Old Mar 23, 2012, 10:17 AM
MelihK is offline
Find More Posts by MelihK
MelihK's Avatar
United Kingdom, England, Canterbury
Joined May 2008
New Product
Navigatron - I2C GPS for MultiWi and Other Projects from Flytron
Hi Guys,
I'm glad to announce our new I2C GPS module for all opensource projects.
Navigatron is an open source I2C GPS module with onboard Arduino and Backup battery.
It is compatible with current(2.0) version of MultiWii and i guess it will be a standard for most of GPS application.
Just connect the Navigatron with your I2C lines and read the GPS values when you need it.
FEATURES
  • I2C communication up to 400 kHz
  • Supports all 3.3v and 5v I2C systems.
  • 10 Hz update rate (1Hz with current MultiWii firmware and updateable)
  • Ultra Sensitive -165 dBm GPS receiver
  • Optional serial access to NMEA data (cross the Tx and Rx pins of FTDI to reading GPS module)
  • 3D Fix LED indicator
  • 1 week backup time with Super Capacitor
  • 3.3v supply voltage (You should replace the charge diode of supercapacitor with a blue LED for 5v supply)
  • Dimension:33mm x 23mm x 8mm
  • MediaTek Single Chip
  • Patch Antenna Size 15mm x 15mm x 4mm
  • L1 Frequency, C/A code, 66 channels
  • Embedded LNA and SAW filter
  • With Active patch antenna
  • High Sensitivity Up to -163 dBm tracking, superior urban performances
  • Position Accuracy < 3m CEP (50%) without SA (horizontal)
  • Cold Start is Under 35 seconds (Typical)
  • Warm Start is Under 34 seconds (Typical)
  • Hot Start is Under 1 second (Typical)
  • Low Power Consumption 48mA @ acquisition, 37mA @ tracking
  • Low shut-down current consumption 15uA, typical
  • DGPS(WAAS, EGNOS, MSAS) support (optional by firmware)
  • Support AGPS function ( Offline mode : EPO valid up to 14 days )
Product Details: http://www.flytron.com/sensors/180-i...nd-others.html
If you have any question about it, please feel free
Have a nice weekend
Melih
MelihK is offline Find More Posts by MelihK
Site Sponsor
Old Apr 03, 2012, 10:16 PM
FullmoonCat is offline
Find More Posts by FullmoonCat
Rank Amatuer
FullmoonCat's Avatar
United States, ID, Boise
Joined Dec 2011
Nobody commented on this? Craziness. So, to spark conversation, how would one go about hooking this up to a MultiWii board, such as my Quadrino? I'd love to try GPS features.
FullmoonCat is offline Find More Posts by FullmoonCat
Old Apr 05, 2012, 04:48 AM
MelihK is offline
MelihK's Avatar
Joined May 2008
Yes you right
We are talking about this on MultiWii forum
I guess there is no MultiWii user here
It is very simple and useful device and resolving very big problem of all gps integration projects.
I'm using it with my mq-200 micro quad
Site Sponsor
Old Apr 18, 2012, 01:20 PM
Dr.Tom is offline
Find More Posts by Dr.Tom
Youtube: TomRi25
Dr.Tom's Avatar
Croatia, City of Zagreb, Zagreb
Joined Aug 2010
I bought your navigatron GPS ( order # 3263)
is this correct way to connect it to 3.3V side of I2C on CRIUS SE?
http://www.goodluckbuy.com/mwc-multi...breakout-.html
http://homepage3.nifty.com/aohp/loca...20software.pdf
and if the 3v3 power regulators wont provide enough mA (+50 needed for your navigatron),
I'll hook it onto 5V BEC(install LED, as you suggest) that feeds whole FC, is this side of I2C then OK?
Do you maybe have any video of it on multicopter, gps hold & RTH ?
Sure will post mine if all works OK.
http://tinyurl.com/DrTomYoutube
Dr.Tom is offline Find More Posts by Dr.Tom
Old Apr 18, 2012, 02:49 PM
MelihK is offline
MelihK's Avatar
Joined May 2008
Hi Tom,
I dont have any experience with Crius boards but i saw MIC series voltage regulator on the board. My OpenLRS boards using same chip regulator for Atmel + sensors + Navigatron + RF module without any problem.
Please check the circuit diagram and find I2C sensor lines and 3.3v sensor supply for attaching your navigatron. I'm suggesting 3.3v mode of it for your setup.
I tested GPS functions on my 20cm MicroQuad (MQ-200) but wind speed was high and my quad didnt turn to home with current multiwii gains. This year, the wing was 10 times faster than previous years in istanbul. (Today was 120km!!!, 3 people killed by flying bricks or something) Maybe time to buying a windmill :/
I hope i will test it in one week.
Site Sponsor
Old Apr 19, 2012, 11:16 AM
Dr.Tom is offline
Youtube: TomRi25
Dr.Tom's Avatar
Joined Aug 2010
OK, thnx.
I don't have circuit diagrams of CRIUS SE board but will double check before connecting,
by tracing lines from I2C sensors back to LLC via multimeter, to be sure where to hook up
the voltage regulators are LG33 and LG50,
http://www.datasheetarchive.com/inde...&keywords=LG50
it's more complex spec. table than I expected, don't understand all info there but i think it is capable of 500mA max, so should be ok.
Wishing you good luck with gps test flight,
Hope you will record some of it and post here, so we can see how it works.
I sure will when my Navigatron arrives
Old Jun 16, 2012, 05:33 PM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
im interested to see how to connect this to my quadrino V1e board anyone do this yet?
Killab is offline Find More Posts by Killab
Old Jun 20, 2012, 09:23 PM
SGsoar is offline
Find More Posts by SGsoar
United States, CA, LA
Joined Aug 2007
so this gps sensor can plug directly into this board?
SGsoar is offline Find More Posts by SGsoar
Old Jun 21, 2012, 12:47 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
So looking at and reading the quadrino manual it looks like.
3V-I2C PIN HEADER
Most I2C sensors now use a 3.3v I2C bus. The Quadrino uses mosfet level converters to provide bus translation between the ATmega328 (Arduino) and the sensors. You can expand the number of sensors by wiring more sensors through this header.
Old Jun 23, 2012, 10:42 AM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
where is everyone on this thread i though this would be a hot topic.
Old Jun 25, 2012, 09:55 PM
The-8 is offline
Find More Posts by The-8
Me
The-8's Avatar
United States, OK, Goodwell
Joined Jul 2003
Thanks Killab! That is what I had figured, but was unsure.
So if I were to connect this GPS, I would then have to connect i2c sonar to the 5v i2c right?
SGsoar, it looks like the upper left is where your 3.3v i2c port is..
The-8 is offline Find More Posts by The-8
Old Aug 09, 2012, 12:21 AM
mentony32 is offline
Find More Posts by mentony32
mentony32's Avatar
Australia
Joined Jun 2010
I just ordered one to try with a Quadrino. Will report back how it goes.
mentony32 is offline Find More Posts by mentony32
Old Aug 09, 2012, 07:18 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
Me too, so anxious to get it. I'll even brave the 100+ degree summer weather to try it out.
I'll report back when I get it
Old Aug 22, 2012, 07:21 AM
mentony32's Avatar
Australia
Joined Jun 2010
Navigatron on Quadrino
I received my Navigatron tonight and wired it up. Pretty much plug-and-play so far. Will test fly tomorrow if the wind here lets up !
Old Aug 22, 2012, 09:26 AM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
Got mine as well, On the bench it fired right up and locked 9 sats. Will test when my new frame arrives. Qav500
New Product ArduLog GPS logger from Flytron MelihK FPV Talk 5 May 20, 2014 06:47 AM
Sold ArduPilotMega autopilot board, APM IMU Sensor Shield, I2C Magnetometer and GPS pilot006 Aircraft - Electric - Multirotor (FS/W) 3 Mar 13, 2012 05:07 PM
New Product Simle GPS Track board for APC230 or other APC series module 1.8 gram CSG_EU FPV Talk 2 Feb 21, 2012 12:13 PM
Sold Flytron OSD/GPS/CURRENT SENSOR $90 Shipped mrfliboy FPV Equipment (FS/W) 5 Jan 30, 2011 08:56 AM
For Sale Flytron OSD XL + Programmer, GPS CrashMeUp Aircraft - General - Miscellaneous (FS/W) 6 Sep 25, 2010 09:16 AM
