This thread is privately moderated by vic gensberg, who may elect to delete unwanted replies.
Old Mar 21, 2012, 02:39 PM
vic gensberg is offline
Find More Posts by vic gensberg
Trader Rating: 33
United States, AZ, Tucson
Joined Dec 2008
Trader Rating: 33
Sold
great planes laser incidence meter 30.00 shipped
I just checked the laser and it turned on
This is the AccuPoint Laser Incidence Meter from Great Planes.
This High Precision Tool is used to find Accurate Angle Alignments on
Airplane Wings, Stabilizers or Engine Mounts.
If laser unit is not pointing toward the scale or if batteries need
changing the unit can easily be removed from the yoke and
reinstalled.
FEATURES: Integrated use of laser beam pointer is much more precise and
trustworthy than the weighted pointers and bubble levels found in
other meters giving modelers pinpoint accuracy.
The laser unit rests in a ball bearing-supported yoke that eliminates
binding and adds to the meter's precision.
The big scale is easy to read from any angle, and measures incidence
down to 1/4 of a degree. Reads 0-10 positive and negative.
The grippers on the clamps are perfectly aligned to stay true over
time, and the opposed, large-radius thumb screws are easy to
access and use.
It is designed to be set on a flat surface to "zero it out" with a
knurled adjustment thumb wheel before use.
Special notch at the bottom of the scale allows attachment to
an engine crankshaft for checking the engine's thrust angle.
Fits wing chords up to 16"
Accommodates wider wings with an optional 36" long aluminum bar
INCLUDES: One Laser Pointer with Yoke Assembly
One Magenta Red Aluminum Bar
One Incidence Meter Scale/Engine Thrust Mount
Two Clamping Jigs with Thumb Screws
REQUIRES: Assembling the Laser Incidence Meter
SPECS: Bar Length Overall: 20"
Length Between Clamping Jigs: 16-1/4"
Scale Height: 8"
The AccuPoint can be used to check:
The wing at the root and tip, for warping.
The stabilizer is aligned with the wing (thrust line).
The wing and stabilizer are both level.
The engine's thrust line.
The fuselage is level.
Helicopter blade pitch
vic gensberg is offline Find More Posts by vic gensberg
Old Mar 22, 2012, 09:00 AM
scigs30 is online now
Find More Posts by scigs30
Trader Rating: 8
Joined May 2005
Trader Rating: 8
pm sent
scigs30 is online now Find More Posts by scigs30
Sold Great Planes Triton Green Dot Charger $30 shipped jeff489 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 16, 2012 07:58 PM
Sold Laser incidence Meter Clavin01 Aircraft - General - Miscellaneous (FS/W) 1 Feb 28, 2012 09:01 PM
Sold SOLD - Cemech Reflex EPP 3D Foam Plane Kit - $30.00 Shipped and Insured. GTMAXX Aircraft - Electric - Airplanes (FS/W) 3 Feb 28, 2012 06:13 PM
For Sale 2 Accupoint Laser incidence Meters rctc Aircraft - General - Miscellaneous (FS/W) 3 Feb 05, 2012 11:43 AM
Sold Accupoint Incidence meter $40.00 shipped primestick Aircraft - General - Miscellaneous (FS/W) 1 Jan 22, 2012 11:12 PM
