Old Mar 20, 2012, 03:13 PM
SevenDays is offline
Find More Posts by SevenDays
Joined Dec 2011
Is my itg3205 from WM+ bad?
I tried to connect itg3205 directly to STM32 board, but with no success.
The yellow wire is SCL, orange is SDA, green - GND, black - +3.3v.
In the code I have included ITG3205. In this I2C line I have connected successfully ADXL345.
SevenDays is offline Find More Posts by SevenDays
Old Mar 22, 2012, 01:03 AM
caotri is offline
Find More Posts by caotri
Hochiminh City
Joined Mar 2004
The SDA and SCL you can get it from the other end of 202 register where you connect the Vcc
caotri is offline Find More Posts by caotri
Old Apr 29, 2012, 03:05 PM
markusb2 is offline
Find More Posts by markusb2
Kalmar, Sweden
Joined Apr 2009
Did you get the ADXL to work in parallell with ITG3205 or as standalone?
Check the datasheet and make sure you did not cut away any gnd or power tracks to ITG3205.
markusb2 is offline Find More Posts by markusb2
Old Apr 29, 2012, 04:55 PM
darec is offline
Find More Posts by darec
Polska, dolnośląskie, Wrocław
Joined Aug 2008
please also check continuity of SDA and SCL lines connecting pullups resistors....if you have just one resistor connected then you may have a problem....all depending on if you have any other pullups active in your lines
NB i like your small board but would cut it more straight :-) with dremel or something
darec is offline Find More Posts by darec
Discussion HK going from bad to worse mike_o HobbyKing 12 May 26, 2012 04:00 PM
Careful! Very poor and bad Service from Castle Creation - my case !! marknopfler Castle Creations 5 Mar 17, 2012 01:25 AM
Discussion my mustang 60 size by WM cannot do a quick loop mahmoodmusaddi Fuel Warbirds 42 Mar 15, 2012 09:29 AM
I just "ordered" my Christmas gift from my wife. Should I feel bad? Jeremy Z Electric Plane Talk 28 Dec 04, 2005 08:58 AM
