Old Apr 05, 2012, 01:04 PM
fabmaster911 is offline
Find More Posts by fabmaster911
Clinton, Utah
Joined Apr 2008
Magnets may not be a bad idea. Will they hold though?
fabmaster911 is offline Find More Posts by fabmaster911
Old Apr 05, 2012, 01:22 PM
Woodstock 1 is online now
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Yup!
Woodstock 1 is online now Find More Posts by Woodstock 1
Old Apr 05, 2012, 01:37 PM
george@dream-flight is offline
Find More Posts by george@dream-flight
Wind Powered
george@dream-flight's Avatar
United States, CA, Goleta
I think that magnets (like the ones used on a Weasel for example) would do the job.
I guess you could cut some recesses in the root rib...and do the same on the fuse.....
george@dream-flight is offline Find More Posts by george@dream-flight
Old Apr 05, 2012, 01:46 PM
surfimp is offline
Find More Posts by surfimp
Piscine Promulgator
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
Yes: http://www.rcgroups.com/forums/showthread.php?t=392270
They are way more than good enough for what you need. Use neodymium "rare earth" magnets, something around 3/8"+/- in diameter and you should be totally golden.
Proof of their holding power: 2m Voltij that weighs ~1700g doing tons of snaprolls:
Voltij at the Ruins: Snaproll Fest (4 min 2 sec)
Steve
surfimp is offline Find More Posts by surfimp
Old Apr 05, 2012, 01:47 PM
surfimp is offline
Piscine Promulgator
surfimp's Avatar
Joined Feb 2003
With the caveat that the magnets as used on the Weasel aren't ideally oriented for wing retention. It's an easy mod though: http://www.stevelange.net/2010/05/01/weasel-evo/
Steve
Old Apr 05, 2012, 01:54 PM
Ginobli is offline
Find More Posts by Ginobli
Joined Mar 2008
flying stab?
anyone considering this? no idea how hard it would be to modify or if it would be worth it. mine is on the way and I am enjoying the premaiden modification discussions.
Ginobli is offline Find More Posts by Ginobli
Old Apr 06, 2012, 12:04 PM
DodgeRC is offline
Find More Posts by DodgeRC
Cable ties & ductape
DodgeRC's Avatar
United Kingdom, Wilmslow
Joined May 2011
Im very tempted to try the magnets out, from what ive heard they hold up!
Plus will have 2/3 spars to stop rotation.
My concern is, if they are that strong, can you still get the wing off?!
DodgeRC is offline Find More Posts by DodgeRC
Old Apr 06, 2012, 04:17 PM
jimbo320 is offline
Find More Posts by jimbo320
Slopeaholic
jimbo320's Avatar
Joined May 2011
Has anyone got a vid of the new speedo yet?
jimbo320 is offline Find More Posts by jimbo320
Old Apr 06, 2012, 08:10 PM
GR8FOLDED is offline
Find More Posts by GR8FOLDED
United States, CO, Boulder
Joined May 2011
Here's a few picks of my finished build. Went out for the maiden, but the wind decided to not cooperate this afternoon (wrong direction for all the local slopes) although it was 20 - 40mph. One thing that surprised me was how much lead this thing took to balance. I have it balanced close to 70mm. R2 Hobbies suggested 30-33% from the LE and Cody at Skip Miller suggested starting at 65mm.
You can see from the photos that I have a lead block at the front of the canopy opening on top of my battery. This is in addition to cramming as much weight as far forward as I could. I have the tip full of leadshot to maybe 1" back, then a 2/3 A 1500 Mah battery (3 cells horizontal with 1 vertical at the nose end) plus a decent amount of lead wire filling all the empty space above, below and to the sides of the battery. Haven't had a chance to weigh the thing yet, but I find it hard to believe that this will fly in 12km/h winds as R2's site says. I think the original will fly better in lighter winds. We'll see though... Tomorrow's wind speed and direction looks promising.
One last thing, the fuse is much thinner than the 1.2 Speedo and with the less than ideal landing zones here in Colorado I am thinking of possibly socking the front portion to at least the front of the canopy opening. At a minimum I think some fiberglass cloth and epoxy around the seam stretching back to the start of the canopy should help. This would allow me to take some lead out, but add to the durability.
Hopefully I'll have a report tomorrow and maybe some video...
GR8FOLDED is offline Find More Posts by GR8FOLDED
Old Apr 06, 2012, 08:33 PM
DodgeRC is offline
DodgeRC's Avatar
Joined May 2011
Am I right in thinking that this is the MK 3 'Lite' version? Not the fully moulded one?
Looks nice!! And cant wait for your review! the 1.2 would take off if someone farted but this one does look more chunky.
Also how do the elevator rods hold up? look slightly flimsy?
Old Apr 06, 2012, 09:04 PM
Joined May 2011
They seem up to task. It came with 2 fiberglass guide tubes for where the rods exit. I may glue them in, but this way provides way less resistance as far as I can see.
Old Apr 06, 2012, 09:13 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
That is my concern for the use of magnets for plug in wings on such mouldies as my MiniVector.
If using them, some provision for starting a small wedge might be necessary. Otherwise, damage could be done I expect.
I don't know as I have never tried them for retaining wings.
Jim.
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Apr 06, 2012, 10:06 PM
Stehl is offline
Find More Posts by Stehl
Bogan of distinction
Stehl's Avatar
Newcastle Australia
Joined Oct 2008
http://www.soaringusa.com/Wing-Tool.html
Wing tool
Stehl is offline Find More Posts by Stehl
Old Apr 06, 2012, 10:16 PM
Joined Aug 2008
Thanks Stehl. I will order a couple.
Old Apr 07, 2012, 01:54 AM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
I've been learning aerobatics with my 1.2 thermo. I have a bendy plastic joiner. I use a conservative amount of tape over just the LE and TE. On a heavy impact, no damage occurs, wings just separate from fuse and each other.. I love the old speedo mounting system. It takes harder abuse than some of my foam.
J.
Discussion New video : speedo fun jimbo320 Slope 19 Jun 06, 2012 03:44 PM
Wanted Xaircraft X450 Pro X450P standard package V2 version willyjoe73801 Aircraft - Electric - Multirotor (FS/W) 1 Mar 04, 2012 03:37 PM
Help! Speedo Pro Mark II battery selection etc.???? fabmaster911 Slope 2 Mar 01, 2012 10:48 AM
For Sale Brand New Speedo Kit Newer Version... orbitone Aircraft - Sailplanes (FS/W) 2 Dec 17, 2011 08:39 PM
Sold NIB Speedo - New Version w/ CF chip.greely Aircraft - Sailplanes (FS/W) 8 Nov 28, 2010 10:07 PM
