Old Jan 05, 2013, 11:46 PM
8thelephant is offline
Find More Posts by 8thelephant
Soaring Fanatic!
Joined Dec 2008
Slow wind Fuse CG?
Just have to ask since I've never had a "slow wind" glider before, would the CG be the same regardless of the extra fuselage length up front?
I've got mine at 75mm from the LE for now and awaiting time to maiden.
-8th
8thelephant is offline Find More Posts by 8thelephant
Old Jan 06, 2013, 11:12 AM
satinet is offline
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
the "slow wind" fuselage doesn't really make sense to me as it seems to have a shorter tail moment than the normal fuselage.
A short tail moment isn't a noted characteristics of models design to fly in thermals or light slope conditions.
If the distance between the tail and wing is shorter the CG will be further forward as you have less stabilisation from the stabiliser.
satinet is offline Find More Posts by satinet
Old Jan 06, 2013, 11:18 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Tom it's just about less nose weight needed.
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Jan 06, 2013, 11:23 AM
satinet is offline
F3B
satinet's Avatar
Joined Sep 2006
in the picture the tail moment looks a lot shorter, which will completely change the longitudinal stability.
does it come with a much bigger tail?
Old Jan 06, 2013, 04:26 PM
Soaring Fanatic!
Joined Dec 2008
I believe (hope) the concept of the Slow Wind Fuse is for less weight in the nose.
Nope, there were no included tail feathers with the fuse, so I used the stock stab and made a larger rudder.
I'll post my short build on this kit in another thread and link it here
Old Feb 19, 2013, 05:08 AM
Soaring Fanatic!
Joined Dec 2008
R2 Hobbies Speedo Pro Lite 1.4 w/ Slow Wind Fuselage Reviewed
OK folks, I've finally maidened and flown the SWF Speedo Pro Lite and made a review:
http://www.rcgroups.com/forums/showt...9#post24181303
Happy Soaring,
-8th
Old Mar 10, 2013, 02:07 PM
peterc is offline
Find More Posts by peterc
Edmonton,Alberta Canada
Joined Dec 2001
Guys thanks for a great, entertaining and informative thread on the Speedo Pro. I just received mine yesterday and am incorporating a few of the ideas thrashed about here. I've been flying a Discus DLG on the slope and it has worked well and I am hoping the Speedo will make everyone around here take note.
A few comments about the kit; beautiful fuselage but I'm not too impressed with the cutouts in the fuselage rear. I feel the servo mount/hatch covers are too heavy and crudely made (inside only). Moulded plastic would have done. The rudder really seems like an afterthought and should have been faired into the fuselage profile better. The instructions are minimal (non existant) but a few things like the CG and canopy hold down could have been illustrated.
Things like the wing attachment (the spring sucks) but I'm going to use an elastic band. I really look forward to flying it as soon as weather permits up here in the north.
Peter
peterc is offline Find More Posts by peterc
Old Mar 24, 2013, 03:08 PM
pipejax is offline
Find More Posts by pipejax
Soaring free outside the box
pipejax's Avatar
Canada, AB, Edmonton
Joined Mar 2007
Any thoughts on mods(flaps perhaps) to this glider or changes to the tail group.
pipejax is offline Find More Posts by pipejax
Old Mar 24, 2013, 04:12 PM
peterc is offline
Joined Dec 2001
Yet another use for an exercise bike. Good to see them being put to good use.
On my Discus DLG I mixed channels 1&6 to use as flaperons and put them on the 3 position switch on the transmitter. Now I have about 10 degrees of flap each way of centre so that when I'm inverted I can still have a cambered airfoil. The reflex also helps get it down in a hurry in our tight landing area. It should work on the Speedo.
Another building note: I used automotive Goop to hold the stab in place. It always remains a bit flexible when dry and sticks like you know what to a blanket. It also dosen't seem to mind a bit of a gap where the parts come together so it makes it easy to set the stab level.
Has anyone else noticed the slight twist in the fuselage?
Peter
Old Apr 17, 2013, 01:24 AM
CaptainHectorA is offline
Find More Posts by CaptainHectorA
CaptainHectorA's Avatar
United States, DE, Dover
Joined Feb 2013
Just finished mine...waiting for the wind to pickup....
CaptainHectorA is offline Find More Posts by CaptainHectorA
Old Apr 17, 2013, 04:06 AM
Gwalch is online now
Find More Posts by Gwalch
Gwalch's Avatar
Australia, VIC, Inverleigh
Joined Mar 2004
Lookin good!!
Good luck with the maiden!!!
Gwalch is online now Find More Posts by Gwalch
Old Apr 17, 2013, 04:40 AM
Joined Feb 2013
thanks))!!!
Old Apr 17, 2013, 04:47 AM
FWAL is online now
Find More Posts by FWAL
Flying without a licence
FWAL's Avatar
United Kingdom, Wales, The Mumbles
Joined Dec 2010
Although, after a first miserable Speedo III maiden I have found this glider to be pretty good. OK it's a little delicate and does have some flaws but what do you expect. It's CHEAP!!
I also enjoy carrying out the odd little tweak and mod here and there to these types of kits as they become more personnel. Here's a photo from yesterday the wind was 24mph and both planes were ripping. However, I snapped the wing joiner on the speedo whilst landing (not crashing)
FWAL is online now Find More Posts by FWAL
Old Apr 20, 2013, 05:18 AM
Joined Feb 2013
maiden....
Finally flew today..wind was not THAT great but enough...she flew nice..need to work out the flap/elevator mix but other than that she flew fine...I am looking forward to some stronger winds so I can do a bit of aero...
Old Apr 22, 2013, 03:09 AM
Gwalch's Avatar
Joined Mar 2004
Congrats on maiden!! I like the colours in that last pic.
Discussion New video : speedo fun jimbo320 Slope 19 Jun 06, 2012 03:44 PM
Wanted Xaircraft X450 Pro X450P standard package V2 version willyjoe73801 Aircraft - Electric - Multirotor (FS/W) 1 Mar 04, 2012 03:37 PM
Help! Speedo Pro Mark II battery selection etc.???? fabmaster911 Slope 2 Mar 01, 2012 10:48 AM
For Sale Brand New Speedo Kit Newer Version... orbitone Aircraft - Sailplanes (FS/W) 2 Dec 17, 2011 08:39 PM
Sold NIB Speedo - New Version w/ CF chip.greely Aircraft - Sailplanes (FS/W) 8 Nov 28, 2010 10:07 PM
