crash (upside down with throttle): prop mount fell off from one other motor - it just stripped inside the motor - screws are fine but nothing to screw them to anymore 3 prop mounts were bent (I only had 2 spares so I straightened one up - seems to work fine and doesn't even vibrate) One motor was shot - it's running fine but the whole bell is bent and it vibrates So that makes 2 motors unusable, but that's still more than I hoped for after this... ![]() Bearings seem to hold fine Overall I can't really complain - neat little powerful motors for a good price, usual QC issues are to be expected depending on how lucky you are.. |
I mounted them up on my FPV quad tonight. They spin up quietly, the bearings are very smooth. The accessories and hardware are hard, dont strip, and of good quality. All 4 motors came in perfect condition with solid bearings.
Power is ridiculous. I need to tone down PID's greatly but then again its been a while since I flew Multiwiicopter. One thing I noticed compared to any motor I've ever used. (mostly lower end stuff) the motors are SO SMOOTH. Power delivery is instant. I need to get a nice long flight in before I can comment about efficiency. Pix: I considered swapping the shafts so I could use the collect prop adapters but figured it wasn't worth the hassle. I used threadlocker in the prop adapters. |
Initial Results in. Got her hovering very stable. Hands off indoors for about 20 seconds before air drafts grab ahold and push it around the house. Timer was setup to log time up from 13%...
Motor efficiency is better than any previous motor I have used. I could have kept pushing this flight till around 14 minutes I think but no use causing lipo damage. Total hover around the living room test with 10.6v left 12:37 ![]() ![]() This is by far my new favorite motor. I will setup my hexa mini using the micro SK3s when I get the chance and get it flying FPV. Waiting on some micro Hitec receivers I ordered. |
Strapped on a freshly charged 5000mah 3s today and managed to pull a 15:56.8 flight.
Pretty damn impressed with the motors. This will help in FPV quite a bit. Im wondering what 4s would do for these... ![]() On the 2750s I plan on running 3s from the start, if its too much I'll drop voltage and increase battery size so I can try and squeeze some more flight time out of them. 16 minutes from a quadcopter is the longest I've seen a while. Very impressed with these motors. Will help a ton in FPV excursions. |
| Thread Tools | |
| Sold Turnigy SK3 3548-700 New Motor | Crist Rigotti | Aircraft - Electric - Power Systems (FS/W) | 2 | Mar 20, 2012 10:38 PM |
| Gallery Summer's End in the High Country | Acer | Life, The Universe, and Politics | 8 | Oct 03, 2011 01:37 PM |
| Discussion Spektrum DX10t ! Spektrum's New Flagship! Tray-Style, High-End Radio!!!!!!!! | Vicarious | Radios | 12 | Aug 22, 2011 09:32 PM |
| F/S New Futaba CDR-5000 High End Charger | GoodTill | Aircraft - Electric - Airplanes (FS/W) | 9 | Jan 21, 2005 07:58 PM |
