Old Mar 20, 2012, 05:13 AM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
Can you guys post the flight times here when you get the Zippy 350s ?
I just tested the Oversky 400mah linear 20C battery. Results are in the BL section. Will add head speed later today.
So far the Nano-tech 300mAh is the best battery for the most head speed, thrust, and flight time. The Hyperion 240 mah is very close to it.
Both batteries are good choices.
Tom
Tom Z is offline Find More Posts by Tom Z
Old Mar 20, 2012, 06:30 AM
achogg33 is offline
Find More Posts by achogg33
Joined Oct 2011
Have you tried the Hyperion 250mah batteries that are made for the mcpx?
achogg33 is offline Find More Posts by achogg33
Old Mar 20, 2012, 08:52 AM
pmerritt is offline
Find More Posts by pmerritt
Joined Oct 2010
has anyone tried these? http://www.ebay.com/itm/10x-Extra-3-...#ht_2415wt_965
pmerritt is offline Find More Posts by pmerritt
Old Mar 20, 2012, 09:38 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
I don't have any of them to try out. They should about the same as the Hyperion 240mah battery flight time wise. 10 more mah won't give too much more flight time.
Tom
Old Mar 20, 2012, 10:43 AM
MX48 is offline
Find More Posts by MX48
United States, GA
Joined Dec 2011
Got them on the way, they have gotten thru Chicago so I expect them this week. I'll see what the run time is.
Sport flying only. Can't do/afford 3d .
Moto
MX48 is offline Find More Posts by MX48
Old Mar 20, 2012, 11:50 AM
pmerritt is offline
Joined Oct 2010
i have the miniCP already and the esc and c05 for brushless...waiting for those gunmetal Devo10's actually had one on pre-order but i had to pull out because of an emergency but payday is coming again. I'm thinking about going 8T and keeping basically the stock headspeed. Should make for really good flight times with that ebay battery. I'm actually worried about the tail motor more than anything else.
Old Mar 20, 2012, 01:23 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Hawk goes after my Mini CP !
Just got back from flying my Mini CP BL outside in a big field.
I took some HD videos which I will post tonight of basic flying and flipping and inverting.
As I was flying a Hawk came after my MCP. It chased it very close and attempted to grad the rotor blades a number of times.
It knew something wasn't right so it flew away but came back.
I wish I would have caught this on film but it happened above the cameras view.
I did get the Hawk coming after my MCP again on video and took some still pictures of it. Pictures are in the BL Section.
Will post the video of it tonight along with my other videos of me flying.
I thought the Hawk might get a hold of my brand new heli and fly off with it.
Final Score:
Mini CP: 1
Hawk: 0
Tom
Old Mar 20, 2012, 04:23 PM
RawmadeCF is offline
Find More Posts by RawmadeCF
Perpetually covered in resin
RawmadeCF's Avatar
United States, NV, Las Vegas
Joined Dec 2011
Final Score:
Mini CP: 1
Hawk: 0
Tom
Lol....I can only imagine a big ass hawk swooping and taking my brand new heli away, id be so pissed.
RawmadeCF is offline Find More Posts by RawmadeCF
Old Mar 21, 2012, 10:27 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Went flying outside again today. No Hawk going after my Mini CP this time
but something else attacked my helicopter...
Tom
Old Mar 21, 2012, 01:31 PM
andrewho83 is offline
Find More Posts by andrewho83
United States, CA, SF
Joined Jan 2012
So would you consider this the best configuration for the MCP ?
C05 motor w/9T pinion
Genius CP main gear.
Stock tail motor
Stock servos
andrewho83 is offline Find More Posts by andrewho83
Old Mar 21, 2012, 02:23 PM
Benf207 is offline
Find More Posts by Benf207
United States, CT, Ridgefield
Joined Dec 2009
A 9t pinion will give a higher headspeed, for indoor you are probably better going with an 8t pinion.
Benf207 is offline Find More Posts by Benf207
Old Mar 21, 2012, 02:25 PM
Air Vaca is offline
Find More Posts by Air Vaca
Air Vaca's Avatar
Arivaca,Arizona
Joined May 2008
Hi Tom,
Long time. I know...where have I been?!?
Too broke to afford helis at the moment...this house. You ever see "The Money Pit"?
I had a red tail hawk stoop on my 4g3 and stopped about 18" from a "bird strike". Funny as all get out, watching it back peddle that hard. I kind of keep an eye out...I live next door to a wildlife refuge and they're around, even if you don't see 'em.
regards,
Bill
Air Vaca is offline Find More Posts by Air Vaca
Old Mar 21, 2012, 04:17 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Stock tail motor
Stock servos
That is my preferred setup for normal and 3D flying except for the Oversky 400mah due to it is pretty heavy at 11.2G VS. 7.7G for the Hyperion 240 mah battery.
For normal (non 3D) flying the Oversky 400mah should be fine to use. It had good power when I tried it for a full 4+ minutes.
Tom
Old Mar 21, 2012, 04:37 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Originally Posted by Air Vaca View Post
Hi Tom,
regards,
Bill
Hi Bill,
Got away from the helicopters for a while. Came back here to update my RX/TX sticky and add some more setup guides.
Then saw the Mini CP threads and had to get the MCP! Liked it so much had to do a review on it.
That is interesting you had a Hawk go after your heli also. Sounds like Hawks like helicopters.
I hear it is common for birds to chase a heli or plane but this is the first time I had it happen to me. If only I could have got it all on film!
Think I saw you got the GCP and liked it. If so have you tried to flip and invert or do any 3D?
Tom
Old Mar 21, 2012, 04:50 PM
scub is offline
Find More Posts by scub
United States, MA, Springfield
Joined Dec 2010
definitely recommend going with a 8T or even 7T if you can find them.. the smaller the pinion the lower the headspeed (which is good for mostly sport flying) but you'll have more torque so less bogging and longer flight time..
scub is offline Find More Posts by scub
Anybody use two packs for speed 400 twins? Daniel English Electric Plane Talk 69 Feb 26, 2014 04:49 PM
Discussion NiCad Disposal GaryK Batteries and Chargers 28 Jan 16, 2014 01:16 PM
Which sensorless SC will work the best for an F7LMR and 10 cells? GregG Electric Plane Talk 6 Nov 18, 2013 08:21 PM
ARF's Cheaper Than Built-Up's Models E-Challenged Electric Plane Talk 42 Aug 01, 2013 10:25 AM
x250...not fair!! tnsfrk Electric Plane Talk 28 Jan 08, 2012 09:30 AM
