Helsinki, Finland
Sorry, no flips or rolls yet
!This time I am flying with 350 mAh batteries. They provide roughly 5 mins. of safe flying time. I tested range of my system in this video. It seems to be 50-60 meters.
Helsinki, Finland
I have recently installed a cloverleaf antanna to my heli and skewed planar wheel -antenna to the receiver. The heli is a little bit too heavy now (AUW is 53g with a 240 mAh Hyperion) but range of the video signal is better than it used to be. I am trying to shave off a couple of grams by using a lighter ESC next.
Helsinki, Finland
The first loops and rolls.
CrashMeUp: Sorry I didn't notice your question before. Thanks to the wide-eye lens and the cloverleaf antenna, my current camera & transmitter steup is quite heavy - roughly about 8g. The original setup (standard whip antenna and standard lens) was 4,8g the voltage regulator included. At the moment AUW of my setup is 54,3g with a 240 mAh battery.
I bought a new higher gain antenna for the A/V receiver from TrueRC Cananda. It is a funny looking piece of engineering (see the pic). The new antenna has expanded range of the video signal for few meters but IMHO, in this kind of low-range sub-micro scale the difference isn't worth of the investment (75 USD). Besides,it is too easy to fly the heli out of Walkera Devo 7 radio's poor operation range now .I did my first FPV rolls and loops yesterday. They went reasonably well .
-Pat |
Helsinki, Finland
BTW, your antenna is a nice piece of engineering and good workmanship! |
Great FPV set up! Love the videos. ![]() You mentioned the Devo 7s poor operating range. I'm about to set up a plane using the Devo 7. Any idea what the range is roughly? |
Helsinki, Finland
A friend of mine used WK2801 PRO with his Gaui X2 heli. There were occasional connection issues so we did a range test with full transmission power. Operation range was less than 80 meters ![]() ![]() . And excactly same thing happenend with another club member who used WK2801 with his Trex450. Last winter I was flying at the same time with another Devo owner. In theory two 2.4GHz transmitters should not interfere with each other if you don't bind them at the same time but my transmitter was intefrencing my friends heli. I have never seen anything similar happening with better radios (Futaba, Spektrum).Don't let fancy touch screen and shiny buttons to fool you. Walkera radios are toy grade! And if something happens there is absolutely no customer service available either. Last year I noticed that the other gimball of my Spektrum DX8 tranmitter was breaking down. I sent the TX back to the factory and they repaired and returned it free of charge ten days later. I would not image that happening if your Devo Tx breaks... |
Helsinki, Finland
new range record - 150 m
I have been following discussions about quality differences between different antenna manufacturers.
It seems that some cloverleaves perform better that the others and ideal operation frequency of the antenna may vary depending on all kind of variables. Until now I have been using only the default frequency on my A/V transmitter (5945 Mhz) but I decided to try if my system performs better on some other frequency. So I soldered a couple of jumper wires to the transmitter in order to switch the transmission frequency to 5685GHz. It made a significant difference: Range of my system expanded a lot and quality of the signal improved. I made a couple of 'long distance' flights and measured the distance with the Google Earth afterwards. My turning point was roughly 150 m away from the base station - not bad for a 10 mW 5.8Ghz A/V transmitter without a patch antenna ![]() ![]() . Even then quality of the video was really good but I didn't dare to fly any further because I don't trust my Devo 7 transmitter at all. Usually my heli goes to failsafe beyound 80m but this time I was lucky and the antennas were pointing to right direction.Quality of the video signal impproved at close range too. There was less faults or interruptions in the video than before. I am extremely happy with the result! |
| Thread Tools | |
| Mini-Review Walkera Mini CP Review - Pictures, Video, Flight Times, Head Speed, Brushless Upgrade | Tom Z | Micro Helis | 663 | May 02, 2013 02:54 PM |
| Discussion Walkera Mini CP sub-micro FPV heli (AUW 54g) | Picofly | Video Piloting (FPV/RPV) | 20 | Dec 15, 2012 06:30 PM |
| Discussion Walkeras Mini CP - Value, Platinum or Premium ? | SpookiePower | Micro Helis | 1 | Mar 07, 2012 04:25 AM |
| For Sale 10 servos mini,micro,sub-micro JR/hitec new/used | 48chebbie | Aircraft - General - Radio Equipment (FS/W) | 1 | Jan 12, 2012 06:47 PM |
