Old Mar 18, 2012, 01:56 PM
Bob Brown is offline
Find More Posts by Bob Brown
Joined Dec 2005
Question
Minima 6 binding problem--please help!
About 6 months ago I bought one of the first Minima 6 receivers. Just now getting around to using it in a new DLG. My Aurora 9 Tx was bought about August, 2010, and has the original software it came with. The Minima 6 won't bind to the Tx. Could there be a software compatibility problem? Or just a bad Rx?
Bob
Bob Brown is offline Find More Posts by Bob Brown
Old Mar 18, 2012, 05:26 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by Bob Brown View Post
About 6 months ago I bought one of the first Minima 6 receivers. Just now getting around to using it in a new DLG. My Aurora 9 Tx was bought about August, 2010, and has the original software it came with. The Minima 6 won't bind to the Tx. Could there be a software compatibility problem? Or just a bad Rx? Thanks, Bob
The Spectra Module must be updated to at least V3.01
ID-setup follows a slightly different procedure for Minima Receivers than that used for the Optima Transceivers.
. Optima Receivers - Light Weight. Optima_6 LITE Transceiver, Minima 6E & 6T Micro Receivers...
.. Minima are compatible only with Spectra Module V3.01 or higher.
. Hitec HPP-22 2.4GHz Programmer - Manual, FAQ - How to Install & Use (with screenshots).
. AFHSS - ID_Setup (also known as Binding or Linking) & Range Test Procedurefor
........Aurora 9, Spectra 2.4Ghz Module <> Optima Transceiver or Minima Receiver.
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers
& Telemetry
- FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F)
A.T. is offline Find More Posts by A.T.
Old Mar 19, 2012, 07:08 AM
Dan.Cummins is offline
Find More Posts by Dan.Cummins
Launching!
Dan.Cummins's Avatar
Chula Vista, CA
Joined Jul 2006
FYI.....Minima rx's have a slightly different binding procedure than the optima rx's
Dan.Cummins is offline Find More Posts by Dan.Cummins
Discussion Hitec Minima 6 not binding w/ Optic 6 joe_crash Radios 9 Jan 24, 2015 12:36 PM
Wanted Hitec Minima 6 RX YellowJacketsRC Aircraft - General - Radio Equipment (FS/W) 4 Mar 14, 2012 09:32 AM
Help! Aurora 9 Optima 6 Binding Problem swa2153 Radios 4 Feb 04, 2012 05:46 PM
Discussion Hitec Minima 6 not binding w/ Optic 6 joe_crash Radios 2 Dec 14, 2011 02:43 PM
Discussion Minima 6 linking problem hebertjj Hitec/Multiplex USA 15 Sep 30, 2011 08:39 PM
