Old Oct 20, 2003, 10:07 PM
tbitz is offline
Find More Posts by tbitz
Ottawa
Joined Oct 2003
How to use your GWS/Smartech transmitter with FMS simulator
Folks,
I've found a way to adapt the GWS or Smartech 4 channel transmitter to run on the FMS simulator.
I opened up the transmitter and probed with my scope until I found the digital signals that has the encoded positions of the sticks. The signal in the transmitter is a 5v TTL signal which is what the parallel port needs.
All that is needed is a 10k Ohm resistor (color code brown, black, red, gold or silver). The resistor is soldered to the encoded signal on the printed circuit board. A red wire is soldered to the other end of the resistor. A green wire is soldered to the ground of the transmitter.
The resistor is there to limit the current going to the PC. It is a prevent and damage to the transmitter or PC.
I've tried this and it works great. Note you still need the batteries in the transmitter to make this work. Also the transmitter will still be transmitting on the channel you selected. Maybe it is a good idea to remove the crystal?
Anyhow here are some pics:
This is a picture of the front of the transmitter (Duh!). Note the smartech transmitter is a rebranded GWS transmitter.
tbitz is offline Find More Posts by tbitz
Old Oct 20, 2003, 10:11 PM
tbitz is offline
Ottawa
Joined Oct 2003
Here is the meat of the modifications:
Old Oct 20, 2003, 10:21 PM
tbitz is offline
Ottawa
Joined Oct 2003
The picture describes the modifications. Once the are done and the two wires are hooked up to the parallel port you need to start FMS.
Go into the control menu, click on "parallel/serial IRQ-interface 32bit -VXD". Set the input to LPT1.
Then go into the calibrate menu and follow the procedure to calibrate the sticks.
Then set the channels in the following order from top to bottom
4,3,2,1,4,3,2,1
invert channels 4,3, and 2
Thats it.
Cheers,
Tony
NOTE: I've tried this and it works, but there are risks involved with anything in life. So if you break your transmitter or PC you do so at your own risk.
Old Oct 20, 2003, 10:39 PM
tbitz is offline
Ottawa
Joined Oct 2003
Note: I have found that if you try and start FMS with the transmitter connected but not powered it brings the PC to a grinding halt. You need to turn on the transmitter to get things going. I'll have to investigate why this is the case.
Old Oct 24, 2003, 02:19 AM
Tom Viper is offline
Find More Posts by Tom Viper
Joined Nov 2001
Have anyone gotten this to work?
Tom Viper is offline Find More Posts by Tom Viper
Old Oct 24, 2003, 02:45 PM
tbitz is offline
Ottawa
Joined Oct 2003
Tom,
I've been running with this for a few days now. No problems other than you have to turn on the transmitter before you start the simulator and turn off the transmitter after you exit the simulator.
What is happening is when the transmitter is off it pulls pin 10 (ack) low indefinitely which causes the PC to go nuts. This can be fixed by adding a transistor and running +5v from the parallel port, but I can live with it the way it is now.
If anyone wants to do it "properly" I can show you how.
Tony
Old Nov 26, 2003, 08:34 PM
thill is offline
Find More Posts by thill
Joined Nov 2003
Has anyone tried this with a WIN XP machine ?
thill is offline Find More Posts by thill
Old Nov 29, 2003, 08:55 AM
mikesnail is offline
Find More Posts by mikesnail
UK
Joined Nov 2003
uuhmm, i followed your steps, connected it to my computer, scanned for hardware changes and it doesnt find it, and FMS isnt finding it , any ideas what could be causing this?
mike
mikesnail is offline Find More Posts by mikesnail
Old Nov 29, 2003, 09:25 AM
tbitz is offline
Ottawa
Joined Oct 2003
Mike,
I did the modification for my bother and we loaded the FMS on his machine and it did not work. When I used his transmitter on my machine I had no problems.
Looks like the FMS software that reads the joystick through the parrallel port isn't compatible with all hardware.
Tony
Old Nov 29, 2003, 01:37 PM
UK
Joined Nov 2003
oki, well, i spoke to a friend of mine, who opened one of his parrallel connectors, and on his the grey wire connected to pin ten and the black and white one to pin 18, so that is something you may want to look at on your brothers machine, i only have a parrael connector that cannot be opened, so i cant view mine, so i plan on trying to find one i can un-screw open to see if its that/
hope that helps
mike.
Old Nov 29, 2003, 04:45 PM
hairy_llama is offline
Find More Posts by hairy_llama
Joined Oct 2003
I have a windows 2000 machine...does it work on win2k?? I did the mod and in the FMS software the parallel selection is grey...any idea why? I want this to work so bad as I need to learn faceing me flying
hairy_llama is offline Find More Posts by hairy_llama
Old Nov 29, 2003, 04:46 PM
Joined Oct 2003
I can't click resources or mapping that is what is grey and un-clickable
Old Nov 29, 2003, 06:14 PM
tbitz is offline
Ottawa
Joined Oct 2003
Sorry guys, I'm running WIN98. Don't know about the others.
Tony
Old Nov 30, 2003, 12:12 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Sorry to cause you so much inconvenience to modify out TX.
Next GWS TX will build in those circuit into PCB.
http://www.gws.com.tw/english/produc...ransmitter.htm
GWS4CEO is offline Find More Posts by GWS4CEO
Old Dec 01, 2003, 07:46 PM
ihug007 is offline
Find More Posts by ihug007
ihug007's Avatar
Melbourne
Joined Nov 2003
GWS4CEO
Is it just me, or does GWS4CEO shamelessly spam pretty much every thread possible in this forum?
Does GWS have some deal going with rcgroups.com?
Just wondering...
ihug007 is offline Find More Posts by ihug007
Discussion Can i use my Futaba 4ex transmitter with FMS? zigzaggy Simulators 5 Jul 22, 2006 03:49 PM
Need help setting up GWS transmitter with FMS waltj2k Simulators 11 Jun 03, 2005 06:56 PM
use your gws receiver with jr tran mod. RiggerTCM Micro Helis 3 Jun 13, 2004 02:53 PM
How to use your GWS/Smartech with FMS simulator tbitz Electric Plane Talk 4 Oct 21, 2003 11:24 AM
Dreamer...show us how your GWS retracts work with your SB!! mefly2 Parkflyers 7 Jul 10, 2002 06:30 PM
