Old Mar 23, 2012, 11:34 AM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
Cool
Simple Dollar Tree foamboard RC ( skirtless ) hovercraft
Made from 1 piece of Dollar Tree foamboard , some hot glue , packing tape , and popsickle sticks . 1 motor ( on throttle channel ) in can for lift . 2nd motor ( on elevator channel ) for thrust . Just disable the + wire on one of the ESC's going to the receiver so only ONE of the ESC's powers the receiver . Rudder servo can go on either rudder or aileron channel .
Works best on smoother surfaces . If you're going to use it outdoors , put something like window screen material at the bottom of the lift can to keep tiny rocks from kicking up into the prop . Works great for drifting !
Skirtless hovercraft (2 min 7 sec)
balsa or carbon is offline Find More Posts by balsa or carbon
Old May 01, 2012, 03:27 AM
dualplover is offline
Find More Posts by dualplover
Joined Nov 2011
can i ask the specs you used for motor and esc ?
dualplover is offline Find More Posts by dualplover
Old May 17, 2012, 01:03 PM
Joined Aug 2010
For the lift motor ( in the Instant Breakfast can ) I used the stock motor and ESC off of a crashed Hobby King SkyFun . It's 1800kv with a 25 amp ESC . For the thrust motor I used this combo from Lazertoyz ( third item down this page on left side ) http://www.lazertoyz.com/shop/specials.htm
Old May 19, 2012, 11:26 AM
samwei1950 is offline
Find More Posts by samwei1950
DIY Mania from Taiwan
Taiwan
Joined Aug 2011
Awesome:
easy build and very creative,gon'na build one for my kid
many thanks for sharing
regards
Sam
samwei1950 is offline Find More Posts by samwei1950
Old May 20, 2012, 12:38 PM
Joined Aug 2010
Originally Posted by samwei1950 View Post
Awesome:
regards
Sam
Let me know how it turns out - with video would be great !
Old May 21, 2012, 02:13 AM
Taiwan
Joined Aug 2011
Thanks,I'll make it fly in the air too
it takes some time to build,will post pics & vid for you when successed
best regards
Sam
Old May 21, 2012, 09:13 PM
Joined Aug 2010
best regards
Sam
I thought you might like this
The new FancyFoam FlipFlop! (2 min 58 sec)
Old May 22, 2012, 12:48 AM
Taiwan
Joined Aug 2011
Originally Posted by balsa or carbon View Post
What a fancy flip-flop craft,love it
is it a vector motor operated
best regards
Sam
Old May 22, 2012, 11:49 AM
Joined Aug 2010
best regards
Sam
Rudder & elevons
Old May 23, 2012, 01:06 AM
Taiwan
Joined Aug 2011
Thanks.
the 6mm EPP is coming it's way,will build both crafts
best regards
Sam
IMGP0360
Old May 23, 2012, 01:24 AM
Joined Aug 2010
Thanks.
best regards
Sam
IMGP0360
Looking forward to seeing the results !
Old May 26, 2012, 11:39 AM
Taiwan
Joined Aug 2011
Some cuttings started
Old May 26, 2012, 12:08 PM
Taiwan
Joined Aug 2011
Keep on going
Sam
PICT1095
Old May 26, 2012, 10:28 PM
Joined Aug 2010
Looking good!
Old May 27, 2012, 07:08 AM
Taiwan
Joined Aug 2011
Well,finished the Flipflop today and brought to the flying club for maiden flight,did a short flying in the field and cut away prop a bit shorter for easier flipflopping handling,but unfortunately stopped dued to the strong gusty wind
will do the job again and post vid soonest....
continueing on the hovercraft
Sam
PICT1124
Discussion Dollar tree foamboard? hayabusa Foamies (Scratchbuilt) 457 Dec 08, 2014 01:12 AM
Discussion Bulk Readi-Board (Dollar Tree foamboard) shipped directly to you? ExperimentalAir Foamies (Scratchbuilt) 15 Feb 05, 2012 01:38 PM
Question Ways to strengthen Dollar Tree foamboard. bass3587 Foamies (Scratchbuilt) 42 Feb 05, 2012 07:17 AM
Discussion Bulk Readi-Board (Dollar Tree foamboard) shipped directly to you? ExperimentalAir Foamies (Scratchbuilt) 4 Oct 28, 2011 11:41 AM
Mini-HowTo GET THE PAPER OFF!! calling all fellow dollar tree/elmers foamboard users justwanttofly Foamies (Scratchbuilt) 11 Sep 27, 2008 11:22 AM
