Old Mar 19, 2012, 04:41 PM
Mungo Parks is offline
Find More Posts by Mungo Parks
Joined Mar 2012
Question
Nubie first question
Hi, I am 12 years old and want to build a hovercraft from scratch.
I have been reading the threads here trying to learn about how to build one.
My problem is i do not understand all of the language around the RC world.
Can somebody tell me what a ESC motor stands for.
Any direction towards a inexpensive remote control and servo can be bought would help me a lot. Cheers Alex.
Mungo Parks is offline Find More Posts by Mungo Parks
Old Mar 19, 2012, 05:32 PM
piito is offline
Find More Posts by piito
piito's Avatar
Joined Oct 2010
ESC is basically a speed controller for the motor(s) you are using. You can use a simple ON/OFF switch to power the motor(s) but this will give you only 100% RPM level or 0%. So if you want to slowly decrease or increase the motor turns you will need a ESC (speed regulator) between the motor and receiver.
You can use a Spektrum system: http://www.ebay.com/itm/Spektrum-DX5...item53e67be8d4
or http://www.ebay.com/itm/Walkera-2-4G...item2c5fc9ebe9
There's plenty of manufacturers, just type in 4 channel Tx Rx at ebay and you'll find what you are looking for. You will get used system with half price usually.
Have fun with your project
piito is offline Find More Posts by piito
Old Mar 19, 2012, 06:11 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
ESC = Electronic Speed Control. And for modern (brushless) electric motors it is needed to drive the motor.
BTW if you want ideas on what to buy it's useful to know where in the world you are.
Steve
slipstick is offline Find More Posts by slipstick
Old Mar 22, 2012, 09:17 AM
Joined Mar 2012
Thank you for your help, I live in Canada, Winnipeg.
Alex.
Old Mar 22, 2012, 01:50 PM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
Inexpensive RC supplies
Here are some links to where you can get inexpensive RC supplies . Radio transmitter with receiver : http://www.hobbypartz.com/79p-ct6b-r6b-radiosystem.html Motor , ESC ( Electronic Speed Control ) and servos ( control your rudder , etc. ) combo : http://www.hobbypartz.com/60p-dy-1006.html Batteries ( get at least two ) : http://www.hobbypartz.com/77p-sl1000-3s1p-40c-3333.html Battery charger : bottom left of this page http://www.lazertoyz.com/shop/batteries.htm This is a very easy to make ( skirtless ) hovercraft - kinda works like an Air-hockey puck . Made from 1 piece of Dollar Tree foamboard , some hot glue and packing tape . 1 motor ( connected to throttle channel ) inside can for lift , a second motor ( connected to elevator channel ) for forward thrust , and rudder servo connected to either rudder or aileron channel . Here's a video of it , took the hood off because it was hitting the thrust prop
Skirtless hovercraft (2 min 7 sec)
balsa or carbon is offline Find More Posts by balsa or carbon
Old May 07, 2012, 03:57 PM
RPM314 is offline
Find More Posts by RPM314
Tailless fly-hard
RPM314's Avatar
United States, NY, Brooklyn
Joined Apr 2012
Hi, I want to do the same thing as Mungo, but am a bit more familiar with R/C stuff. For racing, what is the best planform? Nobody seems to have that info. Also, I'm planning to power everything with EDF, and build with Depron, would that be good? Thanks.
Also, how exactly is the skirt constructed? Still unclear on that.
RPM314 is offline Find More Posts by RPM314
Old May 08, 2012, 07:39 AM
ramicaza is offline
Find More Posts by ramicaza
The Anti-Heli
ramicaza's Avatar
Thailand, Bangkok
Joined Dec 2011
This is probably your best bet for racing. EDF lifter's are inefficient so try getting the lowest kv lifter motor you can find (that still fits in the fan of course) Skirts are tricky so therefor, I would suggest going skirt less... especially for racing. LOL I'm basically summarizing the hovercraft I linked. Another must have for racing is a proportional lifter on your throttle or elevator. You need to be able to stop fairly quickly. Depron is ok but I suggest taping up the bottom of the craft with fiber glass re-enforced tape of similar.
ramicaza is offline Find More Posts by ramicaza
Old May 08, 2012, 07:44 PM
RPM314 is offline
Tailless fly-hard
RPM314's Avatar
Joined Apr 2012
Well, skirtless would only work on linoleum type smooth surfaces, which tend to be too small to reach top speed. I think tarmac would be best for speed, so a bag skirt. Multi-terrain capability is important: I'm not looking for strictly 'racing', just fast. I'm also on a budget, so a single EDF is the max. I know that that will involve compromise, but it's necessary and simpler.
On the attached file, the fan feeds a bit of exaust into the skirt, with a flap to control the intake. Also, a couple of 6mm depron sheets sandwiched with epoxy to make 1/2 inch layer. (The skirt looks messed up, but sketchUp isn't good at that kind of stuff.)
Old May 09, 2012, 05:24 AM
ramicaza is offline
The Anti-Heli
ramicaza's Avatar
Thailand, Bangkok
Joined Dec 2011
Skirtless is fine for tarmac with a sufficient lifter. However water is an issue unless you design a bulky, beveled, depron, "stiff skirt" I've never had very good luck with the flap type design. It might be that I just like the drifting capability of a conventional lifter/pusher set up but thats just me. IMO, you should really throw in the bit of extra money required to buy the lifter motor/esc. A conventional prop will do.
Old May 10, 2012, 05:24 PM
RPM314 is offline
Tailless fly-hard
RPM314's Avatar
Joined Apr 2012
No, I found some good skirt material here. How about the skirt stuff is its own part that is velcro'd onto the rest, and makes a skirtless craft without it?
I'll just get props (high pitch) instead of EDF if the lifter is that important. SketchUp model pending.
Edit: how would one control the lifter with a conventional Rx? Plug the ESC into a servo port?
Discussion Just bought my first RC...Traxxas Slash, but have a question flyhighr Off-road Cars 8 Mar 10, 2012 10:40 PM
Help! NAZA question about switching from 3s to 4s, do I have to change in software first. jasper7821 Multirotor Talk 9 Mar 09, 2012 11:07 AM
Discussion Flying for the First Time: a Question on Control rkenosha Hoverfly Technologies 2 Feb 23, 2012 08:28 PM
Discussion Nubie - first bird ordered Tree_67 Micro Helis 13 Dec 11, 2011 12:01 PM
Discussion First post, first scratch build and first question.... I R Grunt Hand Launch 2 Nov 16, 2011 06:47 PM
