Old Mar 23, 2012, 10:36 AM
tuongnhu is offline
Find More Posts by tuongnhu
Joined Dec 2006
Help!
1.3Ghz video transmitter issue
After dozen of flights, my 1.3Ghz 300mW video transmitter has an issue. When it gets hot, It can not start. I am unable to make it work until it's cool.
Does everyone have this issue? How to solve it?
Thanks.
tuongnhu is offline Find More Posts by tuongnhu
Old Mar 23, 2012, 11:57 AM
Oddmar is offline
Find More Posts by Oddmar
Out of the way, Peck!
United States, AR, Arkadelphia
Joined Mar 2010
Stick some of these on the case of your Video TX and that will keep it cool...i even use a 25mm computer fan mounted over the heat sinks to keep air flowing over them in case i crash, so i still have video.
http://www.dealextreme.com/p/aluminu...iece-set-35816
Oddmar is offline Find More Posts by Oddmar
Old Mar 23, 2012, 10:21 PM
tuongnhu is offline
Joined Dec 2006
Just ordered some 25mm computer fans, aluminum cooler heat sinks from ebay and planning to get a new Vtx for backup.
Old Mar 23, 2012, 10:39 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I've seen the same problem with my 300mW 1.3Ghz Tx, but it's not so much
about being hot, but simply having been on recently. I've de-powered,
let it cool or a while, and still had problems getting a signal lock. I get the impression that
it's drifting off frequency and the Rx's PLL circuit can't quite find it. I seem
to recall having some success repowering or changing the channel on the Rx.
ian
Daemon is offline Find More Posts by Daemon
Old Mar 23, 2012, 11:38 PM
tuongnhu is offline
Joined Dec 2006
ian
It is completetly the same as mine.
Old Mar 24, 2012, 09:33 PM
tuongnhu is offline
Joined Dec 2006
I am going to buy this 1.3GHz 800mW FPV video transmitter fromRangeVideo for replacement of my old unstable 1.3Ghz 300mW vTx.
Does everyone use it before? Is it a good choice?
Old Mar 24, 2012, 09:46 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yes, that's a newer version of the tried and true Sunsky FOX800.
Note that while it's rated for 800mW, it really puts out about 600mW at
12V on 1280Mhz, which is *more* than enough for flights out over 10km.
ian
Old Apr 20, 2012, 07:07 AM
tuongnhu is offline
Joined Dec 2006
I just received my new 1.3ghz 800mW video tx from rangevideo today after one month waiting. The shipping cost is $20, it is crazy.
My old 1.3ghz 300mW is no longer working. The frequency have never been locked any more.
For now, when I touch the solder lead on the PCB, the frequency will drift to the near of last channel (about 1360Mhz) and the images can be seen on the screen but It is still not locked.
Rangevideo Vtx 1.3Ghz 300mW issue (1 min 40 sec)
Wanted Trade - My 1.3GHz SPW for your 1.3GHz CL Casey_S FPV Equipment (FS/W) 0 Mar 06, 2012 12:57 PM
Discussion Sources for LEGIT 300mw 1.3Ghz Transmitters? Bowerz FPV Talk 11 Feb 20, 2012 06:56 PM
Discussion 1.3ghz vtx issue datyip FPV Talk 4 Jan 24, 2012 08:49 AM
Discussion Low power 1.3Ghz transmitters? Freakazoid FPV Talk 7 Oct 16, 2011 02:34 PM
Discussion Video transmiter 1.2Ghz or 1.3Ghz ? EmilioCid FPV Talk 2 Dec 17, 2009 06:38 AM
