Old Mar 20, 2012, 01:32 AM
AzTrekie is offline
Find More Posts by AzTrekie
Doing Projects Differently
AzTrekie's Avatar
Joined Jan 2012
what size brushed motors are these
I want to use motors from a Double Horse (SYMA) Super Sonic RC airplane but need to know what size the brushed motors are.
Will a Playmate ESC be able to run both motors and servos even though the motors are designed to run on 4.8 volt and the playmate runs on a 3.7 volt
Please let me know if this will work or do just test it out to see if it will?
Dave
AzTrekie is offline Find More Posts by AzTrekie
Old Mar 20, 2012, 04:09 PM
AzTrekie is offline
AzTrekie's Avatar
Joined Jan 2012
More info on the motors
The markings on the motors are as follows
OT-9399
11-03-22
need to know the size and volt rating etc.
Dave
Old Mar 20, 2012, 06:24 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Measure the diameter and length of the motor can, it will help to identify it. Also, what was the battery pack it was used with? That will tell you a lot about the voltage.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Mar 20, 2012, 08:56 PM
AzTrekie is offline
AzTrekie's Avatar
Joined Jan 2012
Motor measurments
Jack
NOTE the can is not round it is oblong at the widest diameter 1/2inches or 9.5250mm
motor can 3/8 inches x 1/2 inches or 9.5250 millimeters x 12.7000 millimeters driven by 4.8 volt ni cad battery
This plane has two of these motors
Question:
Can a 3.7 lipo operate the planes two motors designed for this 4.8 nicad with the actual ESC that came out of the plane with the 3.7lipo that was designed operate one motor can this set up operate the two motors correctly?
Dave
Old Mar 20, 2012, 10:03 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Really? is that one of those horrid twin engine chinese crap toys where the motor thrust gives(alegedly ;-) direction control?
IF so.. just put it directly into your trash bin..Now! Save yourself some aggro.
Bare is offline Find More Posts by Bare
Old Mar 30, 2012, 03:05 PM
AzTrekie is offline
AzTrekie's Avatar
Joined Jan 2012
Want to know how much thrust these motors have
I Want to know how much thrust each of these motors have approximately or how fugue it out with a formula
NOTE:
motor can 3/8 inches x 1/2 inches or 9.5250 millimeters x 12.7000 millimeters driven by 4.8 volt 4s nicad battery pack
Thanks Dave
Old Mar 30, 2012, 03:20 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Motors do no have thrust, propellers do.
And when a propeller is turning at a given RPM it produces the same thrust with any motor. Which motor makes no difference.
So guess what we need to know?
Jack
Old Mar 30, 2012, 05:15 PM
AzTrekie is offline
AzTrekie's Avatar
Joined Jan 2012
Jack
I have two different size one 4 1/2 in and the other 2 3/4 in props
the plane came with the 2.75 in props but the 4.5 fit the motor shaft also
Dave
Old Mar 30, 2012, 07:20 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Is there a second number on the props too? To look them up you would need a diameter and a pitch.
I looked here in the flybrushless.com prop database and that are no 2.75 inch props, there is a 3 x 3, you can see that here:
GWS HD 3x3 - http://www.flybrushless.com/prop/view/4
You can browse the Find a Prop list there for 4.5" props too, as you can see you need to have an idea as to the RPM in order to get the thrust for a particular setup.
The systems like the one you have there don't really lend themselves to figuring these kinds of things out. I can understand your interest in trying to get some use out of it though.
Good luck with it!
Jack
Discussion Looking for landing gear for Flame Wheel F550, these are kinda like what I'm looking jasper7821 Multirotor Talk 1 Oct 23, 2012 09:30 AM
Discussion What are these models? No Step Slope 7 Mar 15, 2012 10:18 AM
Wanted Looking for landing gear for Flame Wheel F550, these are kinda like what I'm looking jasper7821 Aircraft - Electric - Multirotor (FS/W) 1 Mar 06, 2012 05:28 PM
Discussion ~100W 2s motor, what motors are efficient these days? saitrix Power Systems 0 Feb 27, 2012 01:13 AM
Help! What's with these brushed motors?? microflitedude Trader Talk 4 Apr 30, 2011 03:14 PM
