Old Mar 21, 2012, 04:51 AM
widget2k4 is offline
Find More Posts by widget2k4
Joined Mar 2012
blade mcpx multi charge lead anyone ?
hi,
does anyone know or have a link to a lead that will allow me to charge more than 1 blade mcpx battery at once using the standard charger?
i can only find posts with leads for a balance charger and not the stock one
thanks
widget2k4 is offline Find More Posts by widget2k4
Old Mar 21, 2012, 09:31 AM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
http://www.rcgroups.com/forums/showthread.php?t=1357720
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Mar 21, 2012, 11:13 AM
Joined Mar 2012
thanks for the link but there's nothing on there pointing towards a lead for the standard charger ?
Old Mar 21, 2012, 12:05 PM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
Did you look at post #2? Or am I misunderstanding your question?
mw
Old Mar 21, 2012, 12:20 PM
Dave H. is offline
Find More Posts by Dave H.
Joined Feb 2008
I don't think the OP means "standard" charger - I think he means the little charger that comes with the MCPX, so you might need to solder that onto the MCPX connector that came with the MCPX. No biggier there.
Do keep in mind though that the adaptor shown in post #2 doesn't actually fit MCPX batteries. The MCPX uses the "high current" micro connector.
I got some of the Eflite MCPX/high-current to parkzone micro connectors (you get one of these with the MCPX) and soldered them together. You could terminate this in a plug that goes into the MCPX charger, but I don't see the point really. They already tell you to set that charger to max to charge one battery at a time. It would be better to get a normal/generic charger that could charge them all quickly.
Dave H. is offline Find More Posts by Dave H.
Old Mar 21, 2012, 02:24 PM
Joined Mar 2012
I don't really care about the time it takes to charge its more of less hassle having to keep swapping batteries over every 15 mins, so if it took an hour to charge 4 batteries that would do, where could I get the connectors from ?
Old Mar 21, 2012, 03:51 PM
Joined Mar 2012
ok, i have just bought one of these
http://www.ebay.co.uk/itm/3505398075...84.m1497.l2649
can i just chop the jst end off and solder the one off the mcpx lead onto it ?
Old Mar 21, 2012, 04:48 PM
Dave H. is offline
Joined Feb 2008
That should work.
Old Mar 22, 2012, 02:48 AM
Joined Mar 2012
cool thanks
Old Mar 22, 2012, 01:04 PM
ror1 is offline
Find More Posts by ror1
FPV'r
ror1's Avatar
Canada, ON, Carleton Place
Joined May 2011
http://www.hobbyking.com/hobbyking/s...g_Harness.html
ror1 is offline Find More Posts by ror1
For Sale Blade mCP X 6X Parallel Charge Lead motorbro1470 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 26, 2012 09:51 PM
For Sale Blade mCP X 6X Parallel Charge Lead motorbro1470 Aircraft - Electric - Helis (FS/W) 1 Feb 26, 2012 09:49 PM
For Sale Multi Charge Harness over 18 popular connectors for charging!! taildragger21 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 23, 2012 09:44 AM
For Sale Blade mCP X 6X Parallel Charge Lead motorbro1470 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 21, 2012 08:13 PM
Question How to reduce the charging rate of a USB charging lead? eyemdee Batteries and Chargers 5 Sep 14, 2011 07:34 AM
