Old May 21, 2012, 03:34 PM
Albany, CA
Originally Posted by Woodstock 1 View Post
Does anyone know what thickness (thinness?) servo is needed for the ailerons?
Woodstock, I used HXT900s which are 12mm thick. I stuck them to the servo covers with the double sided tape provided and did not use the clear spacer mounts. They just fit under the covering. So probably almost any ~9g size servo would work. I've used dozens of $3 HXT900s from HobbyKing, and only stripped one by inadvertently hitting the trainer switch and putting my Speedo1.2 straight into the ground from around 150 feet.
The servos mentioned by Cody and Rotozuk are thinner and probably better. I have been satisfied with both of those vendors too.
dylancoffin is offline Find More Posts by dylancoffin
Old May 21, 2012, 03:36 PM
Don't ask me anything...
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Thanks !
Those HXT900's have an amazing reputation, incredible considering the price..
Woodstock 1 is offline Find More Posts by Woodstock 1
Old May 21, 2012, 07:59 PM
FOKKER D8
cirros's Avatar
Espaņa, Comunidad de Madrid, Los Santos de la Humosa
Joined Mar 2011
Here I show the video of the first flight, my SPEEDO PRO 1.43, in Spanish skies, I hope you like it
NEW SPEEDO PRO 1.43 SLOPE GLIDER PRIMER VUELO (8 min 16 sec)
cirros is offline Find More Posts by cirros
Old May 30, 2012, 10:26 PM
Joined Jan 2005
Speedo 1.43
"Muroc'd" my Speedo 1.4 today. Found it nowhere near as acrobatically responsive as my modified Bobolink but still a lot of fun in a relaxing way. It is a very gentle flier and doesn't respond to French fudging upright but will when inverted. Showed no nasty stall habits, feels like a bigger glasser/floater type. It flies surprisingly well inverted especially considering its partial span ailerons which cannot provide full flapperon effect. It will produce a decent negative loop from a negative shallow dive. Spins much better inverted.
However, the wings bend frighteningly in both directions when g-loaded to any major degree and I don't know whether a catastrophic failure is the offing. As stock it has no provisions for ballast but I think loading it by any means would be fatal to the wings unless the weight were placed near the wing tips (which would do wonders for the already sluggish roll rate!).
Construction was fairly easy but I abandoned the included plastic servo mount rings & the grossly oversized servo covers & made my own simple balsa mounting bridges with servo faces flush with the wing underside. The spring & eye-bolt attempt at a wing lock turned out to be a subtle rendition of Chinese water torture so I glued the wings on with RC 560 canopy glue so that I can pull them off if I really need to stow this plane for extended travel.
All-in-all it's a good deal for the price & I try not to think of some poor devil chained in a ramshackle Chinese "factory" slaving away under pressure to crank out another toy plane for us "roundeyes". I hope it is good that he/she has some kind of job so I'll rationalize it that way.
CFIMEI is offline Find More Posts by CFIMEI
Old May 31, 2012, 12:12 AM
Entropy Happens!
Jim.Thompson's Avatar
Bellingen NSW Australia
Joined Aug 2008
Acrobat/aerobat confusion??
Originally Posted by CFIMEI View Post
"........... Found it nowhere near as acrobatically responsive as my modified Bobolink ....................
Do you have any pics of your "Bobolink? I would like to see some if possible.
And by the way, do you know why the word aerobatic has been replaced by the word acrobatic which describes the agility and skill of a gymnast? Well, at least in my dictionary it does.
Not meaning this to be personal, I've been waiting for a more general forum to come up in which to raise the subject.
I'm old and accordingly old fashioned. Such semantic liberties tend to grate on the (aging) sensibilities a bit......
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old May 31, 2012, 01:18 AM
Joined Jan 2005
Jim.
You're right, & if you look at any of my previous posts I use "aerobatic" too. Just a one-time etymological error. I'm old too.
First real sort-of-aerobatic plane that I used to fly was called "Citabria" which is "airbatic" spelled backwards.
There is a year-old fuzzy vid called "VTPR Wood Ranch Hill" somewhere on this forum with some Bobolink stuff but it was not a great day there & that plane can do a lot more than is shown. Got to get a new camera to mount on my bike helmet. Last one was left in Zurich Airport, found by a Swiss Air worker, sent to me via Lufthansa for pickup at LAX, then sent through my washing machine cloaked in a pair of blue jeans!
Found URL to old Bobolink vid:
Wood Ranch VTPR (3 min 38 sec)
Old May 31, 2012, 03:57 AM
Joined Dec 2005
I took delivery of mine yesterday. I was actually ordering a spare for my "classic" Speedo, but they ran out of my colour choice. Not wanting a dark fuselage, I decided to upgrade to the new boy on the block, hoping that it's performance won't be too far from it's smaller sibling. CFIMEI, do you have an original Speedo, and if so, any comparisons?
Old May 31, 2012, 10:00 AM
Joined Jan 2005
Speedo
No, I don't have the original type Speedo, any degree of dihedral is against my religion! Have only seen one at the local hill & it ended its flight with a broken wing from unintended contact with Earth. I suspect the larger version is slower but better inverted with its straight wing line.
BTW, since the 1.43 has an extremely narrow pointed nose & I wanted to use the least lead for CG I tried a new (for me) & oh-so-clever procedure to compact the required weight as far forward as possible: Pressed aluminum foil into the nose conforming to its shape, placed nose vertically in glass of crushed ice & water, melted lead fishing weight on outside barbecue burner in large spoon & poured it carefully into nose to prevent heat damage to fuse. Probably didn't need the foil but it may have helped with heat shielding. Final weight is 601.4g with TLAR CG. Flies well this way. Also added a small balsa tail sprit fairing below the rudder without which the rudder looks like an afterthought, ending square above/behind the curved fuse tail end in really ugly fashion.
Put almost 2 hours on it yesterday in moderate lift. Was originally concerned with vulnerability of wing covering to brush poking but it lands very easily & the leading edges take the shrub contact well. Be careful though with hand catches on the wings!
Old May 31, 2012, 11:56 AM
Albany, CA
CFIMEI, The original Speedo has no dihedral.
Woodstock, I would say the 1.4 is a good plane. The original is fabulous.
Despite the thinner wings, the 1.4 doesn't seem to fly as fast as the 1.2. I think the 1.2's RG15 is a better airfoil than the SD6062.
Old May 31, 2012, 12:29 PM
Joined Dec 2005
Thanks Mr. coffin!
Yup, no dihedral around there !
The Mk1 (by that I mean the rudderless 1.2m) is an astoundingly good plane. I say this from a perspective of being very privileged to own and fly a huge fleet of almost exclusively expensive, moulded gliders (I know, the wife says I'm a spoilt brat ) yet I love that Speedo! It's flying abilities in particularly difficult (gusty / flukey) conditions is astounding, and it's so tough that I use it as my "foamie" equivalent: in other words for testing out conditions, or trying new / suspect slopes, etc. It flies well in very light, thermal conditions, right through to very strong winds. It's a hard act to follow...
Old May 31, 2012, 12:30 PM
Joined Dec 2005
I notice the wings of the new Speedo are easy to flex in the hands !
Old May 31, 2012, 03:11 PM
Joined Jan 2005
Speedo 1.4 Wings
Check them out in flight. They act as if they're from a long-wing EPP ship! Not sure where the weakest point is as the curving is fairly evenly distributed.but until I develop a little more confidence in their integrity I'm going to limit high G stuff to in close so I don't have to go after the wreckage halfway down a brushy, rattler populated slope face.
Old May 31, 2012, 04:54 PM
Alphabets make great soup
Hamburglar's Avatar
Australia, ACT, Canberra
Joined Jul 2008
No S6062 is a great and proven foil. Your plane is probably too light for it to get 'on-step' and perform well. Try ballasting to 15-20oz/sqft wingloading.
Hamburglar is offline Find More Posts by Hamburglar
Old May 31, 2012, 05:02 PM
Joined Dec 2005
A bit of a Catch 22 here then. Structurally the plane doesn't seem up to ballasting...
Old May 31, 2012, 05:28 PM
Hamburglar's Avatar
Joined Jul 2008
It's a real pity. I wonder if they are planning on resurrecting the JART LX tooling (assuming they are the same crowd) and making a moulded wings for it.
Discussion New video : speedo fun jimbo320 Slope 19 Jun 06, 2012 03:44 PM
Wanted Xaircraft X450 Pro X450P standard package V2 version willyjoe73801 Aircraft - Electric - Multirotor (FS/W) 1 Mar 04, 2012 03:37 PM
Help! Speedo Pro Mark II battery selection etc.???? fabmaster911 Slope 2 Mar 01, 2012 10:48 AM
For Sale Brand New Speedo Kit Newer Version... orbitone Aircraft - Sailplanes (FS/W) 2 Dec 17, 2011 08:39 PM
Sold NIB Speedo - New Version w/ CF chip.greely Aircraft - Sailplanes (FS/W) 8 Nov 28, 2010 10:07 PM
