Old Oct 21, 2003, 10:07 PM
Oklahoma City
Joined Oct 2003
More GWS motor questions
On all the specs on GWS IPS, EPU, & EPS motor/gearboxs, it has a line that says (M0.4) or (M0.3) followed by the number of teeth in the 2 gears. What does the M0.4 and M0.3 indicate?
cdw3423 is offline Find More Posts by cdw3423
Old Oct 22, 2003, 04:26 AM
Greenfield, OH
Joined Jul 2002
It's the pitch of the gear teeth. "MO" stands for Modulus, I believe. If you multiply the number of teeth by the modulus, you will get the pitch diameter of the gear in millimeters. In this country, our pitch is expressed, basically, as " teeth per inch"; a 48 tooth gear in 48 pitch will have a pitch diameter of 1". Metric gears are expressed in "mm tooth to tooth", while we use "teeth per inch". Threads on bolts work the same way. requires a new way of thinking.
rshockey
AMA33963
rshockey is offline Find More Posts by rshockey
Newbie Li-Po (with GWS motor) questions.. tridim Batteries and Chargers 14 Mar 01, 2005 03:31 PM
More GWS Battery Questions Bob HSG GWS (Grand Wing Servo) 2 Aug 11, 2004 01:47 AM
GWS Motor Questions...HELP !!! Tracon Power Systems 8 Apr 23, 2004 12:20 AM
GWS Motor Questions Electro992 Parkflyers 5 Apr 27, 2003 12:39 PM
GWS motor questions Electro992 Foamies (Kits) 0 Apr 26, 2003 06:14 PM
