http://rc-castle.com/shop/product_in...oducts_id=1448 |
FW-190 thoughts
Fellow owners and lurkers,
I guess it is time I gave you my thoughts on this model. Since I only buy kits, I cannot speak of the equipment that comes with the model with the exception of the retract units. Which, if you have not heard already, have quite a few issues. I was NOT immune, but more disturbingly, I also don’t have any real answers. More about this later. Let’s start with fidelity of scale. I compared to the subject model to drawings that I cross-referenced with all my available data. Overall, the model is about an 8 out of 10 for scale of accuracy. The wing is very close to the correct shape but as usual, the aileron is too big and the flaps too small. The inboard LE extension is also not pronounced enough. The landing gear is positioned correctly and about the right length. The dihedral is very close also. The fuselage is the overall correct length, but has been cheated in the nose presumably to get the model to balance easier. The height and width are very good. The vertical/rudder tail is quite a bit oversize, but the proportions are very close. I don’t agree that it is warranted in this model. The horizontal tail is also a bit oversize in both span and chord, again, presumably for flying qualities of which I can agree. The full scale aircraft had a fairly low TVC (tail volume coefficient). This would make the model sensitive in pitch, even with a fairly far fwd CG. (note: the Flyzone (ST Models) smaller FW-190 horizontal tail is HUGELY oversized!) As some have mentioned the outboard cannon muzzles are too long for this FW-190-A8/R2. Besides the tailwheel not being retractable on the model (not easy to do since it went almost straight up!) the tailwheel is a bit small. Overall the main markings are very good assuming that you believe the “8” was red. (many sources claim it was black as well as showing the spinner red/yellow), but the German writing (stencils) found on the model are way too oversized and detract from the look of the model. The bomb/tank rack is missing the longitudinal rails between the fore and aft sway braces. That’s about it for this part. Look for more soon. Tom
For all die hard Futaba fans...we have the Rolls Royce of clone from Hobby King,..but the question remains..will it work with the retracts...
Joined Aug 2011
Strange as probably both are made by FrSky. |
| Thread Tools | |
| Discussion FMS FW-190 800mm range | flyball | Electric Warbirds | 124 | May 02, 2013 01:28 PM |
| Discussion fms warbird owners thread | warbird_cowboy | Electric Warbirds | 115 | Mar 05, 2013 05:09 AM |
| Discussion FW 190 1400mm by FlyFly ...wow it's NOT FMS! | jbc | Electric Warbirds | 117 | Feb 20, 2013 11:15 AM |
| New Product FMS 1400mm FW-190 Part II | Tommy D | Electric Warbirds | 647 | Jul 26, 2012 03:23 PM |
| Video Formation Flying - FMS Stuka, Hobbico FW-190, Velocity-RC T-33s, and Tsunamis | bwoollia | Electric Plane Talk | 0 | Oct 23, 2011 02:45 PM |
