Old Apr 18, 2012, 01:52 PM
dylancoffin is offline
Find More Posts by dylancoffin
dylancoffin's Avatar
Albany, CA
You're right about Gorilla glue. I used about 4 times as much as I should have and had to keep scooping excess off as it expanded. You could definitely cause damage in a confined space. I've done it in noses before and do like making a very strong nose and a secure custom fitted hole for the battery. I f anyone wants to try it use only enough to wet the inside of the nose. It easily expands by a factor of 10.
Flew again yesterday in a bit more wind (12 mph) and despite the really thin wings the 1.4 doesn't seem as fast as the 1.2. I think it will benefit from ballast. The wings are pretty flexy so it should be interesting loaded up
Beware of hot or even warm cars with this plane! It was in the low 60s here and I left the windows open in my car at work, but I still got a twist in my fuse so the stab's not level anymore. I'll have to reheat it (possibly in the car) to straighten it out again.
dylancoffin is offline Find More Posts by dylancoffin
Old Apr 21, 2012, 07:00 PM
cirros is offline
Find More Posts by cirros
Pendiente - Madrid - Espaņa
cirros's Avatar
Joined Mar 2011
Revision 1.43 Speedo slope sailboat
Hello I show the review of my speedo, 1.43. new version
oh someone can help me with the reason for where to place the CG of the wing profile, this would be for medium to strong winds. thank you all ..
NUEVO SPEEDO 1.430 mm. VELEO DE LADERA. - REVISION (7 min 19 sec)
cirros is offline Find More Posts by cirros
Old Apr 22, 2012, 05:10 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Cool! Looking forward to the flight review !
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Apr 22, 2012, 08:55 AM
cirros is offline
cirros's Avatar
Joined Mar 2011
what you want friend, is what I'm looking forward too, but to reach that end. I need, is the data from which position the CG on the wing, for medium to strong winds. thanks for the support .......
Old Apr 22, 2012, 09:11 AM
tailsld is offline
Find More Posts by tailsld
United States, NY, Hamburg
Joined Aug 2011
Yes, documentation is a bit lacking. I was planning on starting at the center of the spar.
Rick
tailsld is offline Find More Posts by tailsld
Old Apr 22, 2012, 11:48 AM
Albany, CA
Cirros, Try 80 mm from the leading edge.
Old Apr 22, 2012, 03:58 PM
cirros is offline
cirros's Avatar
Joined Mar 2011
Dylancoffin. you are great, is just the data he needed. I appreciate immensely your support. many thanks. and will be easier to get to the flight time, and all thanks to you, and I imagine I'll have to do some testing, based on this data. greetings and thanks again .......
John .....
Old Apr 22, 2012, 05:40 PM
Greg Beshouri is offline
Find More Posts by Greg Beshouri
Cant fly enough
Greg Beshouri's Avatar
USA, CA, Berkeley
Joined Dec 2003
Originally Posted by Greg Beshouri View Post
I checked my Jart LT wing against my Buddy's new Speedo wing. They are certainly identical in planform, joiner location, etc. We did not check precisely but the profile also looks the same.
I will buy one for a spare set of LT wings.
If there are any Jart Lovers out there, here is a comparison of the wings:
Root profile and joiner and incidence pin locations all match the Jart wing exactly, The span and planform are almost identical with a slight difference near the tip.
Wing construction is much lighter with and does not have the full sheeting between the wing root and beginning of the aileron. The wing seems about as rigid in torsion. I still doubt the wing will not stand up to the abuse my original Jart Wings took. I may fully sheet it.
Greg
Greg Beshouri is offline Find More Posts by Greg Beshouri
Old Apr 22, 2012, 06:41 PM
cirros is offline
cirros's Avatar
Joined Mar 2011
almost is little difference between the two profiles, the GR 15 of 1.2 to 1.43 of the S6062
Old Apr 22, 2012, 06:43 PM
Cant fly enough
USA, CA, Berkeley
Joined Dec 2003
If that is indeed what each truly is.
Old Apr 22, 2012, 06:49 PM
cirros is offline
cirros's Avatar
Joined Mar 2011
this version does not support plan slowly, as with the 1.2
Old Apr 22, 2012, 06:53 PM
cirros is offline
cirros's Avatar
Joined Mar 2011
GREG, although this has nothing to do with this thread, and enough that you're from California, I can say, FREEDOM AR1 model, because I'm about, of enprender assembly from flat, I can say about this already legendary missile, thank you,
Old Apr 22, 2012, 07:25 PM
Cant fly enough
USA, CA, Berkeley
Joined Dec 2003
I apologize.
No offence was intended.
Old Apr 22, 2012, 09:02 PM
zbytekfr is offline
Find More Posts by zbytekfr
The Lone Sloper
USA, NY, Orchard Park
Joined Apr 2007
I may not go flying all the time, but when I do it's with my SPEEDO. Keep flying my friends
zbytekfr is offline Find More Posts by zbytekfr
Old Apr 22, 2012, 09:21 PM
tailsld is offline
Joined Aug 2011
Frank flies the heck out of his speedo. He is up flying when most of us are waiting for better conditions. This is why I bought one.
Discussion New video : speedo fun jimbo320 Slope 19 Jun 06, 2012 03:44 PM
Wanted Xaircraft X450 Pro X450P standard package V2 version willyjoe73801 Aircraft - Electric - Multirotor (FS/W) 1 Mar 04, 2012 03:37 PM
Help! Speedo Pro Mark II battery selection etc.???? fabmaster911 Slope 2 Mar 01, 2012 10:48 AM
For Sale Brand New Speedo Kit Newer Version... orbitone Aircraft - Sailplanes (FS/W) 2 Dec 17, 2011 08:39 PM
Sold NIB Speedo - New Version w/ CF chip.greely Aircraft - Sailplanes (FS/W) 8 Nov 28, 2010 10:07 PM
