Old Oct 21, 2003, 07:31 AM
DaveyDave is offline
Find More Posts by DaveyDave
DaveyDave's Avatar
Joined Sep 2003
Newbie: How to make your own battery packs?
Hi gang. I was wondering if there was a good website out there that detailed how to go about making your own battery packs? I fly sailplanes, so it would be for the receiver only, but I thought this was the best forum to post the question. Thanks!
Dave
DaveyDave is offline Find More Posts by DaveyDave
Old Oct 21, 2003, 07:41 AM
simingx is offline
Find More Posts by simingx
now that's a wattmeter...
simingx's Avatar
Singapore
Joined May 2002
You probably want a 4-cell brick pack in that... from the end it looks like this:
oo
oo
The battery connections would then be like this:
Connect them in series with copper braid or battery bars, attach a servo connector for supplying power to the receiver, and you're set! Do ask again if you're not sure...
simingx is offline Find More Posts by simingx
Old Oct 21, 2003, 07:49 AM
DaveyDave's Avatar
Joined Sep 2003
In series
When you say connect in series, you mean connect eact positive to a negative. Like this picture attached?
Old Oct 21, 2003, 07:52 AM
simingx is offline
simingx's Avatar
Singapore
Joined May 2002
Something like that, but the way you drew it, it looks like you're short circuiting the pack. Work cell by cell and you'll be fine.
Old Oct 21, 2003, 08:08 AM
simingx is offline
simingx's Avatar
Singapore
Joined May 2002
A picture speaks a thousand words...
Old Oct 21, 2003, 08:09 AM
simingx is offline
simingx's Avatar
Singapore
Joined May 2002
The other end:
Red lines are where you should solder copper strips.
Old Oct 21, 2003, 08:12 AM
DaveyDave's Avatar
Joined Sep 2003
Ahh! Crystal clear now. Thanks for attaching those pics! Now as far as the servo connector goes... where in the mix does that get attached exactly?
Old Oct 21, 2003, 08:20 AM
simingx is offline
simingx's Avatar
Singapore
Joined May 2002
Can't remember where I got this picture from, but it tells all. Note that modern Airtronics stuff has the same pinout as JR, Hitec and Futaba.
Old Oct 21, 2003, 08:34 AM
DaveyDave's Avatar
Joined Sep 2003
Cool, great pics! Ok, so the positive wire would be soldered to the positive end of the battery (area "A" from the above pics), and the negative lead to area "D"? Where does the third "signal" wire get soldered to?
Old Oct 21, 2003, 08:43 AM
simingx is offline
simingx's Avatar
Singapore
Joined May 2002
Yup, and the "signal" wire is not connected for a battery pack..
Old Oct 21, 2003, 09:06 AM
DaveyDave's Avatar
Joined Sep 2003
Wow, in the coarse of a few minutes, I learned how to make my own pack! Thanks so much simingx!
Old Oct 21, 2003, 12:03 PM
azjerry is offline
Find More Posts by azjerry
Phoenix Deer Vally, Arizona, United States
Joined Sep 2003
How do you solder to a battery without overheating the cell?
azjerry is offline Find More Posts by azjerry
Old Oct 21, 2003, 12:45 PM
Jonas Leander is offline
Find More Posts by Jonas Leander
Swedes don't grow on trees
Jonas Leander's Avatar
Sverige, Stockholms Lšn, Stockholm
Joined Jan 2001
Use a powerful soldering iron, around 30-40 watts for AA's. This is the trick - a quick touch of a hot iron does the job without heating the cell - a long touch of a small iron will heat the cell without allowing the tin to flow.
Clean the surfaces thoroughly and tin them. I use solder paste to make the tin flow even better. Then tin the wire. Now make the joint - just touch the tinned wire to the tinned surface and touch them quickly with the iron - done!
/ Jonas
Jonas Leander is offline Find More Posts by Jonas Leander
Old Oct 21, 2003, 03:35 PM
azjerry is offline
Joined Sep 2003
But to tin the surface on the cell you need to heat it enough to melt the solder too.
Or when you tin the cell do you mean to just clean and apply flux / paste to the cell? Or have I forgotten some finer point of soldering (entirely possible)?
Old Oct 21, 2003, 03:43 PM
Joined Jan 2001
Yes, you do have to heat it enough to melt the solder - but don't worry. The point is to make the process as quick as possible - not to not heat the cell at all. It is perfecly OK - you will not destroy the cell by tinning it. To my knowledge I haven't damaged a single cell - and believe me I messed up pretty badly in the beginning, having to tin, retin, retin, then solder and finally resolder... They take more abuse than you'd think, just try to be quick and you'll be fine. Being quick is greatly aided by an iron with some degree of power.
/ Jonas
Discussion Do You Make Your Own Battery Packs? nitroshark Batteries and Chargers 6 Aug 04, 2007 03:20 PM
Question How to make your own packs? wingbeat Batteries and Chargers 8 Apr 12, 2006 12:37 AM
Need help: how do you make your own battery packs? docprego Batteries and Chargers 3 Sep 16, 2005 07:13 PM
How-To assemble your own xSxP packs Arthur Knowles Batteries and Chargers 8 Mar 31, 2003 10:07 PM
ParkFlyer Wall Hangers--How to Make Your Own! DavidJ Parkflyers 9 Feb 01, 2003 06:56 AM
