Old Aug 14, 2012, 05:07 PM
Skovoroda is offline
Find More Posts by Skovoroda
Joined May 2012
Originally Posted by barzaun View Post
Does anyone know where I can find a 1mm M0.5 7t or 8t pinion? I would like to use a CO5M with the Mini CP main gear instead of the Genius main gear.
I just ordered mini z PN Racing brand delrin pinion. It seems like some people used them with success
Skovoroda is offline Find More Posts by Skovoroda
Old Aug 14, 2012, 05:29 PM
3Dmuse is offline
Find More Posts by 3Dmuse
Ontario, Canada
Joined Sep 2009
Can I have the link, please? Thanks.
3Dmuse is offline Find More Posts by 3Dmuse
Old Aug 14, 2012, 09:36 PM
Joined May 2012
7-10t set
2x8t
I haven't tried them personally yet, so you would have to trust benmlee
Old Aug 17, 2012, 12:47 PM
gdwiz is offline
Find More Posts by gdwiz
United States, NC, Hendersonville
Joined Jun 2010
Homefly.com has what you need. On the homepage look on the column on the left for the pinions.
gdwiz is offline Find More Posts by gdwiz
Old Aug 23, 2012, 02:16 PM
dway is offline
Find More Posts by dway
Joined Mar 2007
Ok, I need some help with my brushless setup. I just got in the newest version of the Oversky 10a esc/converter directly from Oversky. I soldered a 3 pin connector to my new C05m and plugged everything in. I charged a battery and plugged it in, the heli bound and the Esc made a few beeps. I moved the throttle to full and I got another beep or two. I think it setup ok, but the esc won't spin the motor up. If I spin the motor by hand a couple time and give it throttle really quick, sometimes the motor will stutter a time or two and sometimes it will spin a couple revolutions, but that's it. It does it even when I pulled the motor from the heli. I thought maybe I had a bad solder joint on the motor plug so I redid them and they are good. Anybody know what the problem could be?
I bought this thing used last month and was only getting about a minute of hovering with the stock motor so that's why I am going brushless. Oh, the batteries are new 300mah nanotech's so I know it's not bad batteries.
dway is offline Find More Posts by dway
Old Sep 06, 2012, 03:48 PM
Xermalk is online now
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
hrm, anyone know if Kyosho Mini-Z SP Delrin Pinion Gear would be comparable to the PN Mini-Z MR-02 Pro Match Delrin Pinions ?
I'd rather pay a little bit more and get a 6-9t pinion set then a 7-10t set.
Homefly has been listing the 8T M0.5 1mm pinions as out of stock for several months now. and the 1.5mm is discontinued.
Xermalk is online now Find More Posts by Xermalk
Old Sep 16, 2012, 09:05 AM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
Wanted: Walkera Mini CP User Handbook
I am looking for a Mini CP User Handbook.
I built mine from all parts that I bought doing my review for it.
I have the PDF user manual but I would like to have the User Handbook also.
Tom
Tom Z is offline Find More Posts by Tom Z
Old Sep 16, 2012, 10:16 AM
Sweden, Helsingborg
Joined Jun 2012
Tom
Handbook?
All i got with my mini cp was 2 pages with tx settings & explained stick movements for devo controller and a cd with the pdf manual.
and the settings/sticks can be found in the manual.
On a side note, has anyone ordered from Banggood with their "Expedited Shipping Service" DHL/UPS? its only US$37.97 & 2-3 business days to get it to Sweden.
I need to order a new mini as my current one seems to have damaged a solder joint somewhere from a crash, (Even barely noticeable vibrations will make the servos jump to endpoints on it, already tested with new servos).
Old Sep 16, 2012, 12:13 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Sounds like they stopped making the user handbook after the Genius CP which I have.
Thanks for letting me know.
Tom
Old Sep 16, 2012, 03:41 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Here's the manual in PDF: http://www.walkera.com/cn/upload/exp...iniCP_expe.pdf
SoloProFan is online now Find More Posts by SoloProFan
Latest blog entry: Pictures of various boats
Old Sep 19, 2012, 01:50 AM
flying toaster is offline
Find More Posts by flying toaster
aka beerassassin
flying toaster's Avatar
Joined Dec 2009
I purchased the mini cp recently, my first cp heli.
I've noticed a good amount of what I learned is called tail wag.
Are there any settings that typically cause this issue, or is it just a (negative) characteristic of the mini cp?
thx..
flying toaster is offline Find More Posts by flying toaster
Old Sep 19, 2012, 02:43 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Too much gyro gain will cause the tail to wag.
Try 82.0% gyro gain and adjust it for less if there is tail wag.
See my setup guides for Mini CP TX setup.
http://www.rcgroups.com/forums/showthread.php?t=1325037
Tom
Old Sep 20, 2012, 01:51 AM
aka beerassassin
Joined Dec 2009
Thank you for the advice and link to all your settings.
I created a model copy on my tx and tried out your advanced settings, my mini cp seems very responsive now to changes in the pitch. I am still a beginner at cp really and don't fully understand everything that's going on quite yet... I've read through a few articles at rchelicpoterfun to get a better idea
there still seems to be tail wag after lowering the gyro gain. I brought it down to 55% I believe then lower but the heli started spinning violently in circles so I stopped there.
Old Sep 20, 2012, 02:27 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Your welcome.
Since the lower gyro gain didn't stop the tail wag I would put it back up in the 75% to 82.0% range so your tail holds.
If you go to high you will get strong tail wag.
I found these posts on tail wag. See if this helps you out.
http://www.helifreak.com/showthread.php?t=397077
http://www.helifreak.com/showthread.php?t=353559
http://www.rcgroups.com/forums/showp...59&postcount=1
Tom
Old Sep 26, 2012, 06:07 PM
RotaryC is offline
Find More Posts by RotaryC
United Kingdom
Joined Sep 2011
I have a V120d02S V2 with a Devo 10 coming any day now, I use a CB100 for indoors mainly but today landed it in a tree so its out of commission until it dries out and want another mainly indoor heli, I was wondering if the mini CP would be better suited for indoors (only a small area) or would I be better with the super fp?
Thanks for any replies
RotaryC is offline Find More Posts by RotaryC
Anybody use two packs for speed 400 twins? Daniel English Electric Plane Talk 69 Feb 26, 2014 05:49 PM
Discussion NiCad Disposal GaryK Batteries and Chargers 28 Jan 16, 2014 02:16 PM
Which sensorless SC will work the best for an F7LMR and 10 cells? GregG Electric Plane Talk 6 Nov 18, 2013 09:21 PM
ARF's Cheaper Than Built-Up's Models E-Challenged Electric Plane Talk 42 Aug 01, 2013 11:25 AM
x250...not fair!! tnsfrk Electric Plane Talk 28 Jan 08, 2012 10:30 AM
