Hawaii
Joined Feb 2003
Finally some good footage from the HX9V
I was plagued with jello effect from the Sony HX9V. I think I finally got it under control:
Hawaii
Joined Feb 2003
http://www.vibrationmounts.com/Store...=Products7.htm http://www.gelmec.co.uk/GelmecSoftSi...lGrommets.html |
these are the ones I ordered. Should be here next week.
http://www.vibrationmounts.com/Store...=Products7.htm $10 a piece ![]() I only ordered 4 as that is what Askman's modified plates use.... they seem to work well, ill post results when i get them. ![]() although I do not have a HX9v I will throw my gopro on it as well as nex-5n the zeal tape gel is amazing and has completely isolated my CCD FPV camera from any vibrations, super simple to use and amazing stuff! http://www.hobbyhut.com/Zeal_Tape_Do...p/kyoz8006.htm |
you need really soft silicon gel grommet like ones seismic used. soft silicon foam may work, but most foam rubber is too springy to be a good isolator.
Latest blog entry: direct drive servo vs geared servo
Hawaii
Joined Feb 2003
You have a couple of issues with your current setup.
1) The foam may be isolating vibration but it really depends on the size of your hole where the bolt goes through. If the hole is not large enough the bolt may be touching and transmitter the vibration. 2) With only two attachment points plus isolation you get a lot of fore/aft movement. The HX9V has an in-camera image stabilization. If there is a lot of movement the image stabilization will not be able to cope and you wind up having jello effect. My suggestion is to make some sort of grommets by stacking foam rings with different diameters. Secondly try using softer materials like yoga pad. Thirdly you need to spread out the vibration isolation attachment points as far as possible to reduce unwanted movement. |
Thanks for your suggestions!
I tried, a different approach, last night to sandwich the motor arms with foam to isolate the arms from the frame. This worked pretty good as it sounds a bit quieter and I can't feel any vibrations on the frame. But - there was almost no improvement on the camera! Also, this prevents the folding mechanism of the arms so I will remove this. It is frustrating because compared to my other camera this one seems very sensitive! The hole in the plywood should be large enough so the nut will not touch the wood, but the gap is very small and could be larger. I will try to create three attachment points for the camera to reduce any possible fore/aft movement and maybe try to create a larger "membrane" of foam, like a x-large grommet to soften the mount. |
| Thread Tools | |
| Video Awesome on board footage from the SR-71 Blackbird!! | bighead93 | Electric Plane Talk | 2 | Apr 01, 2012 04:16 AM |
| Discussion SONY DCS-HX9V, is this a good camera for recording while FPV flying | jasper7821 | Aerial Photography | 4 | Mar 08, 2012 03:12 PM |
| Discussion Some great edited footage of norcal and surfing! | dhdsracer | Aerial Photography | 7 | Dec 30, 2011 10:55 AM |
| Discussion got some air to air footage of the Oakland U quad | 18t | Multirotor Talk | 0 | Sep 10, 2011 07:51 AM |
| Final respects from a nation (good read) | Dave Campbell | Life, The Universe, and Politics | 2 | May 02, 2004 06:42 PM |
