This thread is privately moderated by Willsonman, who may elect to delete unwanted replies.
Old Mar 22, 2012, 04:01 PM
No Hangar Queens!
Maryland
Joined May 2009
Two maiden flights today...
Well, I knew the wind would be calm but overcast so I headed out this morning to get it done.
First up was the Windrider SBD Dauntless. I modified it to have split flaps and a dropping bomb. Flight went fine. I made sure to get up some peed before a gentle pull back of the stick. Needed some trim on roll but nothing major. Tried bottom flaps... some lift but not a wild amount. Top flaps... slows down wildlybut makes the tail control surfaces a bit mushy. I tried using both flaps... bottom then top. She started to roll unexpectedly and ailerons would not recover so I removed the top flaps and pulled out. I dropped the bomb and the magned system worked flawlessly. Though it took awhile to find a green bomb in green grass. The yellow stripe gave it away. Landing I made sure to keep the prop going to have speed over the tail. No flaps deployed but touched down nicely with no tendency to vary on its path.
Second up was the Goldberg Eagle2. Take off really required a lot of juice but once up I was at 1/2 throttle or less. Really a pussy cat and wonderful trainer. SHe had a very bad tendency to toll and maxed out my trim to get her to fly level. I'll be adjusting the ailerons mechanically to correct this. Needed to up trim as well but on power off she had a nearly level glide path right into the wind. I had to wave off my first landing attempt and had about 2" of runway left when I finally got her down. I also notice the roll rate was not fast at all so I upped the travel to 125% on my Tx. Took her back up and all was well. Really no bad habits and just a great afternoon lazy plane to fly.
Willsonman is offline Find More Posts by Willsonman
Discussion Alpha 40 maiden today stevolution Beginner Training Area (Fuel) 3 Mar 04, 2012 09:12 AM
Discussion Skywalker FPV maiden flight maybe today raRaRa Video Piloting (FPV/RPV) 3 Mar 03, 2012 08:19 AM
