Old Mar 22, 2012, 10:49 AM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
What is the Minimum Input Voltage for a CC BEC Pro?
I was assuming that the input voltage has to be some value over the desired output voltage, but realized that the specs never directly say what that is.
More specifically, will a BEC Pro work off a 3s lipo (~ 12V)? I think it will, but thought I'd ask.
Thanks.
Alan Hahn is offline Find More Posts by Alan Hahn
Old Mar 22, 2012, 12:52 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
It probably depends on the output voltage that you want. Most regulators of this type require some voltage overhead to operate at the rated output. I would think that it would be safe as long as the input voltage stays about 3v higher than the output voltage. You will probably have to call CC Tech Support for more details.
RC Man is offline Find More Posts by RC Man
Old Mar 22, 2012, 02:41 PM
Chicago 'burbs
Joined May 2006
I plan to run 6V, so I am betting even a 2s lipo would be fine--like it is for the small CC BEC (they really need another more descriptive name for that one!).
It's just that I don't see that particular spec out there. On the BEC Pro itself, it has a decal with a table average current draws vs applied volts, but the lowest value is for a 4s (or 16V).
The actual application is a 6s Heli, where I have two 3s packs in series. Just want to run the BEC Pro off the lower pack (~12V). An added benefit should be a higher average current draw---not that I think I need >~15A continuous (16V value).
Discussion Looking to buy a 4ch rc helis what to buy any input from the pro's 67sam Electric Heli Talk 16 Dec 24, 2012 04:09 PM
Discussion CC BEC Pro or A123 pack? Frankensteen Electric Ducted Fan Jet Talk 2 Mar 20, 2012 08:08 AM
Sold CC BEC Pro jt182 Aircraft - Electric - Power Systems (FS/W) 4 Mar 09, 2012 05:52 AM
Sold NEW CC BEC PRO -- castle creations bec pro 20A 12S Switching Regulator aquaanox Aircraft - Electric - Power Systems (FS/W) 2 Dec 17, 2011 11:00 PM
For Sale Price Drop Align Trex 700 Flybarless Head only! CC Pro Bec & CC Field Program Card Lenny7118 Aircraft - Electric - Helis (FS/W) 3 Sep 14, 2011 02:52 AM
