Old Mar 23, 2012, 11:42 PM
RawmadeCF is offline
Find More Posts by RawmadeCF
Perpetually covered in resin
RawmadeCF's Avatar
United States, NV, Las Vegas
Joined Dec 2011
Got my Zippy 350 bare cells from Hobbyking.
RawmadeCF is offline Find More Posts by RawmadeCF
Old Mar 24, 2012, 02:37 PM
wowhobbies is offline
Find More Posts by wowhobbies
Joined Jan 2009
There are several battery options. From the flight performance point, the 350mAh and the 400mAh are over weight, you will find the Mini CP more agile, quicker and easier to fly with lighter battery. If you are doing sports flying only than the 350mAh comes into play. 400mah is even better if you are just cruising around.
For best 3D performance we have the following batteries from 3 different factories. We also have the Walkera stock batteries but we do not recommend them, especially for a BL conversion.
Extreme battery
http://www.wowhobbies.com/hplg32502401s_battery-2.aspx
Oversky battery- Wow's pick for best over all Mini CP performance
http://www.wowhobbies.com/turboace300mah1sbattery.aspx
Hyperion battery
http://www.wowhobbies.com/hplg32502401s_battery.aspx
Brushless conversion options are
Motor only
http://www.wowhobbies.com/turboace41...motor-43g.aspx
Includes matched timing ESC and Genius main gear in the kit to slow down the head speed
This is equivalent to using an 8T pinion motor since the Genius main gear is larger.
High head speed kit including matched timing ESC
http://www.wowhobbies.com/turboace41...r-43g-3-1.aspx
I recommend getting the kit for 2 reasons.
1. We checkout all the timing for the Walkera tail ESC with the CO5 for startup. There is a good percentage won't start the motor.
2. The pinion is a bear to install and we bend so many of the 1mm motor shafts already even with the special custom tool we use. I know it is more expensive going with the kit as a turn key solution but there will be a lot less hair pulling. If you chose to save money and do everything yourself, that is great and the information should help you. At least you know what can go wrong with the conversion and be ready for it.
Jonathan9113
www.WowHobbies.com
wowhobbies is offline Find More Posts by wowhobbies
Old Mar 24, 2012, 04:10 PM
Joined Jan 2009
MCPX, Genius or Mini CP which one is better?
Those who has flown all 3 know the answer is Mini CP. We carry all 3 models so we are not bias on this. The Mini CP inverted flight is so much easier to manuever than the MCPX and the Genius even for somebody first starting 3D. Unless you bought the stock Mini CP version with the 9T pinion motor and the so so stock battery, it tends to bog.
The good news is Wow has recreated what should have been. Mini CP with 8T pinion and good battery or Mini CP with 9T pinion re-geared to Genius main gear with the same excellent result.
Tom is correct, the BL conversion is the best way but if your budget does not allow than get the Mini CP-PRO that has been re-geared. For the radio, if you don't like the Devo 7 and find it harder to program but can not afford the Devo 8S, the Devo 10 is the best choice, ETA 3/30. The Devo 10 has many benefits over the Devo 8s. The backlite LCD can be seen under sunlight and it has the vibration alarm, however it does not have color.
Goto
http://www.wowhobbies.com/walkera-mi...elicopter.aspx
Jonathan9113
www.WowHobbies.com
Old Mar 24, 2012, 05:07 PM
RawmadeCF's Avatar
Joined Dec 2011
Heres a size comparison of the Nanotech 300, Fullriver 350 and Zippy 350.
They weigh 7.9g, 10.4g and 9.9g respectively, with connectors.
Old Mar 24, 2012, 06:34 PM
scub is offline
Find More Posts by scub
United States, MA, Springfield
Joined Dec 2010
the c05m weighs only like 4 grams with no plug so even if the battery is heavier the weight loss from upgrading motor you're still saving weight compared to the stock mini motor which is nearly 10 grams.
heck, i think the 9g battery, esc and brushless motor is still lighter than stock! but i do agree less weight the better..
scub is offline Find More Posts by scub
Old Mar 24, 2012, 10:28 PM
RawmadeCF's Avatar
Joined Dec 2011
Man oh man, dont my Zippy bare cells look professionally put together?
I couldnt find anywhere that sells the plastic heat shrink (not electrical shrink) so I just used the reinforced tape like the Walkera lipos, I wanted them to be all nice and color wrapped with my logo on it but noooo had to build them all plain.
Too picky? haha
Old Mar 24, 2012, 11:10 PM
i812 is online now
Find More Posts by i812
i812's Avatar
Joined Aug 2009
Mail Order source for heat resistant Kapton Tape is: http://s.dealextreme.com/search/kapton+tape
If you live near a large US city, maybe Fry's Electronics has it?
It looks like Walkera also uses it to secure Temp Sensor to Motor.
i812 is online now Find More Posts by i812
Old Mar 24, 2012, 11:22 PM
scub is offline
Joined Dec 2010
Too picky? haha
i use polyimide tape..it's very thin and light. to test it i put a heat gun at 300c and didn't melt the tape at all
it's the same type of tape that holds the temp sensor on the motor.
http://www.dealextreme.com/p/polyimi...3m-260-c-21358
Old Mar 24, 2012, 11:51 PM
RawmadeCF's Avatar
Joined Dec 2011
Ahhh thats what its called! Thats what Walkera uses at the leads under the tape. Gonna have to get some.
Old Mar 25, 2012, 08:39 AM
mescalinedream is offline
Find More Posts by mescalinedream
Joined Jul 2008
http://www.wowhobbies.com/turboace41...tor-43g-1.aspx
When are people going to try this motor? I would love to hear someones review of the c06 motor in a mini cp. I would but I have no money. Please someone find one online and buy it, then install it, then tell us.
mescalinedream is offline Find More Posts by mescalinedream
Old Mar 25, 2012, 10:37 AM
itsmillertime is offline
Find More Posts by itsmillertime
United States, TN, Memphis
Joined Dec 2011
How about this one: http://www.hobbyking.com/hobbyking/s...r_10800kv.html
Once again, wow has gotten too greedy with their mark-ups. $60 for the brushless conversion!?
itsmillertime is offline Find More Posts by itsmillertime
Old Mar 25, 2012, 01:15 PM
i812 is online now
i812's Avatar
Joined Aug 2009
I have a lot of respect for Wow, their pricing, and providing us with valuable information.
If you think you can do better, I challenge you to do it. If you're successful, you'd make more people have bigger smiles.
But until then, I honorably bow to Wow.
Thank you for your outstanding service Jonathan!
Old Mar 25, 2012, 01:44 PM
Joined Jan 2009
You can purchase parts which we also carry, do it yourself and save money. Greedy is a pretty heavy word to use, is Apple charging 2 times more than PC greed? They are providing value to the end users. Here we have a kit that is a turn key solution for people who don't want the fuzz and just want to fly
Please understand we are using US labor to do this and we also guaranteed it with advanced replacement for US located customers with postage prepaid both ways if anything goes wrong. We have the same guarantee for the MCPX BL conversion kit.
For people who are handy and would like to save money here is what you can do. Purchase the following parts.
http://www.wowhobbies.com/salehm-43b...a43b4g3-1.aspx
http://www.wowhobbies.com/batteryrec...nectorset.aspx
solder it on the power lead
buy shrink tube online and use a heat gun to shrink it after it is done
The motor connector is all done for you on this motor and the shaft is tapered down to 1mm to fit your stock pinion, if you buy the Hobby King one, the shaft is 1.5mm which you need to mill it down to 1mm to fit the pinion. In the past, I have milled the pinion down but it is extremely hard without destroying the motor shaft. You can also try to find a pinion with 1.5mm bore from another online store. Also make sure you buy a 3 pin motor connector and some shrink tube, and yes, Wow has it listed for $24.95 but the connector and the shaft are all ready.
Next pull off the pinion of your brush motor using a pinion puller
Push the pinion in, enlarge the bore if it is too tight, it needs to be exact or you will bend the 1mm motor shaft and the motor is toast.
Last of all there is about 30% mis match timing and the motor will cog during startup, but there is a fair chance everything will work.
We have 5 owners here (2 new owners), all work over 100 hours per week, so happend to be Steve Job's hours who passed away from over working his liver. Please do not use the word "greedy" and we'll appreciate it.
Jonathan9113
www.WowHobbies.com
Old Mar 25, 2012, 02:31 PM
RawmadeCF's Avatar
Joined Dec 2011
The c05XL is quite a pretty big motor, dont think it will fit a mcp.
Old Mar 25, 2012, 02:50 PM
scub is offline
Joined Dec 2010
i was under the impression it's just taller..?
Anybody use two packs for speed 400 twins? Daniel English Electric Plane Talk 69 Feb 26, 2014 04:49 PM
Discussion NiCad Disposal GaryK Batteries and Chargers 28 Jan 16, 2014 01:16 PM
Which sensorless SC will work the best for an F7LMR and 10 cells? GregG Electric Plane Talk 6 Nov 18, 2013 08:21 PM
ARF's Cheaper Than Built-Up's Models E-Challenged Electric Plane Talk 42 Aug 01, 2013 10:25 AM
x250...not fair!! tnsfrk Electric Plane Talk 28 Jan 08, 2012 09:30 AM
