Old Sep 16, 2012, 06:26 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Original Mirage 2000 molds, no way anyone is going to make a new mold right now in China, lots of worry about the economy, we are lucky to get Ricky to shoot the original mold again as he didnt really want to
Yes he has been working on larger glass models, the J10 is huge!!! I have seen the maiden flight and its a bloody big turbine model, he is now distributing the NT turbine range too, they are an OEM for a large EU company.
Soon as he is happy with the package it will be available for the large turbine guys. There is a couple of glass Mirages on the horizon too, one with a 1500 wingspan and one with 1700+ span, the 1500mm one is what interests me the most, with a 127mm Alloy ramtec fan on 14s would be quite interesting
Extreme_RC is offline Find More Posts by Extreme_RC
Old Oct 15, 2012, 11:56 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Hey guys, does anyone have a photo of the tail from the IIID Mirage with the tiger head in it?
We are doing the decals and hard to find a decent tiger head pic to get the details right. Any help will speed things up a lot!
Old Oct 16, 2012, 03:01 AM
dro56595@bigpo is offline
Find More Posts by dro56595@bigpo
dro56595@bigpo's Avatar
Australia, ACT, Symonston
Joined Aug 2008
Will see what I can find at work. Pretty sure that's the No.2 Operational Conversion Unit logo...
dro56595@bigpo is offline Find More Posts by dro56595@bigpo
Old Oct 16, 2012, 03:06 AM
Joined Aug 2008
Here's one:
http://www.thebaseleg.com/Aviation/W...6531&k=3qvCjG5
Old Oct 16, 2012, 05:47 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Hey Dan, yeah I got the baseleg site thanks, but cannot copy the pics, have to email them to ask if they will supply one. Have sent that to Ricky as reference, but would like something even bigger or a proper artwork side view
Old Oct 16, 2012, 07:23 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Ok I have started building the spare Mirage kit I have had in storage, I want to get one up and running with the Extreme Alloy Jetfan fan unit and the weather is getting better now so I can get it glassed in a couple of days.
First up wings. I wanted to hide my servos inside the wings and as it will be belly lander I wanted my horns topside.
I dont like the old flyfly horns much so made my own from 1mm ply sheet, 3 pieces CA'd together with the centre piece cross grained. Very tough horns.
Pictures show where I put the servo, if you plan on retracts then easy enough to move the servo back further in the wing so there is space to cut out the wheel well.
I am using Hyperion ATLAS DS13TMB metal gears, yes they are a little pricey but there is only 2 of them, and I want this thing to be reliable and last.
I dremel out all the areas for the servo horn clearance, and I used the round horns cut down as they are the toughest horn. Mirage needs very little throw on controls and even with this horn I have to cut the throws back to 50% or less on the radio. I will likely do it in the servo though with the emeter as limiting them digitally is better than using rates in the Tx.
Dremel out the area for the servo tray, epoxy in the ply, line everything up and then epoxy the servo in all round with a spruce block to secure the open end. I will add balsa to the top of the servo and carve it to shape so when the wing covers go on they contact the servo and provide extra support.
I use K&N alloy tube heated under gas then pushed through the wing to make the channels, its not easy to get it dead aligned but dont worry if the hole ends up too big or messy, once you epoxy the plastic guide tubes in you can fill the hole at the top then spackle it over, ends up looking clean on the outside which is all that matters! )
Wing is now glued together, next up put covers on and sand back lightly with 320 alloy oxide paper ready to glass. Next pics will be glassing the wing, and I will prepare the fuse halves ready to lay out the electronics.
Old Oct 17, 2012, 03:08 AM
Joined Aug 2008
Had a quick look at work today - no joy on an electronic record of the artwork. No computer design in those days - was a matter of what the paint shop guys could do by hand on the day ...
Old Oct 18, 2012, 02:25 AM
Joined Aug 2008
Maybe these can be scaled up, with permission of course ...
http://decals.kitreview.com/decals/h...reviewme_1.htm
Old Oct 18, 2012, 07:51 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Nice, I will send him the link so he can use it to scale what we have so far, the sample is looking good, but need some size adjusting and there are some missing, hopefully by Monday the decals are ready for the printer.
Old Oct 18, 2012, 02:14 PM
tomme21 is offline
Find More Posts by tomme21
tom
tomme21's Avatar
USA, LA, Natchitoches
Joined Apr 2004
pic
try
tomme21 is offline Find More Posts by tomme21
Old Oct 18, 2012, 02:46 PM
shhhhh! is offline
Find More Posts by shhhhh!
Yes..ok..maybe..lol.....
Tucson Avra Valley, Arizona, United States
Joined Jul 2004
Yes..........Top drive is nice:
http://www.rcgroups.com/forums/attac...mentid=4859622
shhhhh! is offline Find More Posts by shhhhh!
Old Oct 19, 2012, 04:40 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
http://www.airliners.net/photo/Austr...3de7590bb1c86e
If you know someone in Willytown, apparently the Mirage there is painted up in OCU colours.
Also, the tiger head has been used since Macchi days. Might be worth looking at some of the old jets too?
Odysis is offline Find More Posts by Odysis
Old Oct 19, 2012, 05:08 AM
Joined Aug 2008
Yeah, I 'work' there, but haven't seen it out in the open anywhere - unless it's at the Fighterworld museum just outside the base. Haven't been in there for a decade.
I could ask to take photos if it's there ...
Old Oct 19, 2012, 05:31 AM
Odysis is offline
Joined May 2007
That's where it is, according to some random flickr person!
'work' - that's what happens when you get promoted :P
Is OCU's current flash digitalised?
Old Oct 19, 2012, 06:53 AM
Joined Aug 2008
Yeah, got another line last year so now I'm doing twice the work but the remuneration doesn't match the rate of effort >
Will have to poke around in their p drive, but most stuff is hidden away and access controlled these days. Will make the effort if those decals I linked to don't work.
New Product MIRAGE IIID Aussie Scheme! & BUILD LOG Extreme_RC Extreme RC AUSTRALIA 26 Jan 26, 2013 04:42 PM
For Sale New in the box Top Gun Mirage the big g Aircraft - Electric - Jets (FS/W) 9 Mar 25, 2012 05:08 PM
Sold New Steel Fin OS MAX-III 15 R/C Crist Rigotti Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 20, 2012 08:09 PM
Sold JHH Mirage III/Kfir (LPU preferred) JurassicJet Aircraft - Electric - Jets (FS/W) 9 Feb 16, 2012 08:10 PM
For Sale Aussie buyers only Walkera RTF 4F200LM as new. andione1983 Aircraft - Electric - Helis (FS/W) 0 Feb 09, 2012 11:16 PM
