Old Sep 26, 2012, 08:51 PM
OrbitalGolem is offline
Find More Posts by OrbitalGolem
Joined Jan 2012
Originally Posted by RotaryC View Post
I have a V120d02S V2 with a Devo 10 coming any day now, I use a CB100 for indoors mainly but today landed it in a tree so its out of commission until it dries out and want another mainly indoor heli, I was wondering if the mini CP would be better suited for indoors (only a small area) or would I be better with the super fp?
Thanks for any replies
Excellent choice with the V120D02S - you'll love it. I have three. I have no issues hovering it and flying it around the house, though you have to keep a leash on it to prevent it from getting away from you. Still, excellent precision trainer indoors. It and my V120D01 (real Walkera classic, that one) have given me enough practice/skills over nine months to have no issues hovering my V200D03 in the house.
I also have a Mini CP - much better for use indoors, particularly if you keep the stock brushed motor. Though I have a brushless kit ready to go, I've been lazy and flying the stock motor until it dies (which it's taking quite a long time to do, pleasantly surprising from a Walkera). 3D is okay with the brushed motor outside, but a brushless would be better to keep the headspeed more constant.
I've read good things about the Super FP, but I'd take a look also at the V120D01. Not sure how long Walkera will keep manufacturing it (if they haven't stopped already). I could really slug that thing around the house and it's surprisingly reliable in crashes, likely due to the relatively low headspeed. That low headspeed also means less damage to whatever it hits.
And when you need something that can fight the wind better than a V120D02S, take a look at a V200D03. I just picked one up and I really don't see the need for a 450 anytime soon, as long as she stays reliable. That thing is a beast - no way I would want anything to be hit by those carbon fiber blades.
OrbitalGolem is offline Find More Posts by OrbitalGolem
Old Sep 27, 2012, 05:28 AM
RotaryC is offline
Find More Posts by RotaryC
United Kingdom
Joined Sep 2011
Thanks for the info OrbitalGolem, I was looking at the v120d01 last year but dont think its compatible with my WK-2402 (read somewhere it wasn't) - D02s turned up today, really nice bird, probably a little to large for round the house though other than hovering and orientation.
Will go for a BNF Mini CP I think, about the same size as my CB100.
RotaryC is offline Find More Posts by RotaryC
Old Sep 27, 2012, 08:45 AM
Joined Jan 2012
As FYI, I use the WK-2403 with the V120D01. This video seems to imply that the WK-2402 works too:
Walkera HM V120D01 (4#6S Flybar Less Version) Test - MyRcMart.com (2 min 44 sec)
Old Sep 27, 2012, 11:44 AM
pmerritt is online now
Find More Posts by pmerritt
Joined Oct 2010
The MasterCP flies really well too.....don't sleep on the MasterCP guys. It's built like a tank (except for the servos) and flies really well.
pmerritt is online now Find More Posts by pmerritt
Old Sep 27, 2012, 06:28 PM
segdohbird is offline
Find More Posts by segdohbird
segdohbird's Avatar
San Jacinto, California
Joined Jan 2004
New mini cp owner
Hey all you mini cp owners
How do you guys charge these little batts.
I have the USB charger that came with the cp and have 6 batteries.
I'm not real inthused about using that charger and was just woundering how you go about charging these little buggers.
I have a cellpro 6 charger but the connectors from the batts don't fit anything that I can find to parallel charge. Are you guys changing the connectors out or what ? And I'm not really sure that the usb charger is charging these to the max.
So whats the skinny ????
segdohbird is offline Find More Posts by segdohbird
Old Sep 27, 2012, 09:47 PM
Joined Oct 2010
like this http://www.wowhobbies.com/hm-cb180-z...1-2-1-1-1.aspx
Old Sep 27, 2012, 10:56 PM
segdohbird's Avatar
Joined Jan 2004
Thanks, that will do it.
Old Sep 28, 2012, 02:19 AM
sbstnp is offline
Find More Posts by sbstnp
Deviant
sbstnp's Avatar
Australia, NSW
Joined Jul 2012
I got one of those too but I desoldered and made it parallel. These little 1s lipos don't really need balancing.
I charge 3 of my 350mah and 300mah at 1.8A and it work very nicely, final voltage is exactly 4.2V on all 3. That would be 3*300 = 0.9A * 2 = 1.8A so charging at 2C. I could probably go higher than 2C but so far it works ok for me. Charging time is around 25 minutes.
My charger is a genuine Imax B6 (recently bought, has security hologram and I verified the serial and security code on manufacturer's website) and it did charge and balance perfectly, no accuracy problems so far.
sbstnp is offline Find More Posts by sbstnp
Old Sep 28, 2012, 09:31 AM
segdohbird's Avatar
Joined Jan 2004
OK thanks for the help. So this should also work. But I think you would have to reverse the polarity. Correct
https://02b5baf.netsolstores.com/hpu...geadapter.aspx
Old Sep 28, 2012, 12:23 PM
sbstnp is offline
Deviant
sbstnp's Avatar
Australia, NSW
Joined Jul 2012
Those plugs won't fit without modifications. Rather do like I did and desolder and re-solder to parallel, just go black to black and red to red, heat shrink and done.
Old Sep 28, 2012, 02:18 PM
segdohbird's Avatar
Joined Jan 2004
Can I use this one ????
https://02b5baf.netsolstores.com/jst...raplugs-1.aspx
Or is there a problem with it also?
Old Sep 28, 2012, 02:30 PM
Joined Oct 2010
you can use that too....that's a parallel charging cable....just remember, when charging parallel the batteries will look like one large capacity battery. in other words, (6) 3.7v 240mah batteries look like one large capacity 3.7v 1440mah btty so, to charge it at 1s you would have to use 1.44amps.
Old Sep 28, 2012, 02:56 PM
segdohbird's Avatar
Joined Jan 2004
Got it Thanks.
Old Sep 29, 2012, 01:41 AM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
I use the Imax B6, so you can see what the charger puts back after a flight.
SoloProFan is online now Find More Posts by SoloProFan
Old Oct 04, 2012, 10:54 AM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
I have seen this discussion on several threads about parallel VS serial charging.
I may be wrong on this, but I thought this is the difference.
If you parallel charge, would all your batteries not need to be the same starting voltage. I would think when one battery gets to full voltage, the charger would cut out leaving some of the other batteries not fully charge.
In the series method, each battery is an individual cell, so the charger would balance each cell and get all the batteries to full voltage similar to balance charging a 3 cell battery.
You guys have more experience with multiple charging and I need to set up something to charge batteries for the MiniCP and a V120DO2S. Getting too many batteries.
BThirsk is offline Find More Posts by BThirsk
Anybody use two packs for speed 400 twins? Daniel English Electric Plane Talk 69 Feb 26, 2014 04:49 PM
Discussion NiCad Disposal GaryK Batteries and Chargers 28 Jan 16, 2014 01:16 PM
Which sensorless SC will work the best for an F7LMR and 10 cells? GregG Electric Plane Talk 6 Nov 18, 2013 08:21 PM
ARF's Cheaper Than Built-Up's Models E-Challenged Electric Plane Talk 42 Aug 01, 2013 10:25 AM
x250...not fair!! tnsfrk Electric Plane Talk 28 Jan 08, 2012 09:30 AM
