Old Oct 04, 2012, 11:06 AM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
Originally Posted by BThirsk View Post
I have seen this discussion on several threads about parallel VS serial charging.
I may be wrong on this, but I thought this is the difference.
If you parallel charge, would all your batteries not need to be the same starting voltage. I would think when one battery gets to full voltage, the charger would cut out leaving some of the other batteries not fully charge.
In the series method, each battery is an individual cell, so the charger would balance each cell and get all the batteries to full voltage similar to balance charging a 3 cell battery.
You guys have more experience with multiple charging and I need to set up something to charge batteries for the MiniCP and a V120DO2S. Getting too many batteries.
I parallel charge all the time.
Question: What happens if I connect packs with different states of charge?
Answer: A current will flow between the packs. However, this current is not very high, even if one pack is full and the other depleted.
Yet, it should be avoided to connect packs with a state of charge differing over 50%
Make sure the cells are close in voltage before hooking them up to the charge board, within 20% or so seems within reason.
Here is a good thread.
About parallel charging of Lixx / PB packs.
http://www.rcgroups.com/forums/showthread.php?t=932319
http://www.rcgroups.com/forums/showp...1&postcount=93
Tom
Tom Z is offline Find More Posts by Tom Z
Old Oct 05, 2012, 08:21 AM
i812 is offline
Find More Posts by i812
i812's Avatar
Joined Aug 2009
Tom
For the reasons stated below, I don't think the text I boldfaced above is technically correct.
Originally Posted by flying-llama View Post
When I am not sure of how much current will flow between 2 cells connected in parallel, I put an Amp meter between them to check on the initial current flow.
So far, the initial/peak current flow has not been that much.
The one exception was that once as a test, I connected a fully charged Hyperion 240mAh cell to one at ~20% charge (3.7V):
my ampmeter got pinned and I quickly disconnected.
So in the extremes, there can be quite a current surge.
It is difficult to know what amount of current caused flying-llama's Ammeter to pin/peg without knowing the specifics of the meter; however, I believe most hobbyist Ammeters have a maximum current measurement limitation of 10 A.
Also, within the Julez' post that was referenced above, there's a link (https://sites.google.com/site/tjingu...allel-charging) to a very informative article about parallel charging. At the end of that article, the author provides data on current measurements he made when he parallel connected LiPo's that had 0.2V difference. Here is an excerpt:
"The initial (peak) current represents a rate of just over 7C and within 2sec it was below 4C."
At the end of the article he states:
"The next test will be with the same packs but using a fully charged and fully discharged packs."
I read that article when I first read Julez' post a few years ago, and it doesn't look like it has been updated since then. I hope he's OK, and/or hasn't burned down the place.
i812 is offline Find More Posts by i812
Old Oct 05, 2012, 08:31 AM
Xermalk is online now
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Always wondered , would it be possible to fly the mini in rate mode? Or its gyro only does heading hold?
Xermalk is online now Find More Posts by Xermalk
Old Oct 05, 2012, 09:37 AM
dado099 is offline
Find More Posts by dado099
Italy
Joined Sep 2007
I think it has only HH, because if you set gyro gain below 50% it goes in test mode (led flashing red/green)
where all gyros are disabled (also tail one) and so it is unflyable.
In older WK RX gyro gain below 50% goes in rate mode, so walkera decided to change strategy.
dado099 is offline Find More Posts by dado099
Old Oct 05, 2012, 02:12 PM
Sweden, Helsingborg
Joined Jun 2012
*sadface*
Anyone know if the same applies to the master cp?
Old Oct 05, 2012, 04:00 PM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
*sadface*
Yes, it applies to the MasterCP as well. At 50% the gyro is disabled and is in adjustment(setup) mode.
BThirsk is offline Find More Posts by BThirsk
Old Oct 14, 2012, 04:14 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Bob at Helircstore sent me this prototype canopy for the Walkera Genius CP/Mini CP.
Different colors and patterns will be coming soon and I will post pictures of them.
They are USA Made 100% including the Plastic and Airbrushing paint and US Labor.
Tom
Prototype Canopy for Walkera Genius CP/Mini CP (1 min 13 sec)
Old Oct 16, 2012, 08:35 PM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
I just got my MiniCP, set it up for Devo8S and had a short test flight today.
It is actually an amazing little heli so far. My first impression is it handles as well as my V120D02S.
Old Oct 23, 2012, 11:41 AM
segdohbird is offline
Find More Posts by segdohbird
segdohbird's Avatar
San Jacinto, California
Joined Jan 2004
I'm still using the Devo 7 that came with my ebay used mini cp purchase. I finally got it set up pretty good, but when it gets a little far away I seem to loose communications (about 40')
So my question is how do you tell which transmitter power out the transmitter is 10mw or 100mw ?? Not that I want to get that little thing too far away (hard to see) Ha !
segdohbird is offline Find More Posts by segdohbird
Old Oct 23, 2012, 11:48 AM
j35u5fr34k is offline
Find More Posts by j35u5fr34k
j35u5fr34k's Avatar
United States, MI, East Tawas
Joined Aug 2011
I put deviation firmware on my 8s. Never messed with the devo firmware. Not the answer you wanted I'm sure but it is possible for Devo 6(s)/8(s)/10.
j35u5fr34k is offline Find More Posts by j35u5fr34k
Old Oct 23, 2012, 11:50 AM
j35u5fr34k's Avatar
Joined Aug 2011
Also how fresh are your batteries? My 8s was cutting out yesterday due to low voltage. My Mini CP just fell out of the sky several times.
Old Oct 23, 2012, 11:53 AM
Palle_Plutt is offline
Find More Posts by Palle_Plutt
Kingdom of Sweden, Västra Götaland County, Lindome
Joined Jul 2011
Can you see firmware version?
It usually ends with an a or b and that's tells you 10 or 100mW.
Compare with versions at walkeras home page.
Palle_Plutt is offline Find More Posts by Palle_Plutt
Old Oct 23, 2012, 12:50 PM
segdohbird's Avatar
Joined Jan 2004
Yea I'll check when I get home
So a=10mw and b=100mw ???
Old Oct 23, 2012, 02:57 PM
Joined Jul 2011
I think it's the other way around.
A=100mW
Check FDR's site.
http://rc.fdr.hu/devo.php#devo7
Old Oct 23, 2012, 04:58 PM
segdohbird's Avatar
Joined Jan 2004
A=100mW
Check FDR's site.
Yes it is. Per Walkera site.
Anybody use two packs for speed 400 twins? Daniel English Electric Plane Talk 69 Feb 26, 2014 04:49 PM
Discussion NiCad Disposal GaryK Batteries and Chargers 28 Jan 16, 2014 01:16 PM
Which sensorless SC will work the best for an F7LMR and 10 cells? GregG Electric Plane Talk 6 Nov 18, 2013 08:21 PM
ARF's Cheaper Than Built-Up's Models E-Challenged Electric Plane Talk 42 Aug 01, 2013 10:25 AM
x250...not fair!! tnsfrk Electric Plane Talk 28 Jan 08, 2012 09:30 AM
