Old Mar 19, 2012, 06:14 AM
stormheli is offline
Find More Posts by stormheli
Closed Account
Joined Mar 2012
Help!
trex 450 clone main gear problem
ran into a small problem with my trex 450 clone. i was checking the blade tracking and had the heli taped to my table. was up about a 1/3 throttle and accidentally fliped the 3 d mode switch. all kinds of noise.i shut it down as quick as i could. i have teeth missing on the main gear which is easy to replace but i just noticed when i was rotating the gear that the motor spins around too. meaning the body of it . is this normal? or have i got bigger problems? its a brush less motor. maybe it spins to keep cool because its has vents on the tail end of it. any info would be appreciated. thanks in advance
stormheli is offline Find More Posts by stormheli
Old Mar 19, 2012, 10:14 AM
LiQuid*Xion is offline
Find More Posts by LiQuid*Xion
KoOl BrEeZe
Joined Feb 2012
Depends on your motor. Some spin some dont. I'm betting yours does, So all is well in that area. You stripped your main gear because your head speed was was not going fast enough to keep on track with your sudden motor increase. Rookie mistake, happened to us all at one point or another. But please dont TAPE your Helli to a table with blades on to check your tracking. Very dangerous. And hard on the heli itself. check your blade tracking while in a hover.
LiQuid*Xion is offline Find More Posts by LiQuid*Xion
Old Mar 19, 2012, 11:03 AM
DCT1 is offline
Find More Posts by DCT1
DCT1's Avatar
Joined Oct 2008
Let me get this straight ,,,,? You own a helicopter ,, and don't know if you have a ( out runner or in runner motor???) Ok,,,,,, out runner the outside of motor turns,,,,,, in runner the outside doesn't turn!!
DCT1 is offline Find More Posts by DCT1
Old Mar 19, 2012, 12:24 PM
1Man1Mountain is offline
Find More Posts by 1Man1Mountain
Never Go Full Retard
1Man1Mountain's Avatar
Sverige, Västra Götalands Län, Dals-Ed
Joined Sep 2011
He obviously in his first few setups in a new built heli Clone and your bashing his lack of knowledge?
But yes. in electric motors they can spin on the outside wich gives more effect and cooling but you would not use it in a RC car for example because of all the dirt and the trouqe req.
1Man1Mountain is offline Find More Posts by 1Man1Mountain
Old Mar 19, 2012, 08:33 PM
Closed Account
Joined Mar 2012
thanks for the input liquidclown. thas me rookie! no more table tieing to say the least!!!!!! lesson learned! seen a guy on youtube do it like that, but then again he didn't hit the switch either! my own fault. there's only a few teeth missing and i will order another gear. can i still use the gear i have till it gets here?
Old Mar 19, 2012, 08:38 PM
Closed Account
Joined Mar 2012
yes you got it straight! that was easy huh? i never said i knew everything! just here too learn from others like yourself. this is only my 3rd heli. rookie mistake,but im learning. its a hard way to learn though
Old Mar 19, 2012, 08:39 PM
Closed Account
Joined Mar 2012
thanks for the back-up mountainman. understood! thanks for the answer.
Old Mar 19, 2012, 08:45 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Wait for the new gear.
pmackenzie is offline Find More Posts by pmackenzie
Old Mar 19, 2012, 09:20 PM
Closed Account
Joined Mar 2012
my clone is the same as a trex 450 se v2 and the main gears are suppose to be the same. that being said. are these the only main gears that will work? or are say the sport version ect the same. the one i have is 150 tooth. anyone know???????
Old Mar 20, 2012, 01:11 AM
Joined Sep 2011
basicly count the teeth and you should be fine. Align maingear are blue aswell.
Old Mar 20, 2012, 11:41 AM
videonic is offline
Find More Posts by videonic
videonic's Avatar
United States, VA, Chantilly
Joined Jul 2006
the gap between pinion and main gear was not right -------> broken the main gear teeth when turn on the idle up SW.
videonic is offline Find More Posts by videonic
Old Mar 20, 2012, 01:17 PM
utah Flyer is offline
Find More Posts by utah Flyer
Woods Cross UT
Joined Dec 2006
Advice from one noob to another. Inhibit the idle up! If you accidentally hit it when you are learning to hover you will need a change of underwear.
utah Flyer is offline Find More Posts by utah Flyer
Wanted Trex 450 Pro OWB or main gear...... bucknut Aircraft - Electric - Helis (FS/W) 0 Oct 27, 2011 07:43 AM
Sold Trex 450 Main gear Set (auto gear, main gear, oneway bearing,gear case) SOLD Shipped mmalik4 Aircraft - Electric - Helis (FS/W) 1 Aug 10, 2011 02:11 AM
Discussion problem with a trex 450 main gear not making contact with tail gear nashiem Electric Heli Talk 1 Mar 16, 2009 10:50 AM
Wanted 2 trex 450 main gear swap for mx400 main gear russainred95 Aircraft - Electric - Helis (FS/W) 2 Jan 27, 2008 10:34 PM
Discussion Trex 450 Pinion to Main gear mesh problem Dan_eflyer Mini Helis 9 Mar 27, 2007 10:44 AM
