Old Mar 22, 2012, 03:03 PM
rcta15 is offline
Find More Posts by rcta15
rcta15's Avatar
United Kingdom, England, Portsmouth
Joined Jan 2009
cg help needed on kfm glider build? motor question added
ok here is a 'not to scale' but all measurements are accurate representation (all be it very crude) of a glider i have built.
i am having a prob with the cg location, i have gone for the thickest part of the kfm wing and the i get the cg at 75mm from leading edge, but it just dont look right?
i have tryed the online cg locator gives me a cg location near the trailing edge??
can someone please advise if they can.
Many thanks in advance RCT
wingspan is 1603 not 1630 sorry my bad
rcta15 is offline Find More Posts by rcta15
Old Mar 22, 2012, 04:01 PM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
It looks like it's about 38% of wing chord which would be too far aft for me if I was setting up a plane. I likek to start at 25%, Now that's just me, and lots of guys like cg at 30% of chord. This all for a conventional type plane like yours. I don't know why the calculator might say otherwise. Generally with a KFM2 or 3 and the 50% top step, cg will be foreward of the step.
springer is offline Find More Posts by springer
Old Mar 22, 2012, 04:08 PM
Whiskers is offline
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
OK. Going by the old Rule of Thumb the testing CG should be at 25% of the wing cord, that is 30mm from the leading edge. The CG can then be moved back to around 1/3 of the cord to 65mm.
Or: Using a calculator I get testing at 33mm and final at 52mm.
That'll get you going.
Good luck with it all.
Hah! My bro got in first!
Whiskers is offline Find More Posts by Whiskers
Old Mar 22, 2012, 04:11 PM
rcta15 is offline
rcta15's Avatar
Joined Jan 2009
thanks to you both that has helped loads, now to get back to building.
RCT
P.s. its a kfm9 foil
P.P.S. made a mistake in the wingspan it should read 1603 not 1630.
Old Mar 22, 2012, 05:35 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Bingo-correct! Whiskers hit the CG on the head!
demondriver is offline Find More Posts by demondriver
Latest blog entry: RC Red Dwarf Starbug!
Old Mar 23, 2012, 06:28 AM
rcta15 is offline
rcta15's Avatar
Joined Jan 2009
which motor would be good for this glider?
now AUW so far is 900g ish so i was looking at either of these two motors what do you think?
http://www.giantcod.co.uk/epower-gt2...-p-405956.html because i need some extra weight up front, still might need say 40g extra on the nose i think.
or this one...
http://www.giantcod.co.uk/221720t-86...-p-402409.html but will need to add extra weight for this one.
i am leaning towards the first one but not to sure, will want to put a nice big folding prop on it as well.
can i please ask for everyones advice on this matter please?
many thanks RCT
Discussion Experiments with KFm airfoil on 'Elf' DLG glider JetPlaneFlyer Foamies (Scratchbuilt) 118 Jun 30, 2012 11:46 PM
Question Help with CG on Miss wind 50 Knysna4 F3A Pattern 2 Mar 21, 2012 02:25 PM
Discussion need help on cg for rotorshape djmd Auto Gyros 2 Dec 10, 2011 08:36 AM
Help! Need help on building a rc aircraft WildMaster Fuel Plane Talk 17 Sep 11, 2011 07:07 AM
