I had mine at the factory setting but for 3D I use Manny's pot setting.
See my post for pictures. http://www.rcgroups.com/forums/showp...0&postcount=18 Tom |
Latest blog entry: My RC Web Site
Thanks.
Changing gain's pot position increases or reduces the gyros stabilizing effect. With it all the way up it is extremely stable like a coaxial helicopter. With it turn all the way down it is super responsive and twitchy for 3D flight. The Mini CP can now do full 3D flight with the new RX firmware and upgrades. http://www.rcgroups.com/forums/showp...7&postcount=24 http://www.rcgroups.com/forums/showthread.php?t=1744410 Tom |
http://www.shop.kkpmo.com/ Yeah, they're kind of expensive... |
The OC, California
Joined Feb 2007
Joined Nov 2012
Failed to do a brushless upgrade yesterday with the config in the first post of this thread
- CO5M 13000kv (the HM-C05M-Z-15ADH50, from here) - 9T pinion + genius cp main gear - WK-WST-10A-LT It has very little power and makes horrible noise. See video. Everything seems to turn correctly. The head of rotor is not more difficult to turn manually than with the stock brushless motor. There is a half-milimeter space between the motor and the servo. I've tried to move it further away from the main gear - no change. When I put the stock motor back it works like a charm. Any great ideas? |
Sounds like a gear mesh problem or the pinion is slipping on the motor shaft.
Did you try to run the motor off the heli and see if it runs smooth and quiet? Tom |
Joined Nov 2012
Seems to make normal noice when run on its own.
I assembled the heli with the motor and I do get decent lifting power. However it makes a LOT more noice than the brushed motor and battery time seems awfully short (i.e. shorter than with my new brushed motor) But I have yet to do a timed comparison. Also with the brushlees motor the heli is extremely janky it moves in a robotic way. The only other thing I changed was that I put a genius main gear. Perhaps I should try with my mini cp gear (only that means I'll have to remove the pinion from the brushed motor)? Is it worth the hassle you think? |
Sweden, Helsingborg
Joined Jun 2012
Are the brushless motors supposed to have high frequency vibrations? both my c05 motors vibrate even without pinions, completely assembled my mini vibrates to the point it moves around on the floor with 0 pitch.
I had to lower the gyro sens slightly so that the gyro stopped shaking the servos when hovering indoors. One c05 is a 11000kv 1.5mm / 7&8T from HK and the other is a 11500kv 1mm / 9T from Chinese Jade. |
The flight time with the C05 is pretty good using the Genius CP main gear. You should get at least a minute or more flight time over the stock brush motor. Sounds like the gear mesh is not correct or the pinion is slipping on the motor shaft. Is your pinion a M0.5? If gear mesh or pinion slipping on the motor shaft is not the problem then you may have a bad motor bearing. Tom |
| Thread Tools | |
| Anybody use two packs for speed 400 twins? | Daniel English | Electric Plane Talk | 35 | Mar 06, 2013 05:16 PM |
| x250...not fair!! | tnsfrk | Electric Plane Talk | 28 | Jan 08, 2012 09:30 AM |
| NiCad Disposal | GaryK | Electric Plane Talk | 24 | Jun 16, 2006 11:29 AM |
| ARF's Cheaper Than Built-Up's Models | E-Challenged | Electric Plane Talk | 40 | Nov 08, 2004 02:26 PM |
| Which sensorless SC will work the best for an F7LMR and 10 cells? | GregG | Electric Plane Talk | 3 | Apr 20, 2001 07:46 AM |
