Old Feb 11, 2013, 12:49 AM
mnemennth is offline
Find More Posts by mnemennth
AMA 1033652
mnemennth's Avatar
United States, TX, Houston
Joined Jul 2012
Originally Posted by Picofly View Post
I didn't solder the microphone. It came just like that. There is an empty soldering pad on the left hand side of the red wire. I wonder is it for the audio wire?
I bought the camera from this place: http://www.ahdcameras.com/170-degree...el-camera.html
Whoooa, dude. 170°. No wonder it was making my eyeballs ache. [EDIT] And you said that in the text of the post; I clearly was not paying attention. *D'OH! moment # 5267*
Hey - I took my own advice; added a 470uf cap right at the TX 5V IN. COMPLETELY cleared up the horizontal banding. Thanks for the idea! Now I can move on to building a proper balanced output for the RX so I can hook a monitor to it.
mnem
Hover it, baby!
mnemennth is offline Find More Posts by mnemennth
Old Feb 11, 2013, 01:09 AM
Bo Lorentzen is offline
Find More Posts by Bo Lorentzen
FPVpilots do it remotely
United States, CA, West Hollywood
@Pico - sooo, you going to show us a test-flight with that fisheye monster.?
@mnemennth - agree fisheye get a bit much, but it is wonderful on the CP at slow-speed because the view to the side give a better feeling of sideways drift and speed over ground. probably the same reason helicopters tend to be made with solid side and down vision.
Naturally I would rather than a video goggle with a wrap around type display. but...
Bo Lorentzen is offline Find More Posts by Bo Lorentzen
Old Feb 11, 2013, 02:36 AM
OiOi is offline
Find More Posts by OiOi
Joined Apr 2009
Thanks picofly. Yes, the solder pad is for the audio. As everything is populated on the PCB, you can just solder a wire from the pad to your VTX to have audio.
Hmm, maybe then this one is the camera from the TX5805:
http://www.ahdcameras.com/2-mega-pix...ra-module.html
But without seeing the PCB it's hard to tell. But I guess the probability is high.
BTW: All the microphone circuit on the TX5805 cam is also populated, you can even see, that once there was a microphone soldered on it. But it seems Walkera decided to go without it and just cut it off.
Lol, this is also one of my projects in the pipeline. To use a projector with a special lens to have a 180° FOV. Sure this isn't anymore mountable on the head, but you would just sit inside it...
OiOi is offline Find More Posts by OiOi
Old Feb 11, 2013, 07:22 AM
Picofly is online now
Find More Posts by Picofly
Blade 180 FPV & Mini-Protos
Picofly's Avatar
Helsinki, Finland
I will give it a try on next weekend!
Weather has been really bad lately and I am quite busy at work at the moment. BTW, winter time FPV isn't much fun because lenses of my video goggles get foggy in cold weather and I need to wipe the lenses all the time.
Picofly is online now Find More Posts by Picofly
Old Feb 11, 2013, 12:50 PM
Cid156 is offline
Find More Posts by Cid156
Cid156's Avatar
Switzerland
Joined Sep 2008
Originally Posted by mnemennth View Post
PicoFly -
Cid - I really think you just answered your own question dude. If it's a regulator, they put it there because you need it.
Yes but if on the board (cam and tx) I have already a voltage regualtor (or a 1s lipo), I do not really need it ??
The only problem is that I do not know the required voltage for the camera
Because even with the wires removed, I am still near 3g... it is not so good for camera advertised 1g
Cid156 is offline Find More Posts by Cid156
Old Feb 11, 2013, 04:34 PM
AMA 1033652
mnemennth's Avatar
Joined Jul 2012
Originally Posted by Cid156 View Post
QUOT=mnemennth]
Yes but if on the board (cam and tx) I have already a voltage regulator (or a 1s lipo), I do not really need it ??
Because even with the wires removed, I am still near 3g... it is not so good for camera advertised 1g[/QUOTE]
Cid -
If it needs 3.3V and you're running 1s, yes, you need it. If 5V, no. Maybe. You may need one of the Pololu 2119 Buck/Boost regulator to feed it. That is, if it IS a regulator. It may be a noise filter; only experimentation can tell you if THAT is necessary.
Time to break out the multimeter, or pick a camera more suitable to the level of arse-ache you're willing to endure.
I'm flying a 5 gram camera right now on my V929; my other camera is 3 grams. The 808 #16V2 I WANT to run is 10 grams stripped.
Just a little perspective...
mnem
You got to run on any heavy fuel...
Old Feb 13, 2013, 10:38 AM
Deribas05 is offline
Find More Posts by Deribas05
Deribas05
Deribas05's Avatar
Russian Federation, Moscow, g. Moskva
Joined Apr 2012
Hello, Picofly! My name is Dmitry (Deribas05) ... I am very interested in how you're from a small helicopter made ​​a miracle ... I have a Walkera 4G6S (I had already booked and waiting for upgrade to 2C (7,4 V)) and the transmitter 2801-pro and I want to repeat your experience, but the time comes and I want to ask your advice ... What electronics do you recommend to buy, to install it on my 4G6S for flight FPV ... This includes - camera, transmitter, receiver, receiving and transmitting antennas
(all saiogo low weight), FPVvideoochki (your preference) ... Excuse me for my English, I am writing to you through a translator ... I live in Moscow and, with pleasure, I want to take your experience, if you want to share it ...
Sincerely, Dmitry (Deribas05)
Deribas05 is offline Find More Posts by Deribas05
Old Feb 13, 2013, 06:45 PM
Just a little FYI I ordered a couple of TX5805's from Walkera Helicopter Supply in the USA, great service got the stuff in a few days.
http://walkerahelicoptersupply.com/p...amera-tx-combo
The thing flew fine on my 120 only got maybe 100m on a good day, but tempted to hack it with a better antenna first. total system is about 9grams and remarkable noise free.
Old Feb 25, 2013, 11:43 AM
Summitdude is offline
Find More Posts by Summitdude
Summitdude's Avatar
Joined Oct 2012
Picofly,
How much does the 170Fov camera weight http://www.ahdcameras.com/170-degree...el-camera.html
and how does the quality compare to the other cams ?
Summitdude is offline Find More Posts by Summitdude
Old Feb 25, 2013, 11:51 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
Walkera is now selling FPV Googles for an extremely low price of $588
http://www.hobbyone.com.hk/cn/product.jsp?id=11406
zadaw is offline Find More Posts by zadaw
Old Feb 25, 2013, 12:25 PM
Picofly's Avatar
Helsinki, Finland
Originally Posted by Summitdude View Post
Picofly,
The camera weights 2.5g including the wide eye lens but picture quality has been disappointing so far. It is a poor performer in dim light.
Old Feb 25, 2013, 12:48 PM
Summitdude's Avatar
Joined Oct 2012
Ok thanks, if you find other high fov cameras pls post
I think its cool becouse the wide view and fisheye effect makes it look like seeing true a flying insect eye.
Old Mar 02, 2013, 06:38 AM
Picofly's Avatar
Helsinki, Finland
I was ready to dump my 130X for good when my 3 in 1 died a week and half ago but here we go again with a new unit... If this one dies I will dump the heli for sure!
I re-located the transmitter to the back side of the frame. This time I am testing a 20mW video transmitter and a FAN-antenna from TrueRC Canada. Reception was much better this time. Too bad that range of the the 130X's receiver is so poor that I can't fly far away.
I need to tune aileron gain down. The heli shakes a lot in -10 degree celsius weather...
Blade 130X Outdoors FPV - 20mW tx & Fan antenna (2 min 21 sec)
Old Mar 02, 2013, 10:30 AM
Pico,
Love your positioning of the vtx, sitting under the tail servo and the antenna above. brilliant, I have been struggling with positions this makes great sense.
Old Mar 02, 2013, 11:23 PM
Picofly's Avatar
Helsinki, Finland
The antenna looks good at the current location but the swashplate and rotor hub will block the signal when the heli flies directly towards the receiver. I have to go back with the stock plastic rotor hub because it is more RF transparent.
The next step is to boost input voltage up to 5.5V so that the transmitter will operate on 20mW power.
Mini-Review Walkera Mini CP Review - Pictures, Video, Flight Times, Head Speed, Brushless Upgrade Tom Z Micro Helis 701 Aug 17, 2014 11:54 AM
Discussion Walkera Mini CP sub-micro FPV heli (AUW 54g) Picofly FPV Talk 20 Dec 15, 2012 06:30 PM
Discussion Walkeras Mini CP - Value, Platinum or Premium ? SpookiePower Micro Helis 1 Mar 07, 2012 04:25 AM
For Sale 10 servos mini,micro,sub-micro JR/hitec new/used 48chebbie Aircraft - General - Radio Equipment (FS/W) 1 Jan 12, 2012 06:47 PM
