Old Mar 21, 2012, 11:31 AM
tdogg77 is offline
Find More Posts by tdogg77
Joined Dec 2006
Stinger 64 - Maiden - First EDF Flight
I flew my Stinger 64 for the first time today at lunch - this was also my first EDF flight. All I can say is WOW!
The hand launch went really well - I used an overhand toss with my right hand and tossed at about 45 degrees high. I had plenty of time to get back on the controls. It only needed one click right aileron and two clicks up elevator to be rock solid in the air.
I was apprehensive about flying an EDF but it was no more difficult than my T-28, just faster. Also on landing I flared at about 3 feet off the deck, and then lost elevator control sooner than expected so the nose was a little lower than I would have liked it on touchdown.Thankfully there was no damage.
I did find the stock ESC to be very hot after the flight, which was about 10% full throttle and mostly around 75%. I may look into mounting the heat sink in the intake somehow. If anyone has a suggestion I'd love to hear it.
tdogg77 is offline Find More Posts by tdogg77
Old Mar 21, 2012, 06:08 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Glad u had fun
You ll probably get a better response here..http://www.rcgroups.com/forums/showthread.php?t=1445001
vettster is offline Find More Posts by vettster
Old Mar 21, 2012, 06:54 PM
NCRealEstateGuy is offline
Find More Posts by NCRealEstateGuy
I Used To Have More Free Time!
Charlotte, NC
Joined Feb 2011
This plane was my first EDF too. I probably have 15 flights on it now. My ESC got hot until I moved it further back near the slits back in the duct work. It now stays cool. If you belly land, keep the nose up right before touch down, ot it has a tendency to dig the nose into the ground.
NCRealEstateGuy is offline Find More Posts by NCRealEstateGuy
Old Mar 22, 2012, 12:00 PM
tdogg77 is offline
Joined Dec 2006
I flew it again with a 2200 pack and this time the elevator was dangerously ineffective. I had been using 1oz of weight in the nose to balance at the factory point, but I think the CG should actually be farther aft, so I went down to 3/4oz in the nose. Now it has a lot more elevator control. Still when coming in for a landing you need to be a little nose-high because elevator control dries up quick.
Old Mar 22, 2012, 03:36 PM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
Fantastic plane, with the stock components and a 3S 2.2 AH pack there is NO nose weight needed! Even with the smaller 1,800 pack it doesn't need any nose weight.
Chris True is offline Find More Posts by Chris True
Old Mar 23, 2012, 06:05 AM
Charlotte, NC
Joined Feb 2011
I fly the 2200 pack too with no wieght.
Sold steroid powered stinger 64 jet kremecheze Aircraft - Electric - Jets (FS/W) 6 Feb 26, 2012 08:25 PM
Wanted Hobbyking Stinger 64 EDF Sport Jet FlyWW1 Aircraft - Electric - Airplanes (FS/W) 0 Dec 03, 2011 09:01 AM
Wanted Hobbyking Stinger 64 EDF Sport Jet FlyWW1 Aircraft - Electric - Jets (FS/W) 0 Dec 03, 2011 08:59 AM
Discussion First EDF flight (maiden for me and my plane) Stef stuntpiloot Foamy EDFs 11 Nov 18, 2011 09:46 PM
Video Stinger 64 Edf Jet Hobbyking Anda Inc. Electric Plane Talk 0 Sep 19, 2011 03:44 PM
