Old Mar 19, 2012, 03:58 PM
ripmax is offline
Find More Posts by ripmax
ripmax's Avatar
uk. northampton
Joined May 2009
Yaw control on kk fc board....
Any idears on how to speed up yaw control on a kk board?
I'm running xcopter v2.3 software and happy with the way it flys, don't really want to flash the software as I'm not sure how to do it!! (if it ain't broke don't fix it!!) would just like yaw response to be quicker.
Using a spektrum dx6i, 20 amp escs in an x400 frame from GLB, flys great just yaw is a bit slow, I have travel adjust set to max on yaw and in ufo mode on the board as that seems to say it gives the best yaw response.
ripmax is offline Find More Posts by ripmax
Old Mar 19, 2012, 04:00 PM
randall1959 is offline
Find More Posts by randall1959
Joined Feb 2004
You can tilt the motors a little. Two have to go one way and two have to go the other but I'm not sure which ones.
randall1959 is offline Find More Posts by randall1959
Reply With Quote  (Disabled)
Old Mar 19, 2012, 04:05 PM
nabiul is offline
Find More Posts by nabiul
Joined Jun 2006
Heavier propellers. Yaw control works by unbalancing the torque from the opposite rotating propellers. One set of propellers slow down and the others speed up and the unbalanced torque causes rotation, heavier propellers causes a greater unbalanced torque hence greater rotation speed.
nabiul is offline Find More Posts by nabiul
Old Mar 19, 2012, 04:10 PM
SeismicCWave is online now
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
I will vote for propellers with larger diameter. Also shorter arms.
SeismicCWave is online now Find More Posts by SeismicCWave
Old Mar 19, 2012, 04:17 PM
ripmax is offline
ripmax's Avatar
uk. northampton
Joined May 2009
Would like to keep the frame as is, I'm using 8045 props 8 inch, do u think 10 inch props might speed it up?
Old Mar 19, 2012, 04:23 PM
AMA 46133
Hawaii
Joined Feb 2003
9" or 10" prop may do it. You may want to reduce the pitch a little if you use a larger prop so as not to overload your motors.
Old Jun 03, 2012, 12:14 AM
gitit20 is offline
Find More Posts by gitit20
gitit20's Avatar
Joined May 2012
I have the x525 with the same prob i using a gws 9050 props pretty big and my yaw is slow as hell too also using 2.3 firmware no idea how to fix this everything else is fine it takes about 20 to 30 sec for it to make a complete 360 spin
gitit20 is offline Find More Posts by gitit20
Help! Yaw gyro KK board not responding Menno Multirotor Talk 10 Nov 26, 2013 09:58 AM
Sold KK+ Red Board FC - Firmware of your choice. airbagit13 Aircraft - Electric - Multirotor (FS/W) 6 Oct 20, 2011 01:07 PM
Discussion Yaw Pot on KK Controller Board and Torque rtbchris Multirotor Talk 1 Aug 29, 2011 08:48 PM
For Sale KK Blue board FC programmed for a tricopter Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Jul 12, 2011 07:49 AM
For Sale KK Blue board FC programmed for a tricopter Z06 Tony Aircraft - Electric - Multirotor (FS/W) 0 Jul 12, 2011 07:42 AM
