Old Mar 18, 2012, 05:17 PM
pigly is offline
Find More Posts by pigly
PaulG
Newcastle, NSW Australia
Joined Dec 2004
Comparison of current crop of F3J/TD Planes
I was looking for a way to compare my Egida with the current crop of planes in some fairly simple way. I came across the concept of cubic loading, which is supposed to take into consideration the volume of the wing by dividing the weight by the wing area raised to the power of 1.5. I guess this is a fudge factor but is supposed to have some validity if the same wing profile is used. I know that the wing profiles are different but not that different, so I made the table. I then arranged the various planes in order of their cubic loading at various weights. I took weights of planes I have or had and published data of information from friends. What is apparent is the similarity between a lot of the planes that seem,at first, to be different
It is very obvious that the two Jaro Muller planes use a different philosophy to the others, veering towards the F3B end of the spectrum with regards to wing loading and cubic loading but retaining the low weight of the most modern planes (and thus good launch potential). The average chord of the Espada and Egida are also the smallest, which will affect the Reynolds numbers and, as I have found, mean that the Egida has to be flown faster than the other planes to work at similar Reynolds numbers. It also explains why if you dawdle through sink, the Egida comes down fairly smartly, whereas at higher speeds it does not seem to loose much height at all. I am in no way anything of an aerodynamicist, can hardly spell it, and know that there are other factors involved in how a plane flies but it may be of interest to you. I have added the Crossfire 2 as a F3b comparison, although the profiles used on F3B planes are probably fairly different to those used in F3J planes
pigly is offline Find More Posts by pigly
Old Mar 19, 2012, 01:25 AM
DrFragnasty is offline
Find More Posts by DrFragnasty
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
Number Crunching
Verrrrry interesting Paul. Thanks for crunching the numbers. I've never seen this characteristic before (cubic loading).
Here's the data as a jpg (hope you don't mind the format change) to make it more accessible (see below):
DrFragnasty is offline Find More Posts by DrFragnasty
Old Mar 19, 2012, 01:40 AM
pigly is offline
PaulG
Joined Dec 2004
No Chris, I don't mind at all, took me all my time to change it from a .docx extension to a .doc extension
Old Mar 19, 2012, 10:38 AM
Bob McGowan is offline
Find More Posts by Bob McGowan
NorCal
Joined Oct 2003
How can we do a comparison of top F3J planes without including the current World Champion Icon 2?
Bob McGowan is offline Find More Posts by Bob McGowan
Old Mar 19, 2012, 03:10 PM
pigly is offline
PaulG
Joined Dec 2004
Your right
The Icon 2 seems to be a North America only plane, I think due to the transport problems of the long centre section but I'll add it.
Cheers,
Paul
Old Mar 19, 2012, 03:43 PM
vespa is offline
Find More Posts by vespa
2015 Mukbang Cup Semifinalist
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
By using the 1.5 fudge factor you are simply ranking planes by wing loading. It would be much more interesting if you actually calculated the wing volume but that would be nearly impossible as it requires a decent CAD model of every plane.
vespa is offline Find More Posts by vespa
Old Mar 19, 2012, 04:06 PM
VHO is offline
VHO
Find More Posts by VHO
VHO
glider misguider
Armidale NSW Australia
Joined Feb 2007
Interesting, but...
Hi Paul,
Weather must have been not so good down your way lately
Thanks for the calculations. My take is that the data presented that way demonstrate that models can get to similar performance by many routes. I do like how your Egida can high (well low really) tail it out of sink faster than most, as for the data, I agree the ranking is on wing loading. You don't fancy putting each model into XFLR-5 and cycling them through a series of what ifs do you? Maybe a job for a longer bout of south easterlies
Hutton
VHO is offline Find More Posts by VHO
Old Mar 19, 2012, 04:35 PM
pigly is offline
PaulG
Joined Dec 2004
Yes, But
The weather has been bad but its the Heathcote Cup this weekend, then the Millenium Cup round at Queanbeyan and then I'm off o/s for a month. Plus, the next Egida comes this week, Plus I've got a copy of the program but don't know how to use it!
I've added the Icon2 see how similar it looks to my Xplorer 3.8 cross tail at its heavier weight. I am sure they fly differently but probably not in the sink rates and L/D.
Old Mar 20, 2012, 12:13 AM
Bro is online now
Bro
Find More Posts by Bro
Bro
Bro's Avatar
Southern California
Joined Feb 2003
Xplorer II
Howdy,
How about the 3.8 Xplorer II @ 1745gm? And full strength.
We will not even talk about the 1500gm "lite"...
Same size wing a original X 3.8.
Flying in Europe for a year, and now USA as well!
Best,
Bob
Bro is online now Find More Posts by Bro
Site Sponsor
Latest blog entry: 2015
Old Mar 20, 2012, 03:26 AM
pigly is offline
PaulG
Joined Dec 2004
Yes, All good
Getting the weight down whilst retaining enough strength to take a launch in light winds must be good for dead air times as the wing loading has a direct effect on the sink rate. Once it gets even a bit thermic, that all goes out the window but with the known good handling of the Xplorer range it looks a good bet. However, pilots win competitions not planes. I started this just to see how my Egida sits in the ranks and it is a bit further out on a limb than the others. I have had several Xplorers and retain my 4m ST bought from your good self because it is certainly great in the light conditions. I think that if you can get the weight down whilst retaining full strength, your launches are going to be better. I know that the Egida launches better than anything else I have and is strong enough not to show much bend in the wings and that is with a D box construction! Of course, again, we saw from the last WC that the best pilots can get away from the most ridiculously low launches but, as most of them practice of a short bungy or hand throws, it is not surprising.
Cheers,
Paul
Old Mar 20, 2012, 01:24 PM
Tuomo is online now
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Nice comparison pigly. I also fully agree with your previous post. To me Orca v-tail was the slippery plane that launched well. Orca had very good performance in almost any weather, but was little tricky to fly. I think is the reason why Orca has almost disappeared from competition circles.
The nice thing with F3J is that the plane is not critical. Current mainstream planes can be built at 2kg with quite strong ST structure. This not too expensive and weight and stiffness are just the right for an allrounder. When Perfect / Aspire / Xplorer came out the std lay-up was C68, giving about 2.2 flying weight, which was ok for most conditions, but in very light weather the planes felt little heavy.
Tuomo is online now Find More Posts by Tuomo
Old Mar 20, 2012, 04:33 PM
aussief3b is offline
Find More Posts by aussief3b
Ricky Windsock
aussief3b's Avatar
United States, FL, DeLand
Joined Nov 2008
The standard 3.5M Xplorer ST crosstail flown all over comes out at about 1900grams flying weight. It seems that the 3.5 Xplorer in your comparison must be an old Carbon D Box from 2 or 3 years ago.
Do you think you could add the current 3.5ST?
Gordon
aussief3b is offline Find More Posts by aussief3b
Old Mar 20, 2012, 05:56 PM
pigly is offline
PaulG
Joined Dec 2004
yes
I'll do that and the Orca and the light Xplorer when I have a sec, probably today
Old Mar 20, 2012, 08:35 PM
Larry Jolly is offline
Find More Posts by Larry Jolly
Larry Jolly's Avatar
Joined Oct 2003
Comparing wingloading is an impractical means of comparing the current group of F3J models. This method is lacking enough information to truly evaluate a design and certainly not enough to compare apples and oranges. Just got back from The North Cyprus contest where I flew all day Saturday at 2.6 Kilos with a 3.67 meter wingspan model. There simply is just more to it than squares and weight. LJ
Larry Jolly is offline Find More Posts by Larry Jolly
Old Mar 20, 2012, 11:48 PM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
How can I resist posting in this thread. I've done this for every model out there too, but my formula is a bit different. I use the wing loading in oz/sq. ft and divide that by the sq root of that wing area (in sq ft.) I get the same numbers as pigly, except for the Supra which I have at 67.9 sq dm and not 69.4 .
Anyway,
70 oz icon = 2.71
Originally Posted by Bro View Post
Howdy,
Best,
Bob
1745g 3.8 XII = 2.37
Gordon
1900g X = 2.87
One big thing about the planes getting lighter and the span gettng bigger. The plane can thermal too slowly for its bank angle making the speed differential between inside panel and outside panel too great.
Also regarding comment of Egida outlaunching Xporers, I would find that at odds with all my data. Egida and 3.5X would be about the same weight. The X would have much more wing area to generate higher tension. That higher tension would accelerate the same mass 3.5X more.
fnnwizard is offline Find More Posts by fnnwizard
For Sale F3j - td - "blizzard" (aka buran) erichj Aircraft - Sailplanes (FS/W) 9 Oct 30, 2012 11:45 AM
Cool BIG DRAW IS ON TONIGHT TUESDAY 4th after 8:30 Eastern - MONSTER F3J Team Fund raiser! aussief3b Multi Task F3X 200 Sep 19, 2012 11:06 AM
Question FrSky 2.4 in Supras/TD/F3J? ReidRoberts Sailplane Talk 36 Sep 10, 2012 02:55 PM
Discussion TD TD .051 Conversion to Almost TD.05 RC (Alias Cloning) astronomer1 1/2A Planes 3 Sep 29, 2011 03:30 PM
Discussion TD Supra vs. E-Supra rudder comparison will_newton Electric Sailplanes 4 Dec 12, 2007 11:14 AM
