This thread is privately moderated by North_of_49, who may elect to delete unwanted replies.
Old Mar 23, 2012, 12:22 AM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Mini-HowTo
Blade mCX S300 servo replacement
I had to replace a sticking servo in my mCX S300 today. I don't have a precision tip for my soldering iron (EDIT: I have one now, yay!) so I didn't want to work on the board directly with my iron and shaky hands.
Solution: just snip the old servo's wires leaving the soldered ends still on the board, and solder the cut ends to the new servo's wires... easy as pie. Done
Description: Name: mcx-s300-servo-2.jpg
Description:
North_of_49 is offline Find More Posts by North_of_49
Old Mar 23, 2012, 08:52 PM
Edgeyakextra is offline
Find More Posts by Edgeyakextra
Epoxy, CA, or Duct tape?
Edgeyakextra's Avatar
Joined Feb 2012
Well done sir! I trust it works quite well just being soldered on the old wires, correct?
Edgeyakextra is offline Find More Posts by Edgeyakextra
Old Mar 23, 2012, 09:05 PM
Joined Dec 2011
Thanks...yup, it's fine!
Just use something to help hold the wires still while soldering so you don't get a cold solder joint... like a third hand (like the one in my photo)... or your brother-in-law... I used both
Oh, and using flux makes soldering small things a breeze, I didn't even apply the solder to the wires, I just applied it to the iron tip which is fine for jobs this small that will use next to no solder. And don't forget to put on your heat shrink before you solder your wires together. If you forget, you could brush on some liquid electrical tape (Brush-On Electrical Tape) You can shrink the tubing by putting your soldering iron against it... I usually use the side of the tip attachment.
EDIT: Be careful when stripping the cut ends of the wires coming off the board for soldering... if you're using wire strippers you don't want to tug the wires from the board so grab them with pliers first in your other hand
Old Oct 12, 2012, 12:39 AM
Jake8131 is online now
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
You could have saved yourself alot of grief but doing this the easy way....pop the motor out of the bad servo....pop the motor out of the good servo..take the bad servo and chuck it, keeping the white gears (they do get messed up).
Now, place the good servo by the 5n1...push the old motor into the new servo..install the new servo AFTER you clean the two strips (one black, the other white) with some alcohol on a Q-Tip..then remount the new servo on the 5n1 and check it out! If it works, you are done, if not, just change out the little motor, but, I have never yet seen the little motor go bad.
Jake8131 is online now Find More Posts by Jake8131
Old Oct 12, 2012, 01:23 AM
Joined Dec 2011
Hi, Jake.
Didn't know what part of the servo setup was causing my issue... couldn't be bothered troubleshooting it... just wanted to slap in a new one and be done with it
... and start flying it (bought it used)
Sold Blade mCX S300 Felginator Aircraft - Electric - Helis (FS/W) 3 Dec 15, 2011 07:00 AM
For Sale Blade mCX S300 Felginator Aircraft - Electric - Helis (FS/W) 2 Dec 07, 2011 09:17 AM
Discussion Blade mCX S300 RTF servo problem jackflash1991 Coaxial Helicopters 2 Dec 20, 2009 12:29 PM
Discussion Blade MCX S300 Servo Motor Runaway? RodHitchcock Coaxial Helicopters 6 Sep 17, 2009 02:58 PM
