Old Apr 04, 2012, 12:30 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
It is running fine. A little loctite wouldn't hurt though.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Apr 04, 2012, 07:29 PM
Amp Abuser is online now
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
Kev, the motor is only good for 4amps? Your going to burn it up on 2s the drive line drag alone has it drawing close or over 1 amp no load. Even if you water cool the low pitched 15mm prop is going to be too much perhaps a 10mm. Are the ducted fan guys using it on2s with air flow? Recommend you go 2P 1S for the first tests do a temp check and duration check to get a feel of the amp draw under load.
Amp Abuser is online now Find More Posts by Amp Abuser
Old Apr 05, 2012, 07:31 AM
rLu is offline
rLu
Find More Posts by rLu
rLu
Los Angeles
Amazing projects. I am so impress by the speed of these mpr's you all have in these forums. Amazing.
Lu
rLu is offline Find More Posts by rLu
Old Apr 05, 2012, 08:50 AM
Joined Nov 2007
Ya it is running too hot. I hope I didn't overheat the motor on maiden. I'll switching to 1s.
Old Jul 27, 2012, 06:51 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
so how did it go kev, did you get to try it out?
i ask because i was working on mine today and am concerned that the prop might not lift out with my motor. if i hold the prop about half under the water, it screams like mad and throws water all over the bathroom
but with it submerged, i can't tell if it will have the push needed to get to the high rpm surface running.
i also think the cg might be too far back. hard to really tell without the sponsons though.
derk is offline Find More Posts by derk
Old Jul 27, 2012, 07:10 PM
Joined Nov 2007
I ran it on 2s in the spring and got to dangerous heat levels without noticing so I hope the motor is alright. I'll try it on 1s when I get the Scorpion (ya that name isn't really working too much for me anymore) going. I sold the receiver I used.
Old Jul 29, 2012, 09:46 PM
Akura2 is offline
Find More Posts by Akura2
PROFESSOR TRUTH JIMMY ICE
Akura2's Avatar
Joined Sep 2003
any news on this?... I would love to see a video...
Akura2 is offline Find More Posts by Akura2
Old Jul 29, 2012, 10:39 PM
Joined Nov 2007
I don't have it right now. My stuff are in storage for the summer. I'll have to pick the project back up in the fall.
Old Jul 30, 2012, 06:35 AM
derk is offline
derk's Avatar
Joined Dec 2003
mine isnt finished yet, hopefully when i get to run it, i can get some video of it too
Old Aug 09, 2012, 09:07 AM
derk is offline
derk's Avatar
Joined Dec 2003
here is some progress i have made on my rigger. i also made the top decking and just need to seal the hull before i can test run it
for the hardware, i used some pre made fiberglass plate i found in a power supply box.
i also glued the esc female connector to the side of the hull to help keep the wires away from the motor, it's not too difficult to plug and unplug.
Kev, i used a piece of that silicone tube as a pushrod boot with some plumbers grease, its smooth but water tight.
Old Aug 10, 2012, 03:47 AM
derk is offline
derk's Avatar
Joined Dec 2003
got to run the rigger for the first time, and while it is much faster than the cracker, i think my motor is working a bit to hard for this application. after opening it up, i could smell the heat of the windings
unfortunately, the pool i'm at isnt large enough to get full throttle for more than a split second before it hits a wall! i need an Olympic size pool haha
Old Aug 10, 2012, 01:28 PM
Joined Nov 2007
So I guess I'm not the only one with heat. I hate to say it, but I think it is being caused by the flex shaft rubbing on the aluminum stuffing.
Old Aug 10, 2012, 08:10 PM
derk is offline
derk's Avatar
Joined Dec 2003
its a possibility, it would be a good test to change one out with jointed drive and the same motor and see what the difference is.
i will still try to get a video of this one, even though it never gets full speed because of the short space
Old Aug 13, 2012, 11:28 PM
derk is offline
derk's Avatar
Joined Dec 2003
shot some video today at the pond, couldnt get one in the pool. and as i feared, the motor cooked after the second lap
i will play around with lubing the drive shaft as well as other motors.
MPR Rigger (1 min 1 sec)
Old Aug 14, 2012, 12:27 AM
Joined Nov 2007
Sweet, mine did the same exact thing, except it isn't setup right so it didn't go anywhere fast.
For Sale Evolution rigger with full mod zenoah DumthumbsFRANKIE Boats (FS/W) 7 Mar 02, 2016 12:35 PM
Discussion R2 Hobbies Rigger. 785boats Racing Boats - Electric 19 Aug 20, 2012 01:45 PM
Cool MPR-1&2 boats derk Micro and Sub-Micro Boats 139 Jul 18, 2012 01:49 AM
For Sale Climate Blizzard Rigger Nightow2 Boats (FS/W) 0 Mar 11, 2012 09:27 PM
Discussion Hydro I DIY Rigger FlyingNiko Racing Boats - Electric 7 Mar 09, 2012 01:11 AM
