Old Mar 19, 2012, 05:02 PM
jofro is offline
Find More Posts by jofro
jofro
Joined Jan 2010
15Kwatt "Quad Finned Triptych" Foamy Jet.
Just started on my largest up to date project, pushing the limit and my luck. 15+ Kw foamy jet at 10' 6" x 7' span. The central 127mm EDF unit will be supported by 90mm boosters on each side running on 28S/105Volts/400+Amp current draw combined with 15-17kg thrust. Using only 6mm foam sheets and lot of C/F is going to make this build bit of a challenge I'm really looking forward to. This is not a build log, only few upgrades will be aded about my progress untill my full buid and flying reviews in RC magazines, Joe.
jofro is offline Find More Posts by jofro
Old Mar 20, 2012, 12:16 AM
gmwahl is offline
Find More Posts by gmwahl
United States, UT, Garden City
Joined Aug 2011
Joe, that's insane!! I am really looking foreword to seeing how this ends up. You really know how to push the envelope! 100+ volts? Wicked!
gmwahl is offline Find More Posts by gmwahl
Old Mar 20, 2012, 12:41 AM
jofro is offline
jofro
Joined Jan 2010
My wife thinks the same of me, but if I don't do something new, different I feel that I'm going backwards in this hobby. I.m really pushing the size limit with this one because of my work bench. 105 volts! I said, combined, 2x8-10S and 1x12S. 5-6kg in batteries but despite the weight this model will be a floater, Joe.
Old Mar 20, 2012, 01:21 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
My question is why only 6mm sheets? You can get 1", 2", and sometimes 4" thick 4'x8' sheets at Home Depot. You can use that as your base, then skin it with the 6mm for a smooth surface.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Mar 20, 2012, 05:34 PM
jofro is offline
jofro
Joined Jan 2010
Hi, answer to your question, because it is the easiest and cleanest to work with. 6x6 C/F makes it perfect for laminating to get my strength. Joe.
Old Mar 22, 2012, 01:42 AM
jofro is offline
jofro
Joined Jan 2010
Working on formers to hold the power unit in place, each fan will have 50cm long thrust tube to get the optimal nperformance, Joe.
Old Mar 25, 2012, 02:12 AM
jofro is offline
jofro
Joined Jan 2010
My project is taking up the shape, Joe.
Old Mar 31, 2012, 03:54 AM
jofro is offline
jofro
Joined Jan 2010
Little progress with my foamy working out placement for 8 sets of batteries, Joe.
Old Apr 02, 2012, 04:21 PM
jofro is offline
jofro
Joined Jan 2010
The main frame almost complete, Joe.
Old Apr 03, 2012, 04:16 PM
jofro is offline
jofro
Joined Jan 2010
The first sign of life, primer and two more coats to go, Joe.
Old Apr 08, 2012, 03:05 AM
jofro is offline
jofro
Joined Jan 2010
6 more inches aded to length after installation of my quad Rudd. fins will make this model pretty good size, Joe.
Old Apr 08, 2012, 06:35 AM
rcrich is online now
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Wow!!!!
rcrich is online now Find More Posts by rcrich
Old Apr 08, 2012, 11:44 AM
larryross is offline
Find More Posts by larryross
Registered FFF Addict
larryross's Avatar
Grand Junction, Colorado
Joined Dec 2007
Wow is a good comment.
Great size Jofro. Looks good hope it flies as good as it looks. Have a safe maiden.
What is the weight with 8 sets of batteries?
Regards
Larry
larryross is offline Find More Posts by larryross
Old Apr 08, 2012, 06:19 PM
jofro is offline
jofro
Joined Jan 2010
Regards
Larry
Hi, again lot heavier then originally expected! For my maiden I'll will use lighter (40cell combined) 30C/4Ah packs resulting in15kg AUW but despite, its very light w/loaded model due to its huge wing area. 2.5kg in bonding agents alone and there's no way to minimize that, 1/2kg in 8G leads and connectors not mentioning the rest so it all ads up. I believe equivalent size composite build would be twice the weight so I'm still laughing, Joe.
Old Apr 08, 2012, 06:53 PM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
at 15kw you should be able to fly ROCKS !
go for it !
birdofplay is offline Find More Posts by birdofplay
Discussion "TWIN WIDOW" largest twin edf foamy jet- latest update jofro Foamy EDFs 54 Mar 04, 2016 01:35 AM
Discussion "15Kwatt, TRIPTYCH" foamy jofro Foamy EDFs 52 Jan 29, 2013 03:58 PM
For Sale 3D Foamy F18 Park Jet Kit nxtdoor Aircraft - Electric - Airplanes (FS/W) 1 Feb 27, 2012 10:01 AM
Sold foamy Jet, Completely Built Arf - make offer rhampton Aircraft - Electric - Jets (FS/W) 5 Jan 08, 2012 05:57 PM
Discussion The jet foamy world's fastest djtibas Foamy EDFs 30 Sep 20, 2011 07:20 AM
