Old Mar 20, 2012, 04:44 PM
netdudeuk is offline
Find More Posts by netdudeuk
England
Joined Nov 2005
Flight pack voltage too high for DS821s and TM1000 ?
Hi
I'm using a five cell Eneloop pack in my Toledo Special with Spektrum DS821 servos, an AR8000 and a TM1000.
I've low charge rate topped up the pack for a couple of hours.
The DX8 is now showing that the flight pack voltage is at 7.2 volts. Is this too much for the servos and the TM1000 ?
netdudeuk is offline Find More Posts by netdudeuk
Old Mar 20, 2012, 05:15 PM
Telrin is offline
Find More Posts by Telrin
Dallas, TX
Joined Jan 2010
The servos (and everything else) are rated for use with a 5 cell pack.
Your voltage will not hold that high once it is under load.
Telrin is offline Find More Posts by Telrin
Old Mar 20, 2012, 05:54 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
The AR8000 and TM1000 work just fine up to 9.6V I think. Check the specs, but it handles 2S LiPo easy.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Mar 21, 2012, 06:32 AM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
The ENELOOP cells are really not a good choice as rx pack.
They are excellent tx cells .
The chemistry of the ENELOOP , offers extended shelf life and very good low load performance .
You really should be looking at cells which will provide power under under heavy loads.
As a rule, AA cells in NIMH do not have the same discharge abilities to withstand loads as compared to the 'short ,fatter cells .
Check with local suppliers who offer cells made for rc cars . There are a number of HD cells available which are better suited to rx pack use.
The batteries you select can make or break your 2.4 system.
richard hanson is offline Find More Posts by richard hanson
Old Mar 21, 2012, 01:59 PM
England
Joined Nov 2005
Thanks for the replies.
The pack is sold as an RX pack.
http://www.overlander.co.uk/batterie...h-rx-flat.html
Flying today, the voltage was recorded at a minimum of 5.8 volts.
Old Mar 21, 2012, 02:52 PM
Joined Oct 2007
That is a surprise ,as the specs on those cells showed fairly high impedance -
see if you can contact battery suppliers who have tested these in high drain conditions
The recorded voltage means nothing -I probably have 3 dozen ENELOOPS of newest types and they work extremely well in low load applications -
It's the instant high loads that will cause a problem. They have an internal resistance of 25-27 milliohms
THAT IS TOO HIGH!
If you would go to their site and read the voltage depression on loads you would se that they are NOT rx type cells -
IFyou have only very low loads on your servos -you may be OK -but they are simply not intended for this purpose
go the Hangtimes site and read up on cells .
Old Mar 21, 2012, 08:43 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
I can also confirm that Eneloops and any other LSD NiMH cells are not good as receiver packs unless they power only the receiver and not the servos. I lost a plane to that. The LSD cells have a high impedance and quickly lose voltage when constantly loaded with higher amps.
ivanc is offline Find More Posts by ivanc
Discussion High voltage servos, such as Hitec's do they work with 4.8V-6V voltage? liukku Radios 9 Mar 26, 2012 12:35 PM
For Sale 12S High Voltage & High Power Setup For 600 Size Heli helinut4ever Aircraft - Electric - Helis (FS/W) 0 Dec 31, 2011 09:00 AM
For Sale High-end 600 or 50 size Heli flight pack justin4u Aircraft - Electric - Helis (FS/W) 3 Dec 14, 2011 09:30 AM
For Sale High-end 600 or 50 size Heli flight pack justin4u Aircraft - Fuel - Helis (FS/W) 0 Dec 06, 2011 09:32 AM
For Sale AR7000, DS821s, and 1100mah flight pack. billyzelsnack Aircraft - General - Radio Equipment (FS/W) 5 Dec 17, 2006 05:16 PM
