Old Mar 23, 2012, 11:52 PM
mazdaxxx is offline
Find More Posts by mazdaxxx
Québec, Canada
Joined Mar 2010
My Front Brake Setup - VMX 450
Helllo All,
This Vmx 450 as more than 75-80 packs throught it.
But it was well maintened throught the time and mod.......
It's the first batch with metal gears upgrade gyro - Free from Venom....Thanks
For the front brake setup i use a Hitec HS-85MG servo,
A Flak Jaquet graphite covered cable. rest of mountain bike setup
This cable have very smooth action and not lenghten under load, so if i set
my Dx3R Pro TX at 100% travel for brake action , the front wheel locked...
Too much power...so i set set the travel to 75% and i get result i want.
When set to highter setting you see the bike front suspension compress...just like the real thing,Great Bike I love It.........
http://i167.photobucket.com/albums/u...x/DSC02309.jpg
http://i167.photobucket.com/albums/u...x/DSC02324.jpg
http://i167.photobucket.com/albums/u...x/DSC02319.jpg
http://i167.photobucket.com/albums/u...x/DSC02317.jpg
http://i167.photobucket.com/albums/u...x/DSC02316.jpg
http://i167.photobucket.com/albums/u...x/DSC02315.jpg
The Blizard SR for winter...
http://i167.photobucket.com/albums/u...x/DSC02291.jpg
Aldo
mazdaxxx is offline Find More Posts by mazdaxxx
Old Mar 26, 2012, 12:38 PM
JohnnyMc is online now
Find More Posts by JohnnyMc
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
Hi Ado,
Care to explain a little more why a different wire? You said the stock wire stretched. What results did you get with the stock brake wire when upgraded to the mg servo? How thick is this new wire? The cover makes it look like overkill for situation. Can you provide links to items used?
Thank you,
John
JohnnyMc is online now Find More Posts by JohnnyMc
Old Mar 26, 2012, 10:55 PM
mazdaxxx is offline
Québec, Canada
Joined Mar 2010
Hi John,
When i installed the hitec servo with the stock cable,i only get a little more braking power.
So when the cable broke because it stretched, i upgrade to a bigger diameter to see the difference in braking power . Result = Wow...much more braking power - Night and Day...
Don't lose the power of the servo in the cable,because it don't stretch.
I don't have any links for the Flak Jacket wire.I buy a kit for my mountain bike locally a couple years ago, so i made the VMX cable with the rest of this kit.
I only say that the wire is covered with graphite - Very smooth action on the VMX.
The diameter of the wire is 0.045 inch.
The diameter of the outer tube is 0.100 inch.
For installing this cable you need to drill (0.063 inch) the cable lever and the 2 black
little adjusters.
For the cover, i made it HD because i want that the cable rest in place and don't interfere
with the fork when it compress or extand, or when i turn left or right.
I very like the results it give.....
Aldo
Old Mar 27, 2012, 10:36 AM
RC Dirt Bike Action
JohnnyMc's Avatar
Joined Feb 2010
Well, Ive seen a few other comments on forum for stronger action on this brake so it sounds like you figured out an option...upgraded servo and stronger cable. I have an upgrade servo, so some day I'll shop for the rest to try it out. Thank you for giving out the details, it helps a lot.
So, when are we going to see some stoppie videos from you??
John
Old Mar 28, 2012, 10:58 PM
Rellik is offline
Find More Posts by Rellik
Joined Mar 2012
I have been searching everywhere for a video of the front brake in action so it would be great if you made a video
Rellik is offline Find More Posts by Rellik
Help! Question on front brake for SB5 BipBayU Motorcycles 1 Oct 21, 2011 08:34 AM
Sold Hydralic front brakes for 1/5 baja jrplane Cars - Cars and Parts (FS/W) 3 Oct 13, 2011 04:26 AM
Help! Looking for a front brake for my hv maxx bike geeza_uk Motorcycles 2 Dec 11, 2006 05:30 PM
Front brake and setup question Cipprio Motorcycles 10 Oct 03, 2004 06:24 PM
Question Front Brake setup Tezza Motorcycles 42 Jan 15, 2004 01:53 AM
