Old Mar 20, 2012, 07:13 PM
TMAC4123 is offline
Find More Posts by TMAC4123
God is Good
TMAC4123's Avatar
United States, MI, Grand Rapids
Joined Jan 2011
Question
50cc equivelent electric motors?
Hey guys im looking for a electric motor thats the same size as a 50cc motor, meaning same power. Thanks!
TMAC4123 is offline Find More Posts by TMAC4123
Old Mar 20, 2012, 07:19 PM
fu-corsair is offline
Find More Posts by fu-corsair
fu-corsair's Avatar
Canada, NB, Southfield
Joined Mar 2008
Looking to buy or what to buy?
fu-corsair is offline Find More Posts by fu-corsair
Old Mar 20, 2012, 07:23 PM
fu-corsair's Avatar
Joined Mar 2008
The list is a long one, my favorites are Hacker A80's or A60L then there are the new Axi 5345HD's and my ultimate favorite the Plettenberg Terminator 30-8. NEU are also good choices.
Old Mar 20, 2012, 07:26 PM
imyohero is offline
Find More Posts by imyohero
F-OFF
imyohero's Avatar
Joined Mar 2007
cc doesnt =hp output, how many hp from a 50cc size/weight motor do you need the elec counterpart to match or exceed?
imyohero is offline Find More Posts by imyohero
Old Mar 20, 2012, 07:27 PM
TMAC4123 is offline
God is Good
TMAC4123's Avatar
Joined Jan 2011
I need a motor that will fit in a 72" EDGE. what should i use?
Old Mar 20, 2012, 07:28 PM
fu-corsair's Avatar
Joined Mar 2008
I don't know about the calculations but most of the motors listed below will out perform any 50cc size gas motor.
Old Mar 20, 2012, 07:39 PM
fu-corsair's Avatar
Joined Mar 2008
Who makes your Edge and 72" isn't 50cc size
Old Mar 20, 2012, 07:46 PM
fu-corsair's Avatar
Joined Mar 2008
I'd use either the Hacker A60 or the NEU 1515G HD
Old Mar 21, 2012, 07:37 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Forget number of cc's, airplane weight is the key factor.
* Choosing a power setup
Magic numbers for modelers... - WFF
How to choose a power system - RCG
Beginners Guide to Motor and Prop Selection - RCG
* About de-rating!!! controllers and motors, starting at 'for everyone else':
Scorpion Motors: Questions and Answers.... - Page 290 - RC Groups
http://www.theampeer.org/sitetoc.html
-> Glow to Electric Power System Conversion
Two follow ups to the above by Ken Myers:
http://www.theampeer.org/ampeer/ampn...nov11.htm#GLOW
http://www.theampeer.org/ampeer/ampd...ec11.htm#SHEET
Vriendelijke groeten Ron
diy motor tipsDrive Calculator
diy motor groupCumulus MFC
• Get a life ... get a Watt-meter! •
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Mar 21, 2012, 10:40 AM
fu-corsair's Avatar
Joined Mar 2008
diy motor tips Drive Calculator
diy motor group Cumulus MFC
Get a life, get a Watt-meter!
Thanks Ron, I now have this copied forever.
Old Mar 21, 2012, 10:59 AM
Joined Feb 2001
And then there's the calculators:
http://rcadvisor.com/
http://flbeagle.rchomepage.com
www.drivecalc.de (Eng/German, Win/Lin/Mac)
and Louis Fourdan's ScorpionCalc
http://www.rcgroups.com/forums/showthread.php?t=736782
More e-flight calculators in the sticky in this subforum.
However, keep this in mind, as with all software: garbage in, garbage out.
Don't expect a good result by blindly entering numbers. And even good result is just a ball park figure.
• Get a life ... get a Watt-meter!!! •
Old Mar 21, 2012, 11:32 AM
dirtyballs is offline
Find More Posts by dirtyballs
Bart
Netherlands
Joined Oct 2010
Don't go for super strength, go for super light
Here my setup for a 78" Sbart SU 29S, final weight including Lipo < 4 kg that is ~ 1.2 kg or more lighter then almost all the other planes in this size.
- Hyperion HS4035-400Kv ( 435 gram)
- Jeti spin opto 99
- Gens ACE 6s 5300 mAh 30C
- Xoar 20x9 PJN ( use a prop adapter from scorpion 8mm shaft of the hyperion )
- 4 x HS7950TH
- CC BEC pro at 7.5 Volt
it runs now on 12 degrees timing and it puls max 115A, engine and ESC are cool after flight.
Bart,
dirtyballs is offline Find More Posts by dirtyballs
Old Mar 21, 2012, 12:36 PM
buracho topspin is offline
Find More Posts by buracho topspin
Joined Feb 2012
Here is a (claimed) 50cc outrunner:
http://www.hobbyking.com/hobbyking/s...ner_Motor.html
To me the problem is not the motor as much as batteries. The batteries are heavy and you can only get short flight times without a huge weight increase.
When you get to this size model gasoline or glow engines become a more attractive power source. Gasoline/glow fuel has more energy for a given volume than the batteries needed to fly. You have lower fuel weight/volume and much longer flight time with gasoline or glow fuel. That equals a lighter plane with more power.
buracho topspin is offline Find More Posts by buracho topspin
Reply With Quote  (Disabled)
Old Mar 21, 2012, 12:56 PM
fu-corsair's Avatar
Joined Mar 2008
- Jeti spin opto 99
- 4 x HS7950TH
Bart,
I agree Bart, less weight is the ticket to a nice flying electric.
Old Mar 21, 2012, 04:17 PM
imyohero is offline
F-OFF
imyohero's Avatar
Joined Mar 2007
Lots of good info guys!
I just dislike seeing the cc of a gasser displayed like it has everything to do with power output, it doesnt, its just part of it.
Good luck on your plane hope you get it flying the way you want!
For Sale Electric Motors, Servos, ESCs, Batteries Sailor Jerry Non R/C Items (FS/W) 34 Apr 04, 2012 08:10 PM
Discussion Converting 30 to 50cc size to Electric bleary 3D Flying 12 Nov 15, 2011 08:57 PM
Wanted Electric brusless motor equiv to 50cc rhampton Aircraft - Electric - Power Systems (FS/W) 4 Sep 12, 2011 10:28 PM
Discussion 50cc Giles to electric first big electric roboto65 Glow to Electric Conversions 14 Jun 29, 2009 08:28 AM
Question Electric equivelent for a Cox 049 DrRishi Glow to Electric Conversions 5 Jun 16, 2009 03:01 PM
