Old Mar 18, 2012, 07:39 PM
stevematt18 is offline
Find More Posts by stevematt18
United States, OK, Broken Arrow
Joined Jul 2008
help! how do i replace flybar blade 450
hey how do you i replace the flybar in the blade 450?
if you can include pictures that would be great!
stevematt18 is offline Find More Posts by stevematt18
Old Mar 18, 2012, 07:56 PM
lawlist is offline
Find More Posts by lawlist
Crash and Burn
lawlist's Avatar
Joined Sep 2011
1.5 mm hex head allen wrench, remove the screw on the center of each side of the flybar assembly (directly above where the flybar passes through), remove the screws to the weights next to the flybar paddles, remove the screws to the flybar paddles, (you may need to gently twist off the flybar paddles if the flybar is threaded at the ends), slide out the flybar and insert the new one equal distance on each side, then put in all of the screws with locktite. Paddles are parallel to the flybar assembly, and the thin part of the blade points in the same direction as the thin part of the main blades.
lawlist is offline Find More Posts by lawlist
Old Mar 18, 2012, 08:08 PM
Joined Jul 2008
thanks!
Old Aug 23, 2012, 06:46 PM
Mick2311 is offline
Find More Posts by Mick2311
Joined Aug 2012
Fly bar replacement
Good morning all. I own a blade 450 and am trying to replace the fly bar for the first time. I got the old one off easier enough, but when I put the new one on, I got the paddle and screw in weight on 1side. But come to the other side the notch in the bar is about 3-5mm off coming out the other side. So if anyone has any ideas please how to get the bar out that bit extra please 2put the other screw in wait please.
Mick2311 is offline Find More Posts by Mick2311
Discussion Blade 450 w sticking servo.. (Can I replace stock servo w tail servo)? h8tow8 Electric Heli Talk 6 Jul 31, 2012 07:43 PM
Discussion How do you Replace the Tail Rotor on the Solo Pro V2? iflychrysalis Micro Helis 2 Jan 10, 2012 12:13 AM
Discussion How do you know it’s time to replace the blade grips on your MSR? mikeflys Micro Helis 6 Sep 20, 2009 09:32 PM
Question How do I tighten the flybar on my Blade Cp Pro? fyrc22 3D Electric Heli Flying 1 Mar 04, 2009 05:57 PM
Discussion How do you replace the flybar on the 5#10? apl Coaxial Helicopters 2 Apr 21, 2008 02:20 AM
