Old Mar 21, 2012, 03:57 PM
-james- is offline
Find More Posts by -james-
-james-'s Avatar
UK
Joined Sep 2008
Funcub power and flap problems
Hi guys,
I'm posting on behalf of my friend who has recently got into flying, he's a competent flier now and has moved onto a funcub from the wing he was training on. But the problem is that even at full throttle the motor does not seem to revolve fast enough to produce enough power. It takes off and you can circuit but it doesnt gain altitude as expected. The motor is rated at 220W, 1100kv approximately (can't remember off the top of my head) coupled to a 11x4.7 propeller and a 30A esc and 3s Lipo. I suggested a larger maybe 13 inch prop ?
Could he also need a higher C rating battery?
It's only a 1000mah atm, but will soon be replaced by a 2200mAH.
He is also having trouble with the flap servos, they arent digital but constantly buzz when turned on. They are both towerpro 9g HS55 clones that were working fine and do work fine when the aircraft is inverted :s
It's all very weird and I have no idea what is causing that?
Any help is appreciated,
James
-james- is offline Find More Posts by -james-
Old Mar 21, 2012, 06:17 PM
-james- is offline
-james-'s Avatar
UK
Joined Sep 2008
Actually, it's this motor:
http://www.giantcod.co.uk/xyh3530-11...-p-402740.html
It also has intermittent start up problems
Old Mar 22, 2012, 01:58 PM
-james- is offline
-james-'s Avatar
UK
Joined Sep 2008
Nevermind, turns out it was a faulty battery after trying it with a different one. Also the flaps just had a problem with the kinkage going past neutral too far on the down throw and therefore when it tried to return to no flaps it was just pushing it further down thus creating the problem
James
Discussion Discus CS Flying Dream flaps problem steveski74 Scale Sailplanes 1 Jan 10, 2012 02:16 AM
For Sale Parkzone P-47 BNF w/ Power 25, flaps, 60amp esc. tankbuster Aircraft - Electric - Airplanes (FS/W) 8 Dec 13, 2011 07:03 PM
Question F-22 Raptor Flap Servo Problem banzi28 Beginner Training Area (Fuel) 8 Oct 26, 2011 11:37 AM
Discussion Basic DX6i flap set up problem RC Erik Radios 8 Oct 19, 2011 01:00 PM
